50 Hours Maintenance Question
/ 50 Hours Maintenance Question #1
markfsanderson
New Baltimore, VA
1948 (est) Ferguson TO-20 and John Deere D100
Greetings!
As a relatively new owner of a 2021 Kioti CK3510 SE HST, I'm pleased that it is relatively easy to do monthly maintenance. I have a question regarding grease points; Does my tractor have the 'Position Control Lever Shaft Housing' ? It is mentioned as a grease point in the manual on plate 7-22 in the Owners manual. I cannot find this fitting. I noticed that it showed on the same page where the clutch pedal fitting is, and since mine doesn't have a clutch .... but does mine have a 'control lever shaft housing'? Should I assume that the HST does not have one of these?
Any help would be greatly appreciated.
Mark!
/ 50 Hours Maintenance Question #2
Position control sounds like your 3point raise/lower lever. If you follow that lever under the dashboard area do you see wire, spring, or metal connection point you can throw some grease at?
/ 50 Hours Maintenance Question #3
This from the manual [CK3510(D,H)_CK4010(D,H))-OM-ALL-161220.pdf]
/ 50 Hours Maintenance Question #4
So you are saying that's the picture but you dont actually have that when you are behind the tractor looking through your right 3PT link arm?
A picture well lit from that same spot on your tractor would be helpful. I am pretty sure you have this piece to grease.
That is correct - I'll post a picture. I haven't found a grease fitting anywhere near that spot . . . .
Mark
I'll take another peek . . . I don't remember any easily accessible spots under place where the lever shaft housing is . . .
Mark
/ 50 Hours Maintenance Question #8
That grease fitting may be only for the European models, which those models have Position and Draft control. I could be wrong though. Most manufacturers won't offer Draft control on the US market for some reason.
/ 50 Hours Maintenance Question #9
Greetings!
Mark!
I have the same tractor but from 2019 and mine has that zerk. It is at the bottom of the 3PH control lever under the tractor. I access it by ducking under the tractor in front of the right hand side rear tire. If you can't find it, I'll grab a video of where it is at on mine.
/ 50 Hours Maintenance Question #10
Hey Stan, please do the video. Thanks.....
/ 50 Hours Maintenance Question #11
I can’t find that zerk on my ck3510 either. But even if you have a HSTmodel, you do have a clutch peddle and a zerk underneath the floorboard for it.
/ 50 Hours Maintenance Question #13
When you put your tractor in low, medium or high or when you start your pto, there is a foot peddle on the left side. You also need to depress it to start. That is a clutch peddle. On the bottom of the floor panel where it has a lever it has a grease zerk.
/ 50 Hours Maintenance Question #14
Also I looked at that video but do not have the grease zerk it shows.
/ 50 Hours Maintenance Question #15
Yup, no left pedal on mine. I think I read they removed the clutch on SE models when they switched to electronic PTO engagement.
2009 IC Corporation PB105 School Bus (A68183)
2009 IC...
2018 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A69167)
2018 FREIGHTLINER...
2018 CATERPILLAR 573D FELLER BUNCHER (A65053)
2018 CATERPILLAR...
HYDRAULIC FLUID TANK (A68842)
HYDRAULIC FLUID...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
2025 Swict 66in Bucket Skid Steer Attachment (A66734)
2025 Swict 66in...
