Front-End Loader 3pt weight
/ 3pt weight #1
Smokeydog
Elite Member
Knoxville, Tennessee
Kubota B26, M59, M5030DT
Made 1981 for 2wd tractors. Pulled a lot timber out of the woods and trip bucket manure FEL stall cleaning.
Used an old kitchen counter water heater tank, scrap steel and hand mixed concrete. Very handy at the time but use with 4wd tractors is none. Used as outdoor anvil or weight for proof testing FEL man basket supports.
/ 3pt weight #9
Ingenuity and recycling! And as noted below it also acts as a good target. This is what farming is all about.
/ 3pt weight #10
Looks like my dog in the background.
Shes always getting in the pictures.
/ 3pt weight #11
I can see how that would get the job done back in the day, looks like the top pin might be a little hard to remove after all this time.
/ 3pt weight
The top pin was some of scrap used to build. The bends lock in in place. Always meant to replace with a proper pin. The square holes in RR plates might not take a 3/4” round pin. Has lasted lots of jerking. Snaking out logs with chain wrapped around the top. Spin out then play out feet of chain to get going again.
Probably appreciate the improved braking as much as the added driving traction of 4wd.
2012 GMC Sierra SLE 4x4 Crew Cab Pickup Truck (A61573)
2012 GMC Sierra...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
2015 Ford Transit Connect Cargo Van (A61573)
2015 Ford Transit...
LOT OF PVC & PLASTIC PIPE (A63291)
LOT OF PVC &...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
