Tractors and wood! Show your pics
/ Tractors and wood! Show your pics #19,561
Safety glasses or nothing in my book are the answers neither of them mess with your vision well sighting in either like screen does.
I've not really had an issue with the screen on my forestry helmet messing with my vision.
Wearing no eye protection just is not an option for me. I remember when I started as a shift supervisor in the wire mill back in 1986. I had been working in that position for about 3 months and knew everyone in the department fairly well. That day, I noticed a guy I did not recognize running one of our rolling mills. He obviously knew what he was doing, so he was not new. I asked someone who it was. "Oh, that's Bill. He's worked here for 30 years, most of them on that machine. He was out for eye surgery, and just got released to come back to work. They thought he might lose sight in that eye, but he says he can still see fairly good out of it." Bill later told me that he had injured his eye while grinding on a butt weld used to join the end of one coil of wire onto another. That day, a hot spark got into his eye. From there, our conversation went something like this:
Me: Maybe wearing your safety glasses over your eyes rather than on the top of your head (as he had them at the moment) might reduce the chances of it happening again.
Bill: I've been doing this a dozen or more times a day for 35 years without a problem. I know to aim the sparks away from me. I'll be fine. Besides, the glasses are all scratched up and hard to see through.
Me: On the day the accident happened, did you get up and say "I'm going to have an accident today"?
Bill: No. How the $*#! would I know that?
Me: No one plans to have an accident. They just happen. They happen to the new kids or the guys with decades of experience. If you want to be able to read your grandkid a bedtime story or watch him play football when he gets a little older, put your glasses on. I'll go get you a new pair, but use those until I get back.
Bill: [grumbles and puts the glasses on]
A week or two later, there he is grinding way with his glasses on top of his head. I remind him. He puts them back on. A few months later, he misses a few days due to another eye injury - fortunately, not nearly as bad as the first one. He just needed to get the little crumb of metal out and let the scratches on his eye heal up a bit. His glasses were on top of his head at the time. On his first day back as he prepares to start up his machine, I walk up to him. Before I can say a thing, he comes out with: "I know, I know! Put my glasses on. 35 years without a problem, and then twice within a few months of each other. You jinxed me! I get it, I'll wear my glasses. I guess 'the man upstairs' is trying to end me a message."
I think of Bill when I'm tempted to make "just a couple cuts" without putting my safety gear on, or make that one last cut after I've already thrown my chaps and helmet back in the truck.
/ Tractors and wood! Show your pics #19,562
I recall reading something in The Morther Earth News in the early 80's as it pertains to splits. With the testing they did with the same species (I forget which), they calculated that the most efficient burns were to be had with 6" splits.
Good for drying and good for lasting burns.
Ever since, that's what I've attempted to do.
Seems to work.
I try to keep everything that size or smaller, occasionally one gets by quality control. I usually run the 4 way wedge on the splitter with it so the horizontals are lower, then I take the top 2 pieces and split them again, this gets me a good mix of small and large splits. I like th elarger ones for the over-nights. My stove was made by a local guy, a guy down the road also, although his is larger. Its all heavy steel with a layer of firebrick in the bottom. The door is 1/2" thick with 2 air inlet/dials. I cemented the top one shut because it tends to blow smoke.
/ Tractors and wood! Show your pics #19,563
Typing that last story about Bill and his eye injury reminded me:
A couple of days ago, I was out on the far end of my property doing some Crop Tree Release. (Starting on the first of four 3+ acre plots under an EQIP cost sharing grant I was awarded.) I got a reminder of why I wear a hardhat.
I was dropping one of the cull trees in a crowded area. I had only one choice of which direction to drop the tree: the other sides and back were surrounded by the tree I wished to keep. Fortunately, the limbs were not tangled in each other, so it should be a clean fall. It did have to barely brush through the top of another tree. No danger of damaging the tree, and that one was going to come down anyway, so I was not concerned there. The tree I was working on had back lean, so I made my notch, bored in to set the hinge, came most of the way back out and tapped in my wedge. Then I cut the last of the trigger wood. As expected, the tree settle back on the wedge.
I took another look up, all looked clear, so I tapped the wedge in. The wedge was about halfway in and the tree just started to move on its own. I backed off along my planned escape path as the tree started to fall. Suddenly, I felt a THWACK on my helmet and one of the hearing protectors popped off. I continued retreating.
When all had settled, I looked around. As near as I can tell, in that other tree whose top I needed to "barely brush through", there was a dead limb (hard to tell from the ground in the winter). As it brushed through, it must have bent the dead limb then flung it back toward me. The odds of it flying through the air from the far side of the tree I was working on and hitting my helmet as I retreated from the tree were slim, but it happened. I was probably about 15 feet from the stump when it made contact. A solid hit to my helmet, but nothing touched the rest of me at all.
That helmet is getting old. There are no cracks, but in a commercial setting, per OSHA requirements you are supposed to replace a helmet after 5 years or when it takes a good hit. This hit was not much - not eough to make me consider throwing out a new helmet, and I'm not working commercially, so probably have far less UV degradation on this helmet, but it is getting rather old. So it's time. When the forest talks, I listen. I bought a new helmet yesterday.
/ Tractors and wood! Show your pics #19,564
/ Tractors and wood! Show your pics #19,565
What did you get? I bought a Husqvarna ventilated one a couple years ago, love it!
Older version of this one I believe
/ Tractors and wood! Show your pics #19,566
I do not like wearing any safety equipment, aside from glasses & hearing protection. I would wear the glasses anyway if it was sunny or if there is snow on the ground. The glare hurts my eyes almost instantly. I also wear contact lenses, so any dust or chips is harder to get back out of my eyes. Yes I should know better, & I have full Husqvarna chaps & helmet with "ear goggles" and face screen, but most of the time I just forget. I also don't like gloves when I am sawing, I like the instant feedback of the saw cut, the gloves mute that too much. So in 2022 I will make a conscious effort to wear my helmet (new still in box) and my chaps, (only worn once maybe), but you won't get me to wear gloves while cutting, not going to do it!!
/ Tractors and wood! Show your pics #19,567
Years ago my buddy and I were cutting hardwood on my woodlot. He felled a large maple with a large crown and it lodged at a 20 degree or so angle. We were well back to each side of the stump. It didn't appear to want to go down so we walked to the stump to discuss it, the cut tree leaning away from us. I guess we stood there for a minute or so when the tree snapped and cracked and fell on its own. And then a big limb six inches across fell from the sky, brushed my buddy's shoulder and right arm, knocked the saw from his hand and broke his foot. Right beside me. Could tell the limb was ripped off the stem of the cut tree. Never knew if it was dangling from a neighbour tree or was flung back when the tree started to fall.
/ Tractors and wood! Show your pics #19,569
I make a conscious effort to wear mine too
gg
/ Tractors and wood! Show your pics #19,573
I wear cutting pants. For you guys who wear chaps are they better? My pants give good protection but maybe chaps are cooler in warm weather?
I used to have both. I "grew out" of my cutting pants years ago and gave them to my brother. I've been wearing my full wrap chaps ever since. Some modern cutting pants are cooler than wearing chaps over pants (especially full wrap chaps). Of course with chaps, you can take them off or at least unbuckle the legs when you stop for a break (not that I usually bother).
I've been debating buying a pair of Pfanner Gladiator Ventilation pants for warmer weather work. They are expensive, and no one in my area carries them. If I could try some on for size first, I'd probably already own a pair. I'm hoping someone will show up at a trade show with some so I can try them.
/ Tractors and wood! Show your pics #19,574
Normally see chaps of some sort here either internal or external ones with a set of double knee logger jeans. We don’t see the European style gear out here unless it’s a power line arborist crew that never spent time in the brush. A good set of internals are what most guys wear being you can’t get hung up as easily as the external ones and the few that have tried the pants normally don’t say much about them, or they’re still required to wear a set of chaps either way.
/ Tractors and wood! Show your pics #19,575
I had pants years ago... they were in my packbasket of work gear which somebody stole. :( The beauty of chaps to me is that in hot weather you can take them off to get cooled down, and it's much easier to put them on when using the saw intermittently; say, to cut a tree out of the road. I have considered pants though, and probably will buy a pair if I ever start using a saw seriously again.
One thing which I DON'T recommend is the removable pads which slip down down into a sleeve in the pants. https://www.labonville.com/shop/lab...w-snaps-sp500kp-49917?category=639#attr=12686
It seems like a good concept; buy a pair of pants for summer and another for winter, and switch the pads back and forth. I didn't like them because the pads didn't always stay in place, and I never felt they'd be there if I messed up.
/ Tractors and wood! Show your pics #19,576
I good set of internals are hard to beat, they button into the jeans and there’s very few made that actually do this.
/ Tractors and wood! Show your pics #19,577
I tried on a pair at a logging expo years ago. I can't remember what the brand was. I did not like them at all. They just didn't seem to provide the protection of either my full wrap chaps or the pants I had at the time with the permanently installed chainsaw protection. It felt as though it would be far too easy for the pants to spin on my leg and move the protection out of place. I have never hit any pair of chaps or pants with a running chainsaw, but I just was not comfortable those would do the job if it ever did happen. Maybe I just found a bad brand, or maybe they would work if I actually tried them in the woods. I just was not comfortable experimenting.
/ Tractors and wood! Show your pics #19,578
That was my experience as well. I wear the black Labonville pants all winter which are designed for the pads and thought they would be a good idea; but they didn't seem to stay where they should.
/ Tractors and wood! Show your pics #19,579
Good to know what you think of those Labonville pants jstpssng. I look at them and they look good as you said.
gg
/ Tractors and wood! Show your pics #19,580
This is the norm out here even in the wet, wonder if the labonville pants allow more sliding vs jeans.
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59906)
2022 KAUFMAN 4X2 2...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2020 CATERPILLAR 289D3 SKID STEER (A62129)
2020 CATERPILLAR...
