Buying Advice Considering purchasing a New Holland Boomer 50
   / Considering purchasing a New Holland Boomer 50 #1
Wilverine
Hello all, I'm brand new to the group and am looking at a New Holland Boomer 50 (2013). We have about 35 acres to bush hog and wonder if this is a decent tractor and can we hook up a hay cutter and bailer at some point in the future. (30 acres of pasture 5 or so in woods, it's relatively level and rock free) Any thoughts and suggestions would be appreciated.
Thanks in advance,
Wilverine
   / Considering purchasing a New Holland Boomer 50 #2
Hello all. I am looking at a New Holland Boomer 50 (2013). We have 30 acres of pasture to bush hog, 5 or so in woods. It's relatively level and rock free.
This is a good weight and horsepower tractor for 30 acres.
With 47-horsepower you can pull a 6' wide medium duty Bush Hog through tall grass and pretty heavy brush. If you will be mowing the pasture regularly, so it is all grass and minimal brush, you might be able to power a 7' wide light duty Bush Hog.
Here is a mowing time calculator:
MORE: Rotary Cutter / Bush Hog Considerations for Compact Tractors
You can pull a 6' wide medium duty Bush Hog through tall grass and pretty heavy brush. If you will be mowing the pasture regularly, so it is all grass and minimal brush, you might be able to power a 7' wide light duty Bush Hog.
New Holland compact tractors are private label tractors made for New Holland by LS in Korea. The Loaders are usually made by New Holland in the USA.
Thank you!
   / Considering purchasing a New Holland Boomer 50 #4
NEW HOLLAND BOOMER 50
2011 - 2013
Boomer Series
Compact Utility tractor
Series:Boomer 40Boomer 50
Boomer 47
Type:Compact Utility tractor
New Holland Boomer 50 Power
Engine (gross):47 hp
35.0 kW
PTO (claimed):39.4 hp
29.4 kW (gear)
37.1 hp
27.7 kW (hydro)
New Holland Boomer 50 Engine
Mitsubishi 2.5L 4-cyl diesel
Mechanical
Chassis:4x4 MFWD 4WD
Differential lock:mechanical foot-activated
Steering:hydrostatic power
Brakes:differential mechanical wet disc
Cab:Two-post foldable ROPS.
Transmissions:16-speed synchronized shuttle
hydrostatic
Hydraulics
Type:open center
Valves:0 to 2
Pump flow:8.2 gpm
31.0 lpm
Total flow:12.3 gpm
46.6 lpm (gear)
13.7 gpm
51.9 lpm (hydro)
Steering flow:4.1 gpm
15.5 lpm (gear)
5.5 gpm
20.8 lpm (hydro)
Tractor hitch
Rear Type:I
Rear lift (at ends):2756 lbs
1250 kg
Power Take-off (PTO)
Rear PTO:independent
Clutch:electro-hydraulic
Rear RPM:540
Mid PTO:optional independent
Mid RPM:2000
Dimensions & Tires
Wheelbase:69 inches
175 cm
Weight:3,549 lbs
1609 kg
Electrical
Ground:negative
Charging system:alternator
Charging amps:50
Charging volts:12
Battery CCA:660
Battery volts:12
Battery AH:80
Page information
Last update:December 3, 2014
Copyright:Copyright 2021 TractorData LLC
Contact:Peter@TractorData.com
Thanks in advance,
Wilverine
Hey everybody, we bought this little tractor and are now looking to source implements. Need a 6' Bush Hog and a tiller... post hole digger too. At some point we want to cut and bale hay. Any and all suggestions would be welcomed!
Many thanks,
Will
   / Considering purchasing a New Holland Boomer 50 #6
Thanks in advance,
Wilverine
Boomer 50 is a LS tractor. Do you have a LS dealer around? You can probably save a few thousand $$$.
50HP is not enough for a round baler of any decent size. Are you doing small squares for horses?
Yes, square (rectangular) bales.
   / Considering purchasing a New Holland Boomer 50 #8
Thanks in advance,
Wilverine
The LS-made Boomers date from 2011. My family has a 2012 Boomer 50 with the synchro transmission and it's a solid tractor. You can easily run a 6' rotary cutter with one, it has enough power and weight. An 8' pull type would work for pasture clipping.
It has enough power to make small square bales but it's not a real heavy tractor, so I wouldn't try to pull a throw wagon behind your baler with one. For cutting hay, you are going to be fine for a sickle cutter, smaller drum mower, smaller disc mower, or sickle mower/conditioner (Haybine) but a disc mower conditioner (MoCo, Discbine, etc.) will take way more than 39 PTO HP. Typically those start at about 60 PTO HP and go up from there.
Kubota B2301 (A53317)
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
2023 CASE 580 SUPER N BACKHOE (A60429)
2023 CASE 580...
2017 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60460)
2017 Ford F-550...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
Toyota 7FGCU25 5,000 LB Cushion Tire Forklift (A59228)
Toyota 7FGCU25...
