rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,735
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
It's not right. Diesels are harder to start in cold weather, but not as hard as you describe.
I'd say on a near new tractor if you are leaving the block heater on all night - and you said it is working - then you aren't having trouble starting a cold engine, you are having trouble starting a warm one.
You also said it cranks fast enough, so about the only thing left is that since the engine is warm the glow plugs may not be coming on. You should check that.
If those things are right, I'd then check that the cylinder compression is within specs for a newish tractor - that will be a spec. in the shop manual.
And if compression is also good and it still starts that hard I'd be inclined to sell it back to the dealer. It's unlikely to get better.
rScotty
rScotty
