/ Harbor Freight Tools that don't suck #14,561
/ Harbor Freight Tools that don't suck #14,562
Anyone have their rechargeable flashlights?
Bruce
/ Harbor Freight Tools that don't suck #14,563
/ Harbor Freight Tools that don't suck #14,564
Thats what i did. Coveord with a piece of 3/4 plywood to make an 18" × 42" surface.
/ Harbor Freight Tools that don't suck #14,565
Just purchased a 1/2" earthquake impact gun based on the reviews, looks very nice and it has 3 different torque settings. I will keep you posted with feedback after I use it awhile.
/ Harbor Freight Tools that don't suck #14,566
I've been using these cheap HF dollies for years:
They're rated for 1000# and at $8 apiece, are a great value. I have around a dozen that I use under small implements like FEL buckets, counterweights, pallet forks, etc. I have yet to break one.
I used two of them to make a rolling stand for my HF horizontal metal bandsaw. I also keep one of the larger ones handy for heavy moving tasks. I've gone so far as to build a fixture atop of the larger dollie to move a 600lb safe door.
They are great to have around for all kinds of tasks.
/ Harbor Freight Tools that don't suck #14,568
Which one? I just bought the closeout Earthquake Version 1 (red, cast aluminum) long nose version and it's all the power I need. Tractor lug nuts torqued then measured with a beam torque wrench: Setting #1, 110 ft lbs. Setting #2, 150 ft lbs. I didn't try #3, I don't want to rip the heads off the lugnuts. Not sure I have anything that needs setting #3. I'm sure it will dis-assemble anything I have.
Also by chance I found a HF #94802 tiny impact wrench at Goodwill for $5. I measured its two settings @ 45 and 75 ftlbs, just right for smaller bolts. It doesn't weigh much and looks like it should be a 3/8 tool but its 1/2". I found its manual, dated 2006. Its a better tool than the more recent cheap models.
/ Harbor Freight Tools that don't suck #14,569
Excellent info, mine is the same as yours except it's blue. Thanks for the torque specs I was going to do the same thing, I sometimes get into some bolts that my 1/2" craftsman just won't break loose. It was originally $169 on sale for $149.
/ Harbor Freight Tools that don't suck #14,570
Yeah. at $8@.
The coupon you linked to expired Feb 29, 2020. Now they are $13@
Buy the HAUL-MASTER 18 In. X 12 In. 1000 Lb. Capacity Hardwood Dolly (Item 63098) for $7.99 with coupon code 39334783, valid through February 29, 2020. See the coupon for details.
That was my anniversary :)
I've got about 30 or so of them and have managed to break about 2.
/edit - 30 or so moving dollies, not anniversaries :)
2007 John Deere 6615 (A60462)
2007 John Deere...
MGY Shop Heater (A60463)
MGY Shop Heater...
CAT 930M (A58214)
CAT 930M (A58214)
2005 Big Tex 14TL (A60462)
2005 Big Tex 14TL...
2006 Ford F-350 Pickup Truck, VIN # 1FTWX31P16EB57079 (A61165)
2006 Ford F-350...
AGT Industrial ExRC54 (A60463)
AGT Industrial...
