etpm
- Joined
- Jun 30, 2021
- Messages
- 2,306
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
I took the engine off of a pressure washer because it was locked up. The flywheel would rotate just a little each way and then stop dead. Figuring something bad was wrong in the engine I took the side off to look inside. It was pristine inside. Feeling foolish I looked for the real cause and it was a screw that had gotten loose and was getting jammed in the space between the flywheel and the sheet metal behind it. The screw would roll along and then get stuck. Then reversing rotation it would roll again and then again get stuck. I had to buy another crankcase gasket.
This motor had done the same thing as yours. Was running great, was shut down, and then the problem showed up next time someone tried to start it.
Since your engine cannot be hydro locked because the injectors are out, and because it rotates a little each way, makes me think that maybe a bolt or something similar has come loose and has fallen into a space that lets it move some. I'm sure it won't be easy to check, just because of how complex tractors are. Is it possible to get a look into where the clutch is? Could there be a nut or bolt sitting in the bottom of the clutch housing?
You must be going nuts trying to figure this out. I feel for you.
Good Luck,
Eric
Good Luck,
Eric
