Looking4new
Super Star Member
- Joined
- Apr 8, 2012
- Messages
- 10,290
- Location
- Northern Ontario, Canada
- Tractor
- 2012 Kioti CK27HST w/cab
2013 Dodge Journey Crew (Canadian package) came with block heater. I won't have a vehicle that doesn't have a block heater. I have the heater plugged into a remote so I can turn it on or off from the nice warm kitchen.What kind of car do you have?
Did the block heater come with it, or is it aftermarket?
Remote start is a huge bonus.
The Kioti has a block heater as well and set up the same as the Dodge, just no remote start. I only let the Kioti run at 1400 rpm for about 5 minutes before I start working it. It takes another 5 minutes of warming the hydraulics by raising and lowering the loader while flexing the dump/curl cylinders.
The remotes for the block heaters will handle 1,500 watts, so they do okay with 1,000 watt block heaters. I NEVER run both block heaters at the same time (would blow the breaker as they are both on the same circuit).
probably
