snow blade rubber edge help
/ snow blade rubber edge help #21
/ snow blade rubber edge help #22
Thanks, Lou! I am sure this will be less expensive too when it comes time to replace my rubber edge. It can be reversed once. But at the rate I am going, that's going to come before the end of this winter.
/ snow blade rubber edge help #23
Is yours the FallLine brand that Lou linked to? It would help to know of all options. Lou's reference looks real good though. Maybe the one sold by FallLine is sold by all others, idk.
The polyurethane edge was bought from Universal Urethane. They have an eBay presence, and have been around for a while with good reviews.
The polyethylene edge was from Goodworks Tractors in Michigan. He sells implements, tractors, etc and may have a presence here on TBN (?). He seems like a stand up guy, and does informative YouTube videos (one on poly, rubber, and steel plow edges).
I’ve never dealt with FallLine, but I’ve heard of them as a large commercial supplier.
I think I paid around $400 for the 84 x 6 x 1.25” polyethylene. My blade is around 600 lbs. Sub compact plows could probably use thinner 3/4-1” material (less expensive).
Hope this helps.
On edit:
Either material cuts and drills easily with normal homeowner tools. I bought mine to dimension, the clamped it on the moldboard and drilled through the back of the mounting holes. I also beveled the edge at around 45 degrees on a table saw.
/ snow blade rubber edge help #24
Thanks, RJ. I know of Good Works. He is just selling implements now, per recent video, so should still be in the scraper edge business too.
/ snow blade rubber edge help #25
I think most of the composite / plastic deck boards are mostly recycled polyethylene. Home Depot has a 15/16" X 5 1/2" X 8 foot board for $20. Maybe someone could bolt one on and let us know how it compares to the polyurethane and polyethylene edges that are ~ 5 - 10x the cost? Just a thought...
/ snow blade rubber edge help #26
The Good Works video RJ referenced makes a good case for the UHMW poly blade. Longer lasting than steel!? Quieter, slicker, and won't mark surfaces. A 5' one for my tractor looks like about $300. Something to think about after I flip my rubber edge.
Here is his web page on ordering:
Here is his, Good Works, video on UHMW poly:
/ snow blade rubber edge help #27
I don't believe the longer lasting than steel statement, but the uhmw polyethylene does wear better than rubber or polyurethane.
I wore in the angled edge on the polyurethane by dragging it on dry pavement. I gave up doing this with the polyethylene edge after about a mile or two, and just cut the angle on the table saw.
/ snow blade rubber edge help #29
Not the best angle in the photo, but I can explain. I use a stall mat cut so that I can flip it to use both edges. Drill holes for seven bolts across a seven foot blade width. There is a steel plate on the front to hold it tight. The rubber edge lasts me years and I have a rough long drive - more than quarter mile. I also do a neighbor’s driveway. Anyway, gets lots of use. Highly recommend this solution. Happy to provide more information or photos if needed.
/ snow blade rubber edge help #31
Gary, do you typically take the rubber all the way down onto the pavement. If so, are you in float?
/ snow blade rubber edge help #32
I take the rubber all the way down and make strong contact with the pavement (asphalt and concrete) but not in float. With a 1” think rubber blade, you would be surprised how durable it is on a snow covered surface. The rubber edge extends about an inch and half or more beyond the steel blade.
Just to be clear, it works differently on dry pavement than it does on snow covered pavement. When I first set this up before winter hit many years ago, I wondered how it would work since I didn’t have snow at that time. As soon as I was able to use it with snow, then it was obvious.
I plow every snowfall down to the bare pavement before anyone drives over the snow by far the best results for us in the NW.
/ snow blade rubber edge help #33
Thanks, Gary. I think a lot of the wear on my rubber edge came from using it on gravel. Not from my asphalt. It does a good job on fluffy snow but if I let it get packed, I have to wait for some melting.
/ snow blade rubber edge help #34
Some wear related geometry to watch for, no matter what edge you have-
if your blade is tilted left/right- say, to throw snow to the right; and your loader "bucket" isn't curled flat- say, it's tilted down a little; then the left side of your cutting edge will be lower than the right side and taking all the weight. (blade's left side is further out along the loader's down tilt angle)
/ snow blade rubber edge help #35
I have a rubber cutting edge since I have an asphalt drive.
Not really too effective, IMHO
I'd like to try this stuff
/ snow blade rubber edge help #36
I use a KK rear blade and my dad uses a snow pusher I made from 1/4" plate and a old end loader tire. Both work quite well and neither really leave any scrape marks.
/ snow blade rubber edge help #38
I know Doughknob - I know ................ However - if that was "real quick" - he would be advised to provide a synopsis on normal or long posts. :):giggle:
And the problem I have is that with the blade actually moving in three planes (left-right with the angle, forward and back with the tilt on the FEL, up and down with the FEL), I seem to always slowly knock it off "level", so when angled, either left or right corner hit first and want to dig in. It happened on the gravel even with the shoes on it (the round spaceship kind).
Very typical with plows on FELs. Very tough to keep the plow float and angle happy
/ snow blade rubber edge help #40
Vevor makes a "shoe" that screws onto your bucket that prevents digging in (you would need at least 2 of them). I was skeptical at first because they were relatively cheap, but have worked fine on my gravel driveway and grassy areas that were not frozen. They were half the price of Edge Tamers, but the Edge Tamers have a nifty accessory that inserts into the shoe making it a minifork for very light loads (like brush etc.).
Just another option.
2020 FREIGHTLINER 114 SD CEMENTECH VOLUMETRIC MIXER (A65643)
2020 FREIGHTLINER...
Champion X18A Air Compressor (A65640)
Champion X18A Air...
18.4-42 Tires (A65640)
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
12x20 Car Port (A65640)
12x20 Car Port...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
