Ballast Box
/ Ballast Box #1
Hazel
Maine
Mahindra Emax 20S HST
Hi Everyone,
I am looking for a Ballast Box for my Emax20S HST. It has the cat 1 N 3PH
Thank You,
Rick
/ Ballast Box #2
Check Amazon. I bought a Titan box last year for around $300. It’s what it is for quality. The top link pin ears were welded skewed but I can hookup ok. It definitely takes the weight as I filled up with steel.
I’ve added QH and hydraulic top link since this pic - and grooved my R4’s.
/ Ballast Box
Pokey1416,
I checked out Amazon earlier however, I was concerned that it didn’t mention limited cat 1 or cat 1 n.
do you think it will connect up ok?
not looking for you to make my decision, just your opinion…
Thanks,
Rick
/ Ballast Box #4
Rick I’m not familiar with the “n” designation. I’ve only dealt with CAT 1, CAT 2, and CAT 3.
/ Ballast Box #5
My Titan box was not QH compatible. The top link needed to be lowered and moved forward. I drilled holes in a QH adapter bracket (for brush mower) and used it to relocate top link pin
A parking stand prevents knocking it over when reconnecting
/ Ballast Box #6
I bought a cheap one on Amazon too. It said Cat 1 but came with cat 0 pins. Whatever, it works just fine on my max. I put washers on the ends with the cotter pins (lynch pins didn’t fit🤪)
/ Ballast Box
Pokey1416
limited or N (narrow) cat 1 hitch is the same:
This indicates that the hitch is lower to the ground and may not lift as high or open as wide as standard full-size category 1 hitches
Rick
/ Ballast Box
I thinking about going with the Heavy Hitch Suitcase weight Receiver…
How do you determine the necessary amount of weight needed when using the FEL?
Mahindra Emax20S HST sub Compact Tractor.
Thank You, and Merry Christmas everyone
Rick
/ Ballast Box #9
You’ll need to do a bit of math, but assume 40% of your weight on the front and 60% on the back. Generally, loaded tires/wheel weights and a ballast box or heavy implement are enough.
/ Ballast Box #10
Correct. When I had the eMax25 I made a box that held 300lbs of lead blocks. That with filled tires was great.
The new to me Max26 has a backhoe. There's my ballast. The previous owner filled the tires but I'm considering draining them.
/ Ballast Box #11
Do you ever take the backhoe off?
/ Ballast Box #13
There's a number of sources for Ballast Boxes...and consider Craigslist too (which is where I found mine, a John Deere box with 600-700 pounds of sand).
If you're not using a quickhitch, you probably won't need the Cat-1 to Cat-2 bushings. You probably will need them if you purchase a QH at some point.
/ Ballast Box #15
I’d probably leave the fluid in . Every little bit helps on those little tractors and filled tires will help with stability also
Probably correct, but if the BH owner's manual is available, it may advise against filling the rear tires
/ Ballast Box #17
Hi Everyone,
Thank You,
Rick
Hi Hazel,
I notice your location says you live in Maine.
There's a guy in Hermon who sells concrete ballast blocks with built-in 2" receiver hitches. They come in various sizes from 400-1300 lbs. and cost $250-400.
I bought the 1300lb. block for my Mahindra 4540 and really like it. My father bought a matching one for his JD after seeing mine.
He's had ads up on Craigslist for a while, but I can't find it at the moment. If you're interested message me and I'll share the guys info with you.
/ Ballast Box
Good Morning Woodstock Walt,
Thank you very much for the information however, I purchased a Heavy Hitch receiver with Suitcase Weights.
