John Deere X584
/ John Deere X584 #1
tkcomer
Maysville, KY
JD 3039R
Thinking of upgrading my 11 year old JD LA 145 to the JD X584 with a 48" deck. The LA 145 is what I call my trim mower. I have a 4 acre lot surrounded by woven wire fence with several buildings and a few trees. Plus several "dead" spots I mow as it's easier than using the Case IH DX-33 in those areas. The LA 145 isn't that bad for swinging tightly in and out of all those fence posts, but would the 4 wheel steer be that much better? Also, how durable is this mower? Any problem areas that I need to know about? Ground is pretty rough (Old farmland) so anything over 5 MPH on a rider is moot. Any advice would be appreciated.
/ John Deere X584 #2
That much better!
The rear wheels follow/track the front wheels going around a location, be it a tree or curb or bush. Where the front wheels travel, so do the rear wheels.
Mount a sprayer bar with nozzles on the front weight bracket and you can steer that spray precisely where you want it. No watching back.
Backing up wagon or trailer or lawn roller is much easier too.
/ John Deere X584 #3
4 wheel steer aides significantly in maneuvering but they are strange to drive. Not normal feeling the backend go sideways…
my son had to replace most of the steering linkage on his X749 at around 1200 hrs so pretty durable also.
/ John Deere X584
I doubt they drive like a tow motor. I do have a hillside by the road. Probably could mow about half of that with this. Not sure how steep this model could do. But I have a dedicated mower I'm trying to keep alive for that. Is the transaxle pretty durable? I have a 6X4 trailer that can make that LA 145 whine pretty good if it's loaded and going up a hill.
/ John Deere X584 #5
Deere 4 wheel steering is real nice. Next best thing to already sliced bread. When people ask about zero turns, I suggest that they give one of these a road test first. Zilch in added repairs and 2 extra grease fittings. The 48 Accel deck does well plus the mulch on demand works great and is a big improvement over what they had before.
/ John Deere X584 #6
I've had an X584 for a year now. Replaced my old 1997 John Deere 325.
It is a great tractor. I would not have a garden tractor without AWS now!
The transaxle is a Tuff Torque (Kanzaki) K72 fitted with the AWS option. This is a heavy duty transaxle that is fully serviceable. It also has diff lock, which is nice in low traction situations.
The only down side in my experience is the swapping of implements is not "quick attach" as it was on my 325. (I have the 47" snow blower)
/ John Deere X584
I'd say my biggest problem will be finding one to look at. Glad to hear the transaxle is rugged. I used to use the Poulan Pro (Hydro Gear) to pull with, but that's my hillside mower I'm trying to keep running. The LA 145 does excellent job cutting grass, except when it's wet. Are the spindles hard to get to grease? The LA has two that are a pain to get to.
/ John Deere X584 #8
Greasing is easy. The Accel deck has flip up covers on the outboard spindles that flip up to clean the debris out and the grease zerks are on the sides of them. Besides the 3 spindles the pivot at the tensioner has a lube point plus the 2 joints at the rear end each have one. Then your center pivot and kings on the front axle.
/ John Deere X584
Local dealer said they would try to get one in to look at. But the deck concerns me. With the LA 145, I can get the deck under the fence just a little to mow the grass in between posts. Not sure I can do that with the X 584 as the wheels look like they're too close to the edge of the deck.
/ John Deere X584 #10
Take the wheels off - if you don't need them.
They're only needed as gauge (gage) wheels with undulating ground.
/ John Deere X584 #11
Prolly true with a 48" deck.
/ John Deere X584 #12
The X584 can be configured with a 54-in deck. I have the 54-in deck on my X584 and it works really well. I'm very happy with my setup, highly recommend!
/ John Deere X584
I'm just going to have to find one to get a look at it. Wheels on the LA 145 aren't a problem. But I did have to take the deck wash (Including the bolt) off to keep it from hanging up on the fence. I actually have a wheel off on the Poulan Pro, but for a different reason. I've slipped on the ditch out front a few times and hung the mower up. Had to get the tractor once to get it loose.
/ John Deere X584 #14
Sounds like you are mowing very tight to your fence. Just be aware that with the AWS, when you steer away from the fence, the rear will swing slightly toward the fence.
I have the 48" Accel deck and mow up to my chain link fence and it's not an issue when I turn away. However, if I was sticking the deck edge below the fence, I think I'd need to just be a little careful and not crank the steering full lock away from the fence. The 54" deck would be less of a problem since the tractor wheels are a little further away from the fence.
2016 Jeep Compass SUV (A61574)
2016 Jeep Compass...
1985 Ford Ltl9000 Tender Truck (A63688)
1985 Ford Ltl9000...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
1042 (A60430)
1042 (A60430)
2015 CATERPILLAR 299D2 SKID STEER (A64279)
2015 CATERPILLAR...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
