Tractors and wood! Show your pics
/ Tractors and wood! Show your pics #19,661
I think that using chain lube for street motorcycles, carefully, would be the way to go. That kind of lube is made to stick to chains moving at high speeds.
That's what he said. Also to take it off before lubing, otherwise it will throw lubricant all over the clutch, rendering it useless.
Motorcycle chain lube is exactly what I tried, except I did not take the chain off. Lubing the chain was the start of the loss of pulling power on my winch. I lived with it until my bearings started freezing up (which prevented the clutch from grabbing properly), then took it to forestry equipment repair guy down the road from me. He replaced bearings and bead-blasted the clutch.
When I spoke to one of the techs at Hud-Son, he offered two options for the chain:
  1. Don't lube the chain at all, (it will wear faster, but replacing the chain is easier and much cheaper than replacing the clutch)
  2. Remove the chain and use something like motorcycle chain lube which dries on, and wait for it to dry before replacing the chain.
Learned my lesson the hard way.
/ Tractors and wood! Show your pics #19,662
That's what they said in the video, also.
Yes. They are written in English!!!
Thank you!
/ Tractors and wood! Show your pics #19,663
Jstpssng
I just try to be of a little help just glad
you have something that works for you
willy
/ Tractors and wood! Show your pics #19,664
Who needs wedges anyways but it sure was a nice to do some cutting.
/ Tractors and wood! Show your pics #19,665
The manual reads as though it were translated from the original Croation into Swahili by a native Chinese speaker before finally being translated into English.
Sounds like the government got involved in that process, must have saved them hundreds of pennies while costing the end consumers thousands...
/ Tractors and wood! Show your pics #19,667
Still working on the big oak. 15° F today. Not bad. Lots of kindling. Toasty warm inside the cabin right now. Supposed to be -6 at sunrise tomorrow morning. Looking forward to it.
/ Tractors and wood! Show your pics #19,669
Do you know the btu? Looks like it would put out a tremendous amount of heat.
I assume you can cook on it?
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
2023 CATERPILLAR 926M WHEEL LOADER (A62129)
2023 CATERPILLAR...
Eagle Weathervane (A55853)
Eagle Weathervane...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
