Trailer Size Bx 24
/ Trailer Size Bx 24 #1
tbm13
Bx24
Hey guys,
I’m excited as I have just purchased a BX24 TLB and I’m looking wondering what trailer works best without breaking the bank. I’m very familiar with tongue weight, weight distribution, strapping the tractor down. I also understand the difference between the axel, payload and gross weight. I can compare the specs on the tractor and make sure the trailer is big and strong enough. I have looked at a bunch of forums on here already. My question is can y’all please recommend the make and model trailer that works well for the Kubota BX24 TLB?
Thank you
/ Trailer Size Bx 24 #2
I think for the most part you will find out that trailers are regionally manufactured. There are some national companies but some of the best trailers are made locally. I know I wouldn't own most of the big name trailers after buying mine that was made a few miles from me. It's just immpossible to get the same quality and price.
/ Trailer Size Bx 24 #3
Generally, you're going to want a trailer that is closest to the maximum trailer that your vehicle can handle. Presumably that will be in excess of the capacity that is required for the tractor alone.
that gives you more flexibility in carrying other items, and may help in resale of the trailer down the road.
then just look at local dealers or on Craigslist
just my thoughts.....
/ Trailer Size Bx 24 #4
Nice tractor! And welcome to the Forum. (y)
Having your location in your profile helps a lot. Especially if you're looking for something local to you.
I agree with the previous posts. Local is typically best but wear old clothes so you can crawl under it check for paint and welds on the under side.
/ Trailer Size Bx 24 #5
What are you towing it with and do you have any other uses for the trailer that might sway the decision one way or the other.
You only have a ~3000lb machine. Its a little big (and harder to get balanced tongue weight) for a single axle trailer.
That pushes you to a tandem axle....and those are typically 7k trailers on the low end with ~5000-6000 lbs of payload. Which is more than plenty.
Consider if you ever plan on hauling other things like a car.
In general I'd try and avoid the mesh landscape ramps unless they are reinforced where the tires will track.
A 16' general purpose car-type trailer would be my choice.
/ Trailer Size Bx 24 #6
I've hauled my BX2200 without MMM and bucket on my little single axle without issue.
Adding the loader and a MMM and you've got a TLB, that weighs double.
It's best to go with a tandem axle 5-6k. This is normally what I use when hauling my machine with the front loader and MMM or with an implement like my flail mower.
Also make sure your vehicle is equipped with a trailer brake controller and the correct connectors.
/ Trailer Size Bx 24 #7
As others have said, the things you need to think about are:
What tow vehicle and what is the GVW on it;
Tandem axle with brakes;
Location of tie down points, Can you add E-track?
The friend I bought my tractor set up from, opted for a fairly long, 24-ft, trailer. That allowed him to load implements in front of the tractor if he was taking it somewhere. Longer trailers are easier to back, but take a lot more room to do it in.
Look for used trailers if you don’t mind doing a little work, there are some real deals.
My friend got the trailer dirt cheap, at an auction, because the masonry company that had owned it had overloaded it enough to de-arc the springs, and the wooden deck was worn out. We stripped it down, and he bought new decking from a local mill, and while we had it stripped down, we repainted it with a rust converting primer and a couple of catalyzed color coats, and then re-wired it and installed new LED lights. He figured out that the axles were bent, and bought new 3500-lb axles with brakes on both of them. He ended up with an equipment trailer that is far nicer than any he saw when he shopped for new ones.
/ Trailer Size Bx 24 #8
I haul my '24 on a 16' tandem ramp trailer built by Tuff Trailer locally. Tow it with half ton Silverado and it does a fine job.
I'm a minority of 1 I suspect but I prefer hydraulic surge disc brakes on my boat and tractor trailers. Had the 'Tuff built that way and don't regret it.
Enjoy that new machine,
Z.
/ Trailer Size Bx 24 #9
I have a BX, and bought a 20' trailer to haul it with 2 3500 lbs axles. The trailer is a good match for my half ton truck, and will max out my truck's capabilities.
I built removable side planks which have turned out to be VERY much so appreciated and I hardly remove them now.
20' is by no means too much. Even with a small tractor it doesn't take long to fill it out. I find myself loading up and hauling the loader bucket and my 42" forks, box blade, now I've bought a landscape rake that I can see myself also needing to take ok occasion. If the tow vehicle can handle it and you can afford it at the time of purchase, the extra length is nice!
I was actually shopping for a trailer first for other (non tractor) needs, so I knew exactly what I wanted in a trailer. Just wound up with a tractor too.
It's built by a local outfit "Hudson Brothers" that is a well known and respected trailer manufacturer in these parts.
Thank you guys very much!
/ Trailer Size Bx 24 #11
I use a 14' aluminum trailer. 5k capacity for my BX25. It has brakes.
/ Trailer Size Bx 24 #12
Review the tow abilities of your truck or tow vehicle. I think getting any trailer that is smaller than tandem 18 or 20 ft will seem like a mistake in a few short years. This size will also tow well and back much easier.
But reguardless of what you get, look at the local market - trailers seem harder to find during the last 2 years. I highly recommend buying from a company who uses only certified welders. Become familiar with accessories that can be used with a triler - set back Jack, ramp storage, or tilt bed. spare tire mount, and brakes that are required in your states. Best Wishes.
/ Trailer Size Bx 24 #13
This may not apply to trucks, but it is something to consider. I was going to add a hitch to my SUV. Internet searches came up with 2,000lbs. Only one place mentioned that the 2,000lb rating was only if the trailer had brakes. Without brakes the limit was 1,500lbs. That was confirmed when I actually looked at the owners manual.
So, review your tow capabilities, but make sure you use the right source and look for footnotes.
In many case the amount of weight towed isn't the problem, it is the stopping.
Doug in SW IA
/ Trailer Size Bx 24 #14
Any trailer that the OP is looking at should have brakes. I definitely wouldn't shop for a trailer to haul a tractor that doesn't have any.
I've never seen a rating given for my truck to tow an amount without brakes, but I do think there is a law that trailers over 3,000 (or something thereabouts) must have brakes. That should suffice.
/ Trailer Size Bx 24 #15
One or two states I believe are 1,500lbs to have brakes.
I actually installed brakes on my small 2,000lb trailer. It stops so nice.
/ Trailer Size Bx 24 #16
I'm in the same boat as mewmaxowner.... after going through several trailers I finally bought a 20' 10K Kaufman for my BX. Tow vehicle is a 1/2 ton GMC rated for just under 10K.
The additional deck space has come in handy... I mounted a toolbox at the front of the trailer that holds ratchet straps, binders and chains. With FEL and brushog the tractor pretty much takes up all of the deck space... with just enough room to load balance. That 20' trailer also comes in handy a couple times a year doing double duty as car hauler to get family vehicles to the mechanic.
Do I lose some weight capacity with a heavier trailer? Without a doubt, and I'm not necessarily advocating everyone overbuy on trailer weight ratings. Everyone's needs and preferences are different. However, and this is a huge thing for me, that 10K Kaufman pulls like a dream compared to the lighter and shorter trailers that I previously owned.
/ Trailer Size Bx 24 #17
Nothing against a 20' trailer, if I could fit it in my available space. My 16 can handle my BX24 w/FEL and Hog - with the tail wheel just hanging over the end. Weight is perfectly balanced.
Put a trapeziod tool box on the triangle tongue with enough room for all my tractor-related clobber, and fabricated a spare tire holder that sits between that and the trailer deck.
Just some alternatives for those of us who can only aspire to a bigger rig ;)
Z.
