Electrical
   / Electrical #12
It is funny but worth considering. Look for frayed and gnawed on wires.
   / Electrical #13
Hmm,,, maybe wire manufacturers could add a delectable dose of warfarin to the recipe?
   / Electrical #15
That or stop using soy (food) based insulation.
Is that really what the insulation is made from? I don't have the slightest idea myself but am curious how you know.
rScotty
   / Electrical #16
I was aware they used soy oil in the machines that add the insulation to lube things. I was not aware the insulation was a soy based material.
   / Electrical #18
"Shotgunning" will eventually fix the problem. Sooner or later you will stumble over the actual problem, in your quest to replace your tractor, one part at a time.
That's what the "technicians" at my local Chev dealership do. They just keep throwing parts at it until it's fixed. And OH by-the-way, they leave the parts in that didn't fix it and charge me for it.
Oh for the days when there were real mechanics instead of part replacers.
   / Electrical #19
   / Electrical #20
Its a good idea to first check your wiring
connections before buying parts.
You should always check your manual
in the problem section if you have one is
the first place to start because most of
the time all answers are there for what
you should check or where to start first!
willy
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2019 INTERNATIONAL...
2004 John Deere 4720 (A60462)
2004 John Deere...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
1998 PETERBILT 377 MIDROOF SLEEPER (A58214)
1998 PETERBILT 377...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
