And you thought you knew something about nails and screws!
   / And you thought you knew something about nails and screws! #21
I'll likely use those nifty rafter screws if I build a new house. I'd love to be able to rent one of the tools for installing them: not sure what they're called.
It’s required by code to use those or a metal bracket to accomplish the same job just about everywhere now.
   / And you thought you knew something about nails and screws! #22
These???
Simpson Strong Tie also makes good framing screws
No the ones specifically intended for anchoring trusses have a smaller head.
   / And you thought you knew something about nails and screws! #23
Yeah, I don't think I'd ever think/want to just toe-nail (minimum of brackets- just makes sense). But...
I also figure I'll be utilizing energy trusses and longer sheathing sheets (one manufacturer calls them "Tall Wall" panels). I'd think it would/should be the only way to go for high wind locations:
   / And you thought you knew something about nails and screws! #24
Interesting videos, those deckmate screws were impressive. I'd like to see the nail pull test with the nails driven at a 30 degree angle and with the old hook trick where the first 1/2 inch or so of the nail is bent so the nail curves when driven into the wood.
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
19011 (A48082)
19011 (A48082)
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2008 Ford F-250...
PALLET OF SQUEEZE OFFS (A50854)
PALLET OF SQUEEZE...
STORAGE FEES (A51219)
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
