Adding front bucket extension for more capacity?
/ Adding front bucket extension for more capacity? #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Boy, this winter is gonna have me busy working on the tractor. I have a Yanmar YM2310 with a Bulldog 285 FEL. Besides adding power steering and wheel weights I have decided it could use another upgrade. The bucket is tiny. I have a Case 580CK and the front bucket on it puts my little Bulldog 285 FEL bucket to shame.
So, after talking it over with my son we are both of the opinion that adding some sort of bucket extension makes a good deal of sense. This added cubic capacity is only for carrying brush and branches and wood rounds. I would not be loading the FEL beyond rated capacity. The tractor would be parked, loaded by hand with the wood and/or woody material, transported, and then driven somewhere and dumped. We have lots of stuff that fits the woody category, like berry canes, pine and alder branches, and various invasive plants that need pulling up and burning.
I could use the Case but it is big and long and I always have to worry about the backhoe hitting things. That's one of the reasons I bought this smaller tractor.
So, opinions about construction? My idea is to keep the sides and bottom of the extension in the same planes as the existing bucket. I may or may not have the top angle upward for even more capacity. The extension will need some sort of frame to hold the sheet steel, which will be either 1/16 or 3/32 thick. The frame might just be 3/8 thick flat bar at the mouth. But since I won't be scooping material it might be better to use 1 x 1 x 1/8 angle. It would be lighter and stiffer. I don't know yet how to interface the extension to the bucket itself. I'm not too keen about drilling holes in the bucket but i could. It would be best if there were no fasteners or clamps or any other obstructions at the interface that would catch stuff when I am either dumping or pulling stuff out. A smooth transition from extension to bucket is best. I think I figured out just now how clamping could be done. Tomorrow, when it is light out, I will take a look at the bucket. If my idea for clamping looks good I'll make a to scale drawing and post it here. Anyway, once again, opinions? About construction and the whole idea in general.
Thanks,
Eric
/ Adding front bucket extension for more capacity? #2
Why not just get some pallet forks for hauling brush?
I have forks already. They let too much stuff fall through. I tried using them with a pallet but it really didn't work out very well. I could screw a sheet of plywood to a pallet and add some sides and use my clamp on forks, the ones I used with just the pallet. And clamp the pallet to the forks. Then I can dump the brush onto the burn pile. Hmmm. I'll think about it.
Thanks,
Eric
/ Adding front bucket extension for more capacity? #4
/ Adding front bucket extension for more capacity? #5
I’ve never liked tractor buckets either. A deep bottom skid steer bucket is better in pretty much every aspect. The problem with a deep bottom bucket is you’re going to reduce the bucket breakout force and reduce the loading height.
/ Adding front bucket extension for more capacity? #7
Ive extended several tractor buckets just by welding a new cutting edge in front of the existing one and gusseting the sides and that's worked great. This bucket is on its 3rd tractor now. You just have to be very careful not to warp it or you'll end up with a bow.
/ Adding front bucket extension for more capacity? #9
The problem with bigger buckets is you need a bigger tractor that can lift them. You might be able to lift more with a 3PH carryall. Or if you have lots of cash floating around buy a UTV, Skidsteer or CTL, or track carrier
/ Adding front bucket extension for more capacity? #10
Thanks,
Eric
some pics of the bucket would help.
did you just want to extend the floor of your bucket, or add sidewalls as well?
Will the extension be removable?
I'll post a picture. I want all 4 sides extended. The extension is to be easily removed when not needed. I don't want a 3PH mounted tote because it can't be easily dumped.
/ Adding front bucket extension for more capacity? #12
Check out … titan attachments clamp-on debris forks. Found them handy.
I didn't want to start my tractor today just to raise the bucket. But I think these two pictures will show the small size and shape of the bucket. And just to reiterate, this extension is just to add capacity for bulky but relatively lightweight vegetative material. I have a lot of it every winter.
I am a 65 year old guy with 20 year old crushed wrists injuries. Bone on bone joints in both wrists. I get by but tractors help. I was using my Case 580CK backhoe for this type of work, loading stuff into the front bucket, along with my wife, she is no slacker, but the Case is big and long. My new to me 40 year old YM2310 is a great machine. But the FEL bucket is so small. Loaded with sand or rocks it is the correct size, loaded with pine branches from the latest blow it is woefully undersized. So I want a bigger front bucket that I can dump.
I appreciate the suggestions about forks et al. But I don't want to use forks. I have them. Stuff falls through them. I am not picking this stuff up with the tractor because of what needs to be picked up. I am loading by hand. All sorts of sizes in all sorts of places. Lots of the branches are too long for the bucket and get sawn shorter. Much of the stuff is already short enough to fit. When clearing salmon berry and blackberry bushes they often need to be compressed into whatever we are using to transport them to the burn pile. A big bucket, like the one on my Case, is good for this. But I'm not gonna use the Case because I have the much smaller and more maneuverable Yanmar YM2310. Hence the bucket extension question.
I am newly retired. I have a machine shop on my property 300 feet from my house. I want to make my life easier. My shop, besides the CNC and manual machines, also has 1 plasma cutter, 2 bandsaws, 2 TIG welders, and 2 MIG welders. So I have the equipment to build the extension. Fortunately I also managed to acquire the skills to use these machines. So I can make the extension. I just wanna do it right. I kinda hoped someone had already done this and could give me pointers.
See the two pictures.
Eric
/ Adding front bucket extension for more capacity? #14
My first question would be how often are you going to need what you intend to build? If it is not frequent, either pallet forks or clamp on pallet forks with something to close the gap and hold things would be the simplest thing. I have both and they have worked out well to haul brush with a sheet of plywood, an old wire gate or whatever as a 'floor'. I have also used an old small pickup bed liner and it worked out really well.
But, as you have the shop and all the equipment it may be an interesting project to take on. If I had all that you have I would likely want to build something to suit myself - challenge myself, and get the satisfaction of doing it, even if I was not going to use it much. The wife has stopped asking "what are you building now"?
/ Adding front bucket extension for more capacity? #15
From HollyRidge campground that we go to... used for leaves and sticks. Only thing attached to the bucket at the angle iron on the sides.
That's bigger than I want but I like the design. I'm gonna copy it. Sort of. The open top would really let me pile up the bushy stuff. And it can be easily dumped.
Thanks,
Eric
/ Adding front bucket extension for more capacity? #17
So I think the main side bars, swing out from the one bolt that holds it on. Look at the bottom lip of the bucket, the outside edge catches on the inside and may (?) supports some weight from tilting forward.
Whatever you come up with, make sure you post back!!!
I will post pictures. The front lip will for sure need to fit into a slot to help support the weight. I want my extension sides to butt against the existing bucket. Then I think I will run a bar on each side of the extension to the hooks I have on the top of the bucket at the sides for clamping to the bucket. The bars would run from the front of the extension to the hooks. No, I have a better idea, instead of bars I'll use chain binders. I'm not sure yet how to pull the bottom of the extension tight against the front lip of the bucket, maybe use a chain that wraps around the bottom of the bucket and connects to the center hook welded to the top of the bucket.
Thanks,
Eric
/ Adding front bucket extension for more capacity? #19
I have something similar for leaves and very small brush.... IT was some sort of guard that turned up in surplus material (junk) pile....
dsfel-basket-jpg.714717
/ Adding front bucket extension for more capacity? #20
Good question! I've thought about this because we have a lot of autumn leaves that pile up in a cup-de-sac and I have to carry them pretty far. I've toyed with building a fairly light weight plywood trough that would wedge into the bucket and extend the bottom forward and the top up and forward. I'm picturing two plywood rectangles, maybe 3/8" thick, and two heavy plywood shapes cut with a jigsaw to fit neatly into the sides of my existing bucket and follow the contours in there, maybe 1". Then, make four braces of fairly light steel angle to construct the corner seams, maybe flat steel backing plates rather than letting bolt heads just pull through the wood. Perhaps pull the sides toward the bucket with a couple turnbuckles, anchoring them with a chain or even one hole in each bucket side plate (which wouldn't hurt much).
