Concrete Footer Demo
/ Concrete Footer Demo #1
JM7500
Southern Middle Tennessee
Branson 4820R TLB
In the location where we will put our new house was an old double wide trailer. I got it removed and found a footer for a house that was one the site in the 1950s or 1960s. I have to remove it so the new footer can be poured. Any suggestions on the best way to remove a footer. It's 12"x24" in most areas. I have a small jack hammer that I've been using to break it up. It's back breaking and slow. I would prefer not to have to hire a skid steer or excavator with a hydraulic breaker, but would rather do it myself. It has a little #8 rebar, but it's on the bottom of the footer and some is below the footer and not in the concrete.
/ Concrete Footer Demo #2
I’ve pulled them up with my 5 ton mini excavator without a breaker. I don’t see any practical way to do one without heavy equipment unless you like breaking your back for nothing.
/ Concrete Footer Demo #3
Can you drop a heavy weight on it to break it up? When I had my barn demolished, they had a large wrecking ball they would drop all over the concrete floor and footers. Of course, they were using a 70,000 lb excavator to do the dropping and then scooped it up with a giant grapple.
/ Concrete Footer Demo #4
Just keep beating on it, you'll get it removed. Good thing winter is coming, 12"x24" concrete with 1" rebar is a cool weather sport.
Or you could hire an excavator and be done with it in half a day.
/ Concrete Footer Demo #7
/ Concrete Footer Demo #9
I agree this would be the best way to go combined with the BH. I would rent it if I had water at the site.
Your next post will be about a Branson busted in half.
Don't bother telling me your hoe has a subframe. That's not an all inclusive get out of jail free card.
As much as I would like to cut the concrete apart, I don't have water available to cool the saw and cannot go this route. I understand the limitations of a tractor backhoe vs an excavator. My current plan is busting up the concrete into pieces that I can scoop out and pile up with the hoe. Most of the pieces are similar to 6"-8" rip rap. I'm not concerned about bending any of the frame, but more concerned about over stressing a hyd cylinder and bending it. With limitations I have between location, lack of utilities and not having unlimited funds, I work with what I have. Fortunately, I do have 2 months to remove the footer, which is plenty of time breaking it apart and piling it up.
/ Concrete Footer Demo #11
I pulled this one out of the ground in like an hour with my Kubota KX-040. Zero sawing, no hammer, zero manual labor. I can’t believe how much work you’re willing to go through to avoid getting the right tool.
/ Concrete Footer Demo #12
I agree with most every respondent here. Rent/use an excavator, if you insist on the DIY route. I'm a die hard DIY'er too, but I have my limits...
I pulled this one out of the ground in like an hour with my Kubota KX-040. Zero sawing, no hammer, zero manual labor. I can’t believe how much work you’re willing to go through to avoid getting the right tool. View attachment 722022
Did you break it up by hitting the top or dig underneath and pull up? If things don't go as planned this weekend, I'll take this route. Do you think a 10k mini-excavator is the right size for a 12" deep x 24" wide footer?
/ Concrete Footer Demo #14
I didn’t have any optimal sized rocks to drop and break it so I just dug under and pulled it out. As long as there’s no rebar they’re not that hard to break. My machine is around 10k. One size bigger would be optimal but it got the job done. I had to demo a sidewalk that had finished concrete on both sides. I paid a guy with another KX040 with a hammer to come chip that up and he made quick work of that as well. But I doubt you need a hammer unless there’s rebar or you want the footer in little easier to dispose of pieces.
/ Concrete Footer Demo #15
Can you simply move your build site a few feet and avoid the entire mess?
I could move it forward about 15' to avoid removing the front footer now, but the trade off moving it is the front of the house on a severe slope with 2 additional courses of block on the front. Moving to the left or right would also require additional site prep and courses of blocks. I only need to remove the front and half the sides for the current location. I want to remove all of it. Somehow I know if I leave it there, someday in the future I will need to remove it for some reason, so do it now without the house in the way. In my job, I deal with a lot of equipment, pipe, conduit, etc. that is "abandoned in place" and causes issues down the line. If I don't make significant progress this weekend, I'll probably do as 4570man suggests and rent a mini excavator.
/ Concrete Footer Demo #17
What are you doing for putting in the new footer? If you’re hiring it out I’d just let them pull it out while they’re at it.
/ Concrete Footer Demo #18
Rent a big diesel air compressor and 80lb jackhammer. It will make short work of the concrete. Big rental yard should have one. You pull them with a truck. Don‘t mess with electric hammers. They are too slow.
After several days with very little progress, this is the option we are going with. It’s moving the house about 250’ back and 25’ higher elevation . Now I’ve got a lot more trees to clear and more driveway to cut. Trees and dirt are much easier to deal with than concrete. I appreciate all the suggestions and advice from this forum.
/ Concrete Footer Demo #20
You might want to check the cost of building 250’ of driveway and running utilities 250 foot vs the cost of renting an excavator with a hammer if needed. $500 would solve the concrete problem. Moving back that far will cost tens of thousands.
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
2019 FORD F-350 (INOPERABLE) (A65643)
2019 FORD F-350...
2019 Mercedes-Benz Sprinter Box 1500/2500 Van, VIN # WD4PE7ED3KT012316 (A65563)
2019 Mercedes-Benz...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
2008 Mercury Mariner (A62679)
2008 Mercury...
