Welding Bucket Hooks!
/ Welding Bucket Hooks! #81
Etch said:
Thanks for the tips and suggestions guys. I'm thrilled to have a welder and I was thinking of taking a class to get the basics down. I know it will take practice. I do play musical instruments, so I can relate to what you all are saying. I know I won't be making great welds in the beginning.
Too bad you guys aren't in San Antonio. I'd hire you to weld my hooks on.
Go to the Hobart welding forums hobartwelders.com, there is a guy from Bulverde that might be able to help, his user name is dda52.
/ Welding Bucket Hooks! #82
Thanks wushaw. I contacted him and he was ready to come out tomorrow night, but I don't even have the hooks yet..lol.
/ Welding Bucket Hooks! #83
As a hobbist welder, I really improved my welds by using fresh rods. What a difference! My old rods were exposed to ambient air in my shop for years and were difficult to start and run a good consistent bead. I bought some new rods and shezzam.........nice beads and good penetration to boot.
I bought some HF rod containers and store my rods in them and only remove what I know I'll use up right away. After reading this entire thread, I thought this important tip would be helpful to other "nubbie" welders.
/ Welding Bucket Hooks! #84
Hey Cap, Don't trash those old rods that don't work so well unless they are actually contaminated with oil or something that won't evaporate away. They just need to be properly dried out by low temp baking and then stored in an air tight container like you are doing with more recent "new" rods.
I buy my most frequently used size and type rods in 50lb boxes for economy and the lesser used ones in 5-10 lb. The 50's come in a plain not waterproof cardboard box. If stored where they can absorb moisture they will but just need to be properly dried and put in a sealed storage container. The containers at HF are OK but I bought some military surplus mortar round containers. They have a twist off lid that requires only a partial turn to open and have a good O ring seal to keep out the moisture carrying air.
Folks with serious intent in welding use rod ovens to dry/store rods. Low hydrogen rods like 7018 need to be baked out at much higher temps than the 60 series like the popular 6011,13.
Serious (well informed and expert) welding shops store their rod in thermostatically controlled ovens.
Home brew ovens are easy, especially for the 60 series rods which don't require very high temps. Some shops use an old refrigerator (with metal shelves so they don't soften and sag) and a light bulb as heat source with an easily procured thermostat to store a fairly large quantity of rod.
A couple sheet metal boxes, one inside the other with fiberglass insulation and a thermostat controlled heater (or light bulb) works. Light bulbs work OK for heaters but aren't the longest lasting solution. There are lots of other choices. There are things made and sold for gun cabinets, yachting use, ceramic cores with heater wire wrapped on them which have a light bulb type male thread to fit a porcelain "porch light" socket.
Pat
/ Welding Bucket Hooks! #85
xlr82v2 said:
Thanks!
When I watched the video for the first time, I was suprised at how my face (the helmet) was right in the fume plume (;)) as well. That was the first time I've seen myself weld.
However, although I could smell the fumes, very little was coming inside the hood... I never felt that they were overwhelming or annoying at any time... as you see in the video, they are convecting upwards, around the hood, and keep going upward... inside the hood is fairly fresh air. I certainly inhaled more smoke and fumes after I lifted the hood than I did while welding, no doubt about it!
I mostly tig weld but when I stick or flux core, I use a half mask with pink filters that are very flat and will fit under the welding helmet. Google 3m half mask. By the way, I'm gonna put some hooks on my BX24 and use your method. Thanks.
/ Welding Bucket Hooks! #86
I just noticed this thread so I will put in my two cents worth a few times and maybe go for a dimes worth.
1. Welding hooks I did not see anyone mention that you can buy weld on hooks made for welding to things they are a hook with a flat side that makes it easy to weld. I got mine pretty inexpensively from a tow truck supply company. I dont remember the name of it but someone from TBN suggested it so you can probably do a search and find it.
2. I noticed someone asking patg about a hardoned surface and he mentioned hardening rods. You can also get a wire for wire feed welders that will allow you to surface harden things. I have seen it available but it is a bit pricey. I have a friend that sharpened the blades on his brushhog then ran a bead over them with a hardening rod and he said it was amazing how much of a difference that made.
3. Duty cycle- my welder has something like a 40 per cent duty cycle at the maximum rated amerage of 175 amps. When I looked at the specs you only have to come down a few amps. Something like maybe 150 and then it was showing 95 per cent. I have found that I have only used the maximum setting on my welder one time.
I realize that is only 6 cents worth but there will be other threads :)
/ Welding Bucket Hooks! #87
I just bought some weldable hooks from Truckntow. They're called pelican hooks. It was posted in another bucket hooks thread.
You can also just short circuit the rod to your workpiece until it gets hot enough to "steam out" the coating. Takes just a couple of seconds, and works pretty well. Realize that, none of us here are making X-ray quality work, this is just "hobby" welding. Anyone out there doing X-ray quality welding will realize that short circuiting will not properly dry the rod to meet X-ray spec.
The 60 series rods and non-"low hydrogen" rods do not require the same meticulous care in keeping them dry... they are actually designed to be used with some amount of moisture in the coatings, and using them while too dry will actually impair their performance.
/ Welding Bucket Hooks! #89
You can find them here too. Just do a search for weld on hooks. McMaster-Carr
/ Welding Bucket Hooks! #90
Right on, 60 series have recommended storage temperatures for long time storage in a drying oven which are significantly lower than for low hydrogen rods like 7018. Still, the major rod makers have storage oven temperature specs for their 60 series rod.
Can you direct me to a reference where the need for moisture in a 60 series rod is given by competent authority?
Pat
/ Welding Bucket Hooks! #91
real nice job, Brian.
I'm in the process of choosing a new small tractor. I just went to the hardware store and picked up a couple of 3/8" grab hooks so that when I make the final choice I plan on handing the dealer that pair of grab hooks and saying,"Weld these on the front bucket and deliver this thing." I see that you have provided one in the middle as well. Now I have to go back to the hardware store and fork over another $3.69 for one in the middle. I hope, for my sake you now have enough. (BIG GRIN)
I have a question for you. Do you think it's necessary to grind the back of the grab hooks flat and remove the hole? I realize it makes for a nice base but if one were to weld on a hook would not the weld fill in any deviation enough to make a substantial point of connection. I can see the obvious case for extra strength but was just wondering if it would be wrong to leave the 3/8 grab hook in it's entirety hold in at the right angle and fasten it by welding a good bead at each contact point?
Good job.
rim
/ Welding Bucket Hooks! #93
/ Welding Bucket Hooks! #94
edownr said:
Another source for weld-on grab hooks, grade 40 and 70 is AWDirect in Berlin, CT. You can order online at AW Direct Towing Recovery Service Vehicle and Wrecker Accessories - 1-800-243-3194 or by phone at 800-828-9678.
They specialize in towing accessories and have many, many items that are hard to find elsewhere.
I am not associated with AWDirect, just a happy customer!
Larry
Edownr Thank you for this post. I was trying to remember their name. I bought mine at AWDIRECT and I am very satisfied with their prices and their service.
/ Welding Bucket Hooks! #95
I was just going to post that link to AW Direct but Larry beat me to it. I get most of my towing stuff from them.
I also got a deal on 10 weld on hooks on FleaBay for a fraction of the cost. There are deals to be had, just have to look for them.
/ Welding Bucket Hooks! #96
I put on some extra hooks last year. after my double passes i realized they were on backwards oops. still havnt fixed them yet. can i have a few of yours. lol. bill
/ Welding Bucket Hooks! #97
And the steel in their weld on hooks is good stuff. No monkeying around grinding hooks to fit flat..etc..etc. Definately a "must have" for a FEL
/ Welding Bucket Hooks! #98
Not to throw a wet blanket on this whole thread:
I really would like to warn everyone about using welding equipment inside a wooden building within the proximity of exposed wood or other flammable material. I know a lot of people do it. But, no matter how many time its done, it is still not a good idea.
This has been a public service announcement.
In keeping with my newly established general policy in my threads...
Safety Patrol is not allowed!!!
That is not to say that Members of the Safety Patrol are not allowed to post or contribute... but you must take off your hat, badge and boots and leave them at the door before you come in. Being a normal everyday person is prerequisite.
:D:D:D:D:D:D (but I'm NOT kidding.)
We are all adults here, and we don't need a bunch of preaching by a bunch of phobic busybodies...
Sorry to be so blunt, but I'm just getting dang tired of it around here...
/ Welding Bucket Hooks! #100
Sorry:( , I knew it would not be appreciated by some, but it is due to my experiences. When I see that, it is like seeing some when standing on the tracks with a train approaching and I can't help it.
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2022 EZ-GO ELITE...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
