Machinewars
Member
I’m practicing mig welding and would like to weld some hooks on my bucket. Can I mig weld hooks on? Will mig welds provide a strong enough bond?
Applies to gasless. Add shielding gas and the spatter (and grinding) is greatly reduced. I suggest in investing in a needle scaler, makes removing spatter much less invasive and removes weld dross as well.Being a novice welder has vastly improved my grinding skills.
What thickness of material vs wire gauge is important. .035 wire best but .030 might also.I’m practicing mig welding and would like to weld some hooks on my bucket. Can I mig weld hooks on? Will mig welds provide a strong enough bond?
.035 solid wire is too heavy for a 115 volt machine like a Hobart Handler 140. .023 or .025 wire will actually penetrate better. For flux core .030 or .035 is fine. How thick is the bucket where the hook is going to welded? My bucket was only about 1/16 thick where I wanted to weld the hooks so I welded large 1/4 plates to the bucket and then welded the hooks to the plates.What thickness of material vs wire gauge is important. .035 wire best but .030 might also.
I would not weld with .025
As someone else said, you can check the charts to see what your welder is capable of.
Your welder has the capability to do this job. I can not answer the "I" part.I’m practicing mig welding and would like to weld some hooks on my bucket. Can I mig weld hooks on? Will mig welds provide a strong enough bond?
Yep. I burn .035 with my Miller 250..035 solid wire is too heavy for a 115 volt machine like a Hobart Handler 140. .023 or .025 wire will actually penetrate better. For flux core .030 or .035 is fine. How thick is the bucket where the hook is going to welded? My bucket was only about 1/16 thick where I wanted to weld the hooks so I welded large 1/4 plates to the bucket and then welded the hooks to the plates.
Eric
The HH 140 is a 120v machine and will handle .030 solid wire and C25 quite well... I use .030 almost exclusively with mine...Yep. I burn .035 with my Miller 250.
DC welder for starters, 7018 or 7014 are easier to make pretty welds not needing any grinding. Good auto-darkening helmet so you can get a good start and watch that puddle.I have a stick welder. Maybe weld twice a year on small projects. Getting proficient welds but not the prettiest. Thus the grinder.
