Rim guard or not? Why a ballast box instead of boxblade?
   / Rim guard or not? Why a ballast box instead of boxblade? #51
The only time my ballast barrel isn't on the tractor is when I'm brushogging. I poured concrete in a 55 gal barrel and left it down about 4'' so I have room for 2 or 3 chains with me all the time. There is also a place for shovel,rake,chainsaw and gas &oil. Also have a receiver hitch. It's tucked in tight so I never run into anything so why take it off.
Jeff
   / Rim guard or not? Why a ballast box instead of boxblade? #52
I have only used a box blade for loader ballast so far because my tractor is so small that a 60" BB provides enough counterweight to max out the stock loader hydraulics.. until i crank them up anyway.
It does present some maneuverability issues, and i intend to fill the rear tires and MIGHT build a dedicated ballast.. but if i do i am thinking it will be a ~30 gal plastic barrel full of sand, because the things i might run into are things i care about.
I do really like seeing all the other uses people build into their weight boxes!
   / Rim guard or not? Why a ballast box instead of boxblade? #53
I used a box blade here for a while and for many years elsewhere. Heavy Hitch began to appeal to me because it had weight and a receiver hitch, plus I could use a ripper in the receiver.
What I found was that the hitch felt much less in the way, felt very compact, and was heavier than my blade. I'd never used anything but an implement, but here all my spaces are so tight.
I have a Heavy Hitch with about 250lbs of suitcase weights, so ~300lbs total, and since it functions as a hitch I guess it's a degree more functional than a ballast box. To remove it I can easily lift each suitcase weight off and then the hitch itself, so that's handy. The HH wasn't cheap, but it does seem to be made very well, and as you mentioned it's compact - good counterweight and I almost forget it's back there.
   / Rim guard or not? Why a ballast box instead of boxblade? #54
Even if you added weight to your box blade, it would be less maneuverable in small spaces than a ballast box. That may be why some do it.
If I remember physics correctly, and that is a big if, having weight further back is better than closer to the fulcrum. That would support using a box blade or cutter as counterweight versus a ballast box.
In my situation, I will load the tires and keep the RC on most of the time. No lawn to mow, just brush, so too much weight should not be an issue.
Your PHYSICS thought is correct however the wording is questionable.
   / Rim guard or not? Why a ballast box instead of boxblade? #55
I use a box scraper with added steel plates on for weight and a shelf ontop for my chainsaw, chains for yarding logs etc. A ballast box unless empty to carry things in for me is useless. I also put tubes in and fill my rear tires with calcium.
   / Rim guard or not? Why a ballast box instead of boxblade? #56
I use a ballast box because it came with the tractor when I bought it. I attached a hitch to it to move trailers and other things around. I don’t mow with mine and I use a 3pt blade to fix the driveway
   / Rim guard or not? Why a ballast box instead of boxblade? #57
Biggest advantage of a ballast box is a lot of weight in a comparatively compact size.
I've got a Deere brand box I've had for years, along with 600-700 lbs. of sand that was in it when I bought it.
Although I haven't had need of it since moving to Vermont (2012), I'll keep it
Some guys use implements like rotary cutters, rear blades (which aren't really that heavy) and such. For loader work, one wants to concentrate on the loader, not what's on the 3PH, especially in close quarters.
   / Rim guard or not? Why a ballast box instead of boxblade? #58
I'm a little cheap when it comes to a ballast box, because then it has to be filled with something and doesn't move around easily unless you put a furniture dolly underneath when you take it off, I was at a auction and bought those weights that are used for calibrating scales, they weigh 50lbs each bought 6 @8 dollars a piece, used 5, slid my draw bar through the center and attached it to my quick hitch which weighs 75lbs, now I have 325 lbs of counter weight for my 6ft. snow blade.
   / Rim guard or not? Why a ballast box instead of boxblade? #59
.. doesn't move around easily unless you put a furniture dolly underneath when you take it off...
Yep, furniture dollies are useful tools, if you have a concrete floor. My box has been on a furniture dolly since I bought the box
I thought about adding a receiver hitch, but found something like this:
Pretty handy and I used it a lot when I had a half-ton trailer back in PA.
The one I own is quite a bit stronger (robust) then the one shown in the link....made for larger tractors
Always regretted I left that trailer when we moved to VT...
   / Rim guard or not? Why a ballast box instead of boxblade? #60
A box blade really isn’t heavy enough for sufficient ballast on its own without liquid tires or iron weights.
My BB weighs 1100-1200 lbs. I have 1500 lbs of rear tire fluid. I'm guessing the BB hanging off the 3pt adds more weight than the fluid. But I'm not going to take the time to mathematically prove it. :)
3Pt 4' Harrow (A59814)
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A59230)
2004 Pierce Tilt...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
