Pin Lock quick attache
/ Pin Lock quick attache #1
tgrashopper
massey Furgeson 1528
Is it possible to get attachment for this system?
Can I take a regular attachment and run a pin on the top hold that it will connect?.
/ Pin Lock quick attache #2
You have a pin grabber. It will allow you to only use attachments that are made for that model of loader. If you want to use the standard skid steer quick attach you will need to get an adapter that will replace the pin grabber, something like an ATI MF3. You will then need a bucket with a quick attach plate on it.
Another option is to buy a quick attach latch plate, cut the ears off of the bucket, then weld them to the quick attach latch plate. There are many threads on this forum that cover that.
Titan makes a frequently used latch plate
I like the RVM better because it uses thicker steel, and the parts are standard New Holland parts, so serviceability is better.
/ Pin Lock quick attache #3
Absolutely, go with one of the adapters listed above that way you have unlimited options for all of your attachment needs.
This is a bumer. I was not expecting this answer. I'd like to get a snowpucher and some fork but I did not had the intention to spend 2k$ Canadien to concert my current bucket.. Previous owner did not treat the bucket well. It's bended and have hole in it. I'll have to heat it up with torches and weld a plate to cover the hole. Nothing impossible but I was hoping to keep my current attachment system.
I'll check with my local dealer if it's possible to get a Snowpucher for that system. I saw that it's posible to get fork that can be bolter and unbolted to the bucket, worst case that would be my other option for the time that i'll need fork. I live in Candana quebec so chances the site you show me would be crazy shipping price + border fee + conversion. To expensive.
I calles my dealer and they told me it's possible to get attachement for this system. only thing with covid it's a special order that can take a long time.
/ Pin Lock quick attache #6
I know HLA makes several quick attach adaptors, they are in Listowel ON it might be worth giving them a call.
Thanks I'll check with the. I belived it's with them that my dealer had the intention to have one build. Not sure if they deals with non business
ATTENTION! PLEASE READ (A64126)
ATTENTION! PLEASE...
2020 Takeuchi TB250-2 Mini Excavator (A62613)
2020 Takeuchi...
New/Unused AGT Industrial YSRT14 Mini Skid Steer (A65579)
New/Unused AGT...
32" Smooth Lip Mini Bucket  (A62679)
32" Smooth Lip...
Wooden Wagon Wheel Table (A64127)
Wooden Wagon Wheel...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
