Cordless Tools vs. Other Options
/ Cordless Tools vs. Other Options #121
I have several battery powered Makita Drills. Batteries cost more than a Drill. However, they never fail to drill 1-1/2 holes before they are dead.
/ Cordless Tools vs. Other Options #122
My next 3D print task
/ Cordless Tools vs. Other Options #123
Lots of low priced replacement batteries on the web for Makita but very rare for DeWalt.
I was aware that DeWalt monitored web sites for discount batteries and presume issued cease/desist warnings.
To charge a battery you always do so at a voltage slightly higher than the nominal voltage , I.E. use 20 to charge 18.
Even a car 12 volt battery is charged at 13-14 volts.
Now a freshly charged battery will briefly read the voltage used for charging, I.E. 18 will briefly read 20.
While not totally false it is good advertising hype.
/ Cordless Tools vs. Other Options #124
I still use my over 20 year old DeWalt 12V Drill and have bought couple of used spares dirt cheap from eBay vendors.
It's terribly outdated but still works fine for light duty work, and new non-OEM batteries are cheap.
Yes I know you get what you pay for, but they are OK for me for now....
When more juice is needed I use my Milwaukee 1/2" corded drill, or Craftsman or even old Black & Decker from the 70's.
/ Cordless Tools vs. Other Options #125
Yes I know you get what you pay for, but they still work fine for me for now....
Raleigh, NC had a Dewalt shop that rebuilt all my 18V dewalt tools. They were like new. I gave them to a young friend starting out in business. They were solid tools
/ Cordless Tools vs. Other Options #126
Aftermarket batterys were sure were poor X years ago, like 15 years ago I tried them and most failed asap for DeWalt tools. But seems today they have improved on them and I'd buy the them is they have lots of good reviews. I've been swticing over to Makita. No aftermarket ones being build for them?
/ Cordless Tools vs. Other Options #128
Are you peddling tools?
i use Milwaukee cordless. Best ones i have owned - so far…
/ Cordless Tools vs. Other Options #131
I have one of these too a 1995-96 vintage, after two sets of batteries I decided to upgrade to Li. Interesting no one mentions Bosch Li tools. I started buying Bosch sets on CPO tools about 5 years ago on Black Friday and Xmas specials. Now have a dozen different Bosch LI 12V and 18V tools between house and barn. They have held up well, although as others have said, the Circular saw and Sawzall seem to run down batteries 2X faster than the 1/2" impact or drills do.
/ Cordless Tools vs. Other Options #132
I contracted for Hyster-Yale for a couple of years. The mechanics all agreed that Makita was by far the best cordless tool in regards to durability and toughness. I guess they would know better than I and wish I had them but it is impossible to change over without spending a lot and what I have works fine. I do lose batteries every few years but not sure if it is in part my fault or not.
/ Cordless Tools vs. Other Options #133
I followed the whole thread, am amazed that no one mentioned RYOBI TOOLS.
I had over a dozen Dewalt tools and batteries. Burned out tools and had dead batteries all the time. RYOBI had some good deals at HD since I was sick of paying thru the nose for Dewalt thought I'd give them a try. I liked it and you can't beat the bang for the buck, especially after I found out about DIRECT TOOL OUTLET on line. You can buy new, factory blemished, factory refurbished, all with warranties and some times at 50% savings from list.
Other good thing about Ryobi and Direct tools is they make a bunch of tools that HD doesn't normally carry but you can get on line at Direct tools.
What i like is my Ryobi tools and batteries hAVE LASTED MUCH LONGER THAN DEWALT AT SIGNIFICANTLY LESS COST.!!
Another feature Ryobi has are multi chargers, 6 holes for any amp hour Ryobi battery, with automatic charge maintainer and USB ports for your phone or lap top and with a carry handle so you can pick up 6 fully charged batteries and go to work!!
BTW for you rigid guys, Rigid is made by Ryobi.
/ Cordless Tools vs. Other Options #135
That's interesting. I did just the opposite. Ryobi doesn't make some of the portable tools that DeWalt has. I still have my small Ryobi Tek4 tools though.
I guess it all depends on your individual needs and preferences.
/ Cordless Tools vs. Other Options #136
Ryobi burnt me a good while back on their 12v line and I won't buy another. I too still have dewalt 12v that I've gotten a decade of use out of. I need to replace as batteries are well past good use. Probably Milwaukee.... Mostly made in US
/ Cordless Tools vs. Other Options #137
Nobody has mentioned the Milwaukee M28 line of heavy duty portable tools. I bought their complete kit - except for bandsaw - back about 2010 and they are amazing. LOTS and Lots of power. Really good design and chucks. Li Batteries still a decent charge too. We still use them everyday.
rScotty
/ Cordless Tools vs. Other Options #138
When I put a battery tool away I check the battery level and if its less than full the battery goes on the charger. If you do that you'll always have a full or nearly full battery to start your next job with.
Do lithium batteries not have a memory? The old wisdom used to be not to charge until the battery is drained.
/ Cordless Tools vs. Other Options #139
no they don't, actually you don't want to leave them at bottom or at top for long periods of time. Only Nicad had memory
/ Cordless Tools vs. Other Options #140
The don't seem to have a memory, but they do lose some capacity after being charged over a thousand times. I've had some of the Milwaukee M28s for close to ten years now. I charge them when they are below 75% before going out on a job - so probably several times a week.
After ten years and a thousand charges they are still useful, but they don't last as long as they did when new.
I usually take two batteries when going up on a roof or something like that....but then I always did......
Bobcat 873 (A55272)
Bobcat 873 (A55272)
2024 Blue Diamond Skid Steer Vibratory Roller (A63116)
2024 Blue Diamond...
(INOP) JOHN DEERE 5055E TRACTOR (A62130)
(INOP) JOHN DEERE...
iDrive TDS-2010H...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
