JD 5300 steering cylinder repair help needed
   / JD 5300 steering cylinder repair help needed #1
AdrianW
1997 John Deere 5300
I have a 1997 JD 5300 2wd. The steering cylinder is leaking and I need advice on how to replace the seals in the cylinder. Does anyone know how to break this item apart? I believe it is a part number RE284628 or RE45885. It has the cylinder arms on both sides for left and right.
   / JD 5300 steering cylinder repair help needed #2
Check your private messages
   / JD 5300 steering cylinder repair help needed #3
Post a pic of the cylinder around the gland area. There are only a handful of ways cylinder gland caps are attached to the barrel. One of which are too difficult to disassemble...but some are not so obvious if you have never messed with hydraulics.
The Manual that another gentleman shared with me (very much appreciate iated) just says to take end caps off but doesn’t state how to do that exactly. I’m mainly trying to prevent further damage when I start taking it apart. 7309F17C-9ED2-4922-A435-6BD46116FC7D.jpegD7F93736-E1C3-4FA1-B1C4-184234ADEAEB.jpeg3955727F-66E3-4AF3-B299-2A1442F2A1EE.jpeg6FE8EDBA-D0D9-4C65-9979-4B6F1D1ABFA5.jpeg
I posted a pic down the line in thread. Not sure if they attached or not.
Worst part of that job is getting the tie rod ends off the cylinder rod.
Do you happen to know how the caps come off?
   / JD 5300 steering cylinder repair help needed #8
I'm wondering if they are not physically attached the the barrel.
Since it bolts in from both sides....maybe the manual doesn't elaborate....since maybe they do just "remove" from how you have the cylinder now.
Try taking a dead blow hammer and tapping off one of the ends
   / JD 5300 steering cylinder repair help needed #9
That's my take on it. Glands are both bolted to the axle. O-rings seal them to the barrel, nothing more.
Thanks everybody. I’ll get the parts ordered and give it a go. I’ll let ya know how it goes.
J & M 1150 Grain Cart (A50514)
J & M 1150 Grain...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52128)
Kubota 24in Quick...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
CHALLENGER MT465E TRACTOR (A51406)
CHALLENGER MT465E...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
