35 mm slides converted to digital format
/ 35 mm slides converted to digital format #1
m7040
Elite Member
Frederick maryland
Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
I have many old 35 mm color slides that I would like to save in a digital format. There are several hundred of them and I may want to save perhaps a hundred of those. What is the best way to do this and what is your experience with buying a copier or using a service to convert them?
Yes there are copiers available. What is the experience in using these and what is the experience in using a service to send them in to be converted?
/ 35 mm slides converted to digital format #4
I copied several of my 356mm slides, using a scanner at maximum dpi.. Found it a chore to clean them up. Dust showed up. My daughter said she would do it. She said she had no problems with dust. Turned out she scanned them at 300 dpi. If you want to view them enlarged, it is necessary to scan them at high dpi.
/ 35 mm slides converted to digital format #5
I've not used a service. In the past, many years ago, i've used copiers and scanners to do the scanning. It depends on how picky you are. More picky, more expensive for scanner or service.
If money and time are not a problem, you can purchase some pretty expensive slide scanners, and take your time with scanning the slides. Some scanners have automatic feed, which is nice if you are doing a bunch of them. Then do post processing of your images. I had some slides that were almost completely black looking, way under exposed and was able to manipulate the image to get an adequate picture from it.
If i was to do slides that are mostly people oriented, the quality of the image is not as important as being able to recognize the people and have a pleasant viewing experience, i'd be tempted to try a service out. The down side of sending to the services is loss of slides, either from shipping or the facility that will do the processing.
I've also used a digital SLR to take picts of 35mm slides. A stand for this is desirable. The pro for this is if you have the camera, doesn't need to be a SLR, you can try it out and see how it goes. A light source like a light table or something similar will make it easier.
/ 35 mm slides converted to digital format #6
I've hear horror stories of people that send in photos, movies, etc. to have them converted and having the originals get lost. I'd do it myself, or use a local company before I sent them anywhere.
/ 35 mm slides converted to digital format #7
A few years ago I used a local one man shop to convert several 8mm movie rolls (25 ft?) to DVD. I was quite pleased. $1.00 per foot as I recall. I too was concerned with shipping them off and them getting lost. I’d consider a nearby FedEx/Kinkos or similar today if I knew they did the work in-house.
/ 35 mm slides converted to digital format #8
I have the Kodak Slide-N-SCAN linked above. Works good.
Here is a slide I scanned with it. Using 22mb setting.
/ 35 mm slides converted to digital format #9
I bought a Digitnow one that does both slides and photos. You can do photos on a flat bed scanner, but this thing does them quicker and easier. It has a rack that takes 4 slides/load. You have to slide each of the 4 slides into position and do the copying.
Other models are available that will do more slides racked up.
I had several hundred. A long while back, I'd somehow made up a gizmo to do slides on my flat bed scanner but lost that method. This Digitnow thing was better and not very expensive.
/ 35 mm slides converted to digital format #10
Back in 2003 I scanned in over 2200 old slides that my parents had to get them into a digital and usable format. I can't recall the specific scanner I used, but it had a slide holder that held 5-6 slides and automatically scanned them. Took a lot of time sitting by the computer reloading the holder and clicking 'scan' over and over, but it was worth it.
Closest thing I can find now are these, but they are ridiculously expensive. Something like this should cost around $120 these days.
Something like this is what really should be available these days, though this one has horrible reviews and is apparently junk:
RalphVa's one mentioned above sounds like it may be a decent option.
Rob
/ 35 mm slides converted to digital format #11
I'm in that same boat.
Problem is patience, which I am in short supply of.
It'll be 'round toit' thing I guess.
I did start a while back by projecting and selecting some 'keepers' but that soon got boring.
1st step was to load the projector and view to select the keepers but after some 7-8 carousels I kinda gave up, then the wife decided to put that away as she wanted that work space.
So that's my excuse!
/ 35 mm slides converted to digital format #12
The Digitnow gizmo bought around a year ago was only about $40-60. Kodak and some others are much more expensive.
/ 35 mm slides converted to digital format #13
I used a copier by "IT" (Innovative Technology), it copied negatives and slides, and did a super job. I had tried to photograph them with a macro lens on a digital camera, but go poor results. The film in the frame was not entirely flat, so part of the image was not in focus - depth of field was a problem. However the IT devise works, it took care of focus perfectly.
The other hing I noticed is that once copied to digital, I could actually adjust the exposure in Adobe to actually get a better photo than the slide had been. I was very happy with the results.
/ 35 mm slides converted to digital format #14
Here comes the techno Geek part: depending on the slide film, there are from 1500 to 3500 grains per inch. The slower the film, the smaller the grain, and more grains per inch. Kodachrome 200 was about 2000 grains per inch. To capture teh full fidelity, you need to scan at that, so for a 35mm slide you are looking at about 5.2 MegaPixels.
This is slow and time consuming to do. When I converted some 2500 slides I bought a very expensive scanner which had an auto feed feature, it was a Japanese brand, maybe Fuji, been a while. It took standard Kodak Carasol trays. I would load one up with the 100 photos, and launch it, and load the spare tray. That can take a bit, becasue you want to blow any dust off, before you load them. Then come back the next day, change the Carasol out, and load slides in the one that just finished. Took most of a month to run them all through.
The compression strategy is that it starts at pixel 0,0, and decides what colors and gray scale that pixel is and records it. Then it goes to 0,1. If things haven’t changed it goes to 0,2, and analyzes it. If it hasn’t changed, it move on to the next one. If it gets to 0,5 and something is different then it records the location and the new data. And ,moves on until it finds another change.
Things that are pretty uniform can scan quickly, things that have its of changes take longer. Sometimes a lot longer.
There is no quick, easy way to do it and capture the potential of the film.
/ 35 mm slides converted to digital format #15
The difficulty with slides, is that they color change, fade with time are are not standardized. There were different formats of slides. They tend to go into the red and yellow color spectrums. Getting anything back to originality is guess work. That said, I have used with great success, dedidicated slide scanners. One slide at a time and I have to say also, this took forever and each slide required a great deal of post scan correction. It the picts are really important, I would have a Pro do it and pay the price and recieive TIFF digital imagines, which will be rather large. If you want to do it on our own, and you already have a 1200-2400 DPI bed scanner, you can take the slides out of their carriers so you are only using the film. Lay the images all out and do one scan as one large image with very high resolution, save as jpeg.. Then cut them up individually. I use Irvanview for corrections, as its easy to see if you need to do a later Batch correction on a set. Normal human eyes can't see better then a 1080 display.
/ 35 mm slides converted to digital format #16
My slides are about 50 years old and have had color changes. I bought one of the OpticFilm scanners specifically designed for 35mm slides. First I projected all the slides onto the wall and selected the ones I wanted to scan. Then I took the time over several months and scanned them one at a time and did the post processing to correct the color and exposure as much as I could, at least they are now better than the film. It did take a long time but they're better than the film. Our wedding photos were sent out for copies and everyone of them were lost, so I'm not sending out any more pictures.
/ 35 mm slides converted to digital format #17
I use a canon flatbed scanner, has a slide adapter. I’ve done hundreds, and have about 700 to do now.
Dust is a problem, I try to keep the scanner clean.
/ 35 mm slides converted to digital format #18
So many photos and slides are just junk or are of stuff one can youtube or Google to find many pictures of any more. The ones to save are of people and unusual things.
/ 35 mm slides converted to digital format #19
I don't have many old slides and I don't have a whole lot of patience. All my slides are 50 years plus. I'm just going to keep them - as they are.
Are you using the RS40 scanner?
NO ADDITIONAL ONLINE BUYERS PREMIUM ON BID.FIVESTARAUCTION.COM (A64047)
NO ADDITIONAL...
2021 Frontier GM4060E Mower (A64047)
2021 Frontier...
RAIN FLO 1200 WATER WHEEL TRANSPLANTER (A63291)
RAIN FLO 1200...
2014 JAYCO JAYFEATHER TRAVEL TRAILER (A63569)
2014 JAYCO...
2021 LIUGONG 925E EXCAVATOR(INOPERABLE) (A63569)
2021 LIUGONG 925E...
John Deere 5090GN (A60462)
John Deere 5090GN...
