Man I need front fenders
   / Man I need front fenders #41
With all due respect, Hay Dude, I think you are making this more difficult than it is. If you don't want metal, then go and buy some plastic sheet. Most fab shops I know won't go crazy if you ask them to deal with a little plastic.
Why?
I'm just tapping into TBN members vast knowledge of ideas and resources. I have no intention of "fabbing" the fenders. Im more looking for resources on buying them (and rear fender extensions) from sources other than dealers, who charge a lot.
   / Man I need front fenders #43
Forgive me if I already asked this question, because every time I see the thread title, I remember the picture. AND I keep wondering...
Why did you wash the tractor before taking the picture? :)
   / Man I need front fenders #44
lol
You win the post of the day.
   / Man I need front fenders #45
Our Canadian neighbors up north can get fenders on the L40 and L60 series tractors, but I was not able to find a way to actually buy them. Apparently there is an "Arctic" tractor version that comes with fenders, but it may also be a Canadian or dealer specific thing. It's been a few years since I looked into it though.
I don't get too far when I think about fabricating my own steering fenders... Looks like a lot of work. I may mount large mud flaps to the frame since most of my issue is roading the tractor while plowing in the winter (straight run driving at speed).
Not any longer. Paul Short gave me his dealer contact info and the sales manager responded to me and said the front fenders were no longer available for the L60’s. He said customers were having problems and they were getting torn up.
Huckabones did a short video of a limited edition winter Kubota and it had FF on it. If I remember right he said the FF shouldn’t be used for field work or rough terrain. I’d be ok with that. Put them on in winter to keep salt off tractor and remove them in warmer weather.
Ive never washed that tractor. :giggle:
   / Man I need front fenders #47
Ah hah here’s the screenshot I took.
Those look fixed. helpful for sure, but would prefer steerable
   / Man I need front fenders #50
Steerable front fenders are expensive. They may be plastic but they are quite durable.
Also on many tractors they will reduce your turning angle considerable.
Then if you add a loader into the equation it gets even tighter and becomes a tossup,
do you want maneuverability or mud and slop protection.
   / Man I need front fenders #51
Here's an example from the hot rod world.🤓
   / Man I need front fenders #52
I was going to suggest looking into Skytrak or Lull fenders but the set I found online was $2k.
That's for some thin wall tubing and plastic. Yikes.
   / Man I need front fenders #53
Had my Kioti dealer fab me some.
Yeah!!! They get a LOT for fenders!
I haven’t seen any reduction in steering on my tractors that have steerable front fenders.
   / Man I need front fenders #56
I have, it also depends on the front wheel spacing,
on that MX how close to the frame do the front tires get.
And then how much closer to the frame do the fenders get.
Did someone set the steering stops so the fenders don't hit the frame even on the articulation bump stops?
On the 7100 and 7200 series Magnums it makes several degrees difference in turn angle with or without fenders.
   / Man I need front fenders #60
Not the fenders themselves, it's the mounts and how they attach to the spindles and how they can articulate at full lock without hitting anything. Last time I was at my dealer, they were installing a set on an M151 and the mounts are pretty complex.
New Holland Basket Rake (A56438)
New Holland Basket...
2009 Ford F-150 Pickup Truck (A59230)
2009 Ford F-150...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
