Rut repair
/ Rut repair #1
yanmars
I had logs skidded out and the equipment in the soft soil left ruts up to a foot deep. Mostly on my steep hills/lane. They are frozen now. Should I just get a dozer in the Spring to level them. I do have a small lane drag with rippers, a disc and on the flats a plow for my Cat 1 tractor. Can't use the lane the way it is and worried about erosion making it worse. Also a hard place to bring in gravel later. Shoveled most of it by hand in the past out of the bed of my pick up.
/ Rut repair #2
After starting 108 threads, neither your Yanmar model nor your location show.
How can we proffer quality advice without knowing the capability of your tractor?
Perhaps this thread will assist if your Yanmar is similar in weight:
/ Rut repair #3
For Forest Service timber sales, we require ruts to be ripped first to reduce compaction, then smoothed and seeded. If there is any slope we also have water bars constructed perpendicular to the slope.
/ Rut repair
I have access to two tractors. A Yanmar 336d and a Mahindra 4510. Both MFWD and Cat 1 tractors. Small, 33 and 45 HP. I live in western Ohio. Elevation changes on my ground are 75 feet in 300 feet or less. Pretty heavy clay ground but with many rocks in places. Hopes that helps answer the question.
/ Rut repair #7
Had the same situation used a 3 point rear tiller,worked great..
/ Rut repair #8
in my area the loggers that damage the terrain are usually required to repair it.
/ Rut repair
I caused the ruts helping drag out the logs where the horses could not. The repairs will be on me.
/ Rut repair #10
??? A horse or mule can go work in places no tractor could even begin to. Please explain this.
/ Rut repair #11
Either a rear blade or LPGS with shanks. I prefer the LPGS with shanks. Chew it up - level/smooth it out. Compact with your tractor when all is smooth.
/ Rut repair #12
In my experience with my red clay here in East Texas, I always have to add a bucket, or several buckets of dirt to the ruts to make them go away. If you just work with what you have, it will always be a low area, and hold moisture that will lead to more rutting if you go through there again.
I dump the dirt, back drag it, drive over it again and again, back drag is some more in the other direction, and drive over it again and again, until it is solid.
I do the same thing when I remove a stump too.
/ Rut repair
Some of the logs were too heavy and long for the 2 horse teams and with a 4 team it was narrow in places. Also the horses got tired as it was hilly and I was able to help out and gave them some rest.
Caterpillar D6R Dozer Parts and Service Manuals (A63117)
Caterpillar D6R...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
60in Bucket Skid Steer Attachment (A61572)
60in Bucket Skid...
JOHN DEERE 6125M TRACTOR (A64280)
JOHN DEERE 6125M...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
