Snowblower size question
/ Snowblower size question #1
450
New Member
Fairbanks, Alaska
Branson 3725CH
Hello,
I have a Branson 3725CH (37hp engine and 33hp PTO). What size 3-pt snowblower would work best? I am thinking about a 72” or 84”. I’m just not sure if a 84” would be to big for my tractor. Thanks
/ Snowblower size question #2
You need to be wider than the tractor.
If you are HST, you can go bigger because you can go slower if you need to without toasting the clutch
/ Snowblower size question #3
Not exactly correct. If it's a hydraulic shuttle which has no dry clutch, the clutch is eliminated from the equation. Rule of thumb is 5 horsepower (pto) for each foot of blower throat width. Don't matter how wide the tractor is, only delivered power matters.
/ Snowblower size question #4
84" = 7 foot = 35 Pto power. Which works but only in light, fluffy snow of minimal depth. Get into heavy wet snow or drifts and you'll be unhappy with the results. I have a 7 foot Lucknow on the back of my M9000 (87 pto) and in the deep heavy stuff, it works the motor hard. Always up on the turbo and sucking down fuel. If I were you, I'd go with a 6 foot unit. Just my opinion.
/ Snowblower size question #5
I had a five foot blower on my first tractor. Ford 1700 4WD with 26 hp. The blower was a tad narrower than the rear wheels. About 3" on each side. It worked just fine. Heavy wet snow is no fun regardless of Hp or blower width. I would much prefer to push thru crusty frozen snow.
Thanks for the help, I think I will go with the 72”. I think my tractor is about 66” wide.
/ Snowblower size question #7
Hello,
I have a Branson 3725CH (37hp engine and 33hp PTO). What size 3-pt snowblower would work best? I am thinking about a 72” or 84”. I’m just not sure if a 84” would be too big for my tractor. Thanks
Both the six and seven foot snow blowers are too large for your tractor to be effective.
The power take off uses the available torque the engine and transmission
generate to provide the implement the centrifugal speed to operate an
attachment like a snow blower.
The resistance created by the snowpack being pushed into the auger housing will drag the
speed of the open cross augers down and continue to pack into the housing as it reaches
the fan housing.
In order to be able to use the tractor in snow effectively you should buy a 4 foot Power Take Off
driven snow blower and have 8 inch wings attached to it.
The reason why is that the 4 foot snow blower will let you operate the Power Take Off at the 540
Revolutions Per Minute engine speed while you are traveling in reverse more effectively and be
less taxing on the engine as it does not have a turbo charger.
The drive train will be operating at the 540 Revolutions Per Minute with the 4 wheel drive operating
in reverse speed at a speed that will not plug the snow blower because the fan will be operating at
The recommended speed
Another way to do this is to use a single stage snow thrower with an engine that would power the snow
thrower and the control the chute and spout with a 12 volt electric system using a pendant control.
The mk martin 1060E single stage snow thrower uses a GX 390 11.7 horsepower engine with a belt to roller
chain final drive.
A single stage snow thrower is of the simplest design for a motorized snow removal implement as it has no
right angle gearbox to provide the torque needed to spin the fan and use a connected shaft to rotate a spur
to worm gear drive to operate the open cross auger.
The single stage snow blower operates using a high speed of rotation to rotate the snow blower rotor to chew in
the snowpack and discharge the broken snowpack at a very high rate of speed up through the cute and spout using
4 paddles in the center of the snow thrower rotor.
The GX390 honda engine uses a double V belt drive system to rotate a drive sprocket and the roller chain to spin
the driven sprocket that spins the snow blower rotor at a very high rate of speed and torque.
The S1054E and the S1060E are equipped with the gx390 engine and have the SSQR mounting system which would
require the SSQR mounting plate to use a a 3 point hitch adapter that would allow it to be attached to the three point hitch.
The other option would be to mount it on your front end loader if the tractor in your avatar is the one you have.
You would need a longer power cord to operate the snow thrower from the cab.
As the gas engines have been detuned due to the EPA mandate for pollution limits at the tail pipe for small engines you
should invest in a larger fuel jet to increase the fuel flow and the engine torque at high idle/wide open throttle which is the
engines operating speed to power the dual V belt drive and roller chain final drive.
The S1054E is $9,250.00 and the S1060E is $9,650.00 based on 2020 prices.
Mounting it on the loader allows you to drive forward while clearing snow and slice off deep snowpack in several layers
if needed and eliminate snowplow berms
Granted it is a lot of money but you need to understand that a snow blower or snow thrower requires high torque to
operate effectively.
The two 3 point hitch mounted mk martin single stage snow blower models offered in the 1000 series are the 1048(48 inch cut) and 1054 model(54 inch cut) that are rated for 15-30 horsepower.
Adding 8 inch wings to the 1054 would allow you to clear 70 inches slowly in one pass. The steel plates would have to be 12 inches wide to allow enough steel to be bolted to the smaller wings of the 1054.
The three point hitch models use a right angle gear box to spin the cross shaft that spins the drive sprocket and roller chain to spin the
driven sprocket that spins the snow blower rotor at 540+ revolutions per minute.
The only thing that will break if you hit an object is the roller chain on these four models of snow throwers.
You want and need simplicity for snow clearing and these 4 snow blowers will provide simplicity and ease of maintenance.
If the tractor you own is the one in your avatar the two motorized units would attach to the SSQR plate.
The two motorized models would require a change order to have a longer control cable added to the order to either snow thrower on your front end loader for it to be long enough to reach the tractor cab.
The change order would also have to have a waterproof male and female plug to allow you to pass the cable from the outside to the inside of the cab. This can be done as waterproof electrical male and female plugs are readily available.
/ Snowblower size question #8
I spent most of a year shopping for a new tractor-blower-front loader- combination. Seems like most dealers are mainly interested in selling what they might happen to have on the lot the day your there. Wound up buying a 55 horsepower tractor with loader and a rear 72 inch 3 point blower, one dealer actually told me a 72 inch blower was to big for my 55 horse tractor and I really should buy the 60 inch blower that he happened to have in stock. So I was a little worried that maybe the 72 inch blower might be to big but it’s definitely not in fact I often wonder if maybe a 7 foot blower might work even better.
The dealer I wound up buying everything from traveled to somewhere in Iowa to pickup my tractor from another dealer, so far after 165 hours of use I am very happy with my choices.
But in your case with a 33 horsepower tractor I do believe you probably should be buying a 4-5 foot blower
I have 33hp at the PTO. I have a older 50” with wings that make it around 60” snowblower now and the tractor runs it with no problem. I would like to upgrade and get a new one with hydraulic chute/deflector and the width of my tractor. Here in Fairbanks, Alaska we don’t normally get big dumping of snow at a time. We normally just get 6”-8” at a time with the most I have seen is around 12”.
/ Snowblower size question #10
I have the exact same size tractor, with HST. I've been running a very heavy 78" blower for 25 years with absolutely no issues. I wouldn't want anything smaller. Every few years we see a 3'+blizzard, but normal annual snow fall is about 70", with storms averaging 6-12". My gravel driveway is 800' long with a steep section, chains are needed when things ice up. I normally wait until the storm is over before doing the driveway. 3" or 3', the blower just eats it up. I'll jinx myself here, I've only broken one sheer pin in 25 years, clearing out a neighbor's driveway, I got too close to his wood pile.
/ Snowblower size question #11
Why upgrade when you can improve your current one
with a few simple improvements?
You can line the chute and fan housing with 1/4" slick
sheet material from Mcmaster Carr and using grain
elevator bolts and nuts to hold it in place and installing
an impeller kit to double or triple your casting distance?
/ Snowblower size question #12
I ran a 6' blower with 27hp at the pto without issue through several blizzards, and many lesser amount snows.
The same blower is now on my L4060 (32.5hp) and it just barely covers my tracks. A 6' blower will be fine on your tractor.
/ Snowblower size question #13
For what it's worth, I run a 72" blower on the back of my B2650, which has under 20 pto hp. I have had it for four years now, and never once have I had an issue with it moving, or not moving, snow. Whether it be light fluffy stuff, heavy wet stuff, or stuff it has already blown, not a single issue (breaking a shear bolt because of a piece of scrap lumber the dog was chewing on isn't the blowers fault).
/ Snowblower size question #14
When I posted 5 pto horsepower per lineal foot of blower width as the rule of thumb. I meant that as being able to remove snow in a timely manner, In reality, you can use any width of blower you want to so long as the 3ph can pick it up. Having said that, I for one don't want to spend a protracted amount of time removing snow, especially with an open station and freezing my tail off (not that I do because I have a cab unit), but snow removal for me isn't something I look forward to. I want to get it handled as quickly as possible and retire to the warm house.
Blowing or plowing snow for me ranks low on my list of 'to do' stuff.
/ Snowblower size question #17
But the pride of workmanship at the end is wonderful. Seeing all the nice crisp lines along the edges, and even backblading the tire marks in certain spots. Very aesthetically pleasing!!!!
Last thing I worry about. My prime directive is plowing / blowing out my rentals so my renters can get to work and pay the rent. Asthetics mean nothing to me, never have.
/ Snowblower size question #18
I can relate. I like a neat job on the dozen or so rural drives that I plow. When I use the blower (infrequently) the job looks incredible!
/ Snowblower size question #19
I agree on liking the results of the blower much better than the plow. Even on storms where I plow, I will go back and do the edges with the blower to get them cleaned up.
/ Snowblower size question #20
I ran a 6' McKee Snolander 520 behind my '64 MF 35 Utility. With some conveyor material added to the fan, lots of rear weight and tire chains, I went through some gnarly storms. I went out late at night and blew a 5' deep x 5' wide plow dump at my mailbox clear across the main road in three swipes. (two for the majority of the snow, the third swipe to get whatever fell off the top)
My machine is around 30pto HP.
My father uses the blower now, I have a company vehicle that I can use for personal stuff with a Boss v-plow. Now my pup sits next to me in the heated seats while I plow us out.
Edit: We had a storm a few years ago that dumped probably 3' and drifted to over 4'. The business behind my house closed for the day, the roads were downright treacherous. Since the business was closed, whomever plows it waited to do it last. I take care of the entrance (we share an entrance) like it's my own, mostly becasue if we need emergency services at home, we'd be out of luck. Too far to try to walk through to get to my house.
Fired up the old Massey, let it warm up, got to cutting the path in. I cleared the entire entrance from my driveway to the state road that I live on, plow berm and all. When I saw the plow guys out there they thanked me, because they wouldn't have been able to get in past the plow line at the road's edge. It was like packed cement and 4' high. I blew it all right across the road.
If that happens again, I'll miss having the blower at my house...
Portable Chicken Coop (A66408)
Portable Chicken...
New 2026 WINSTON 20 Ton Tandem Tag-A-Long Trailer (A62613)
New 2026 WINSTON...
2023 CHEVROLET 3500HD TRUCK (A63276)
2023 CHEVROLET...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
Jobox Truck Bed Tool Box (A64556)
Jobox Truck Bed...
