L2501 with HST
/ L2501 with HST #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
How does an L2501 work with brakes on same foot as the HST pedal?
I've been looking a Kubota for my next tractor. Have pretty much set my mind on a B2301 but decided to look at the L2501 since it is so popular.
Real deal breaker seems to be the brake pedals on same side as the HST treddle. No way can you use the steering brakes unless you put the HST on "cruise". Just won't work for snow removal or pushing of big pieces with the FEL when the steering won't work, etc.
/ L2501 with HST #2
I have the same issue with my B2620. When I do need to use the steering brakes in winter when I am cutting the ice in the driveway I just reach down and use my hand on the brake pedal, LOL
It is not an ideal setup, but my B has a clutch which I like, so no choice.
I see the new L02 series that is coming out has left side brakes but I don't know if the updates will carry over to the L2501? I'm guessing probably not yet.
/ L2501 with HST #3
I use the cruise control on my 3901 when I need the steering brakes. Tractor brakes were never meant to stop just turning or holding in place
/ L2501 with HST #4
I second that. I use cruise control and steer with the brakes for snow removal. Just reduce the speed for better reaction time for directional control.
/ L2501 with HST #5
The problem is that brake steering with 4x4 engaged doesn't work to well... If you are in snow, you are most likely in 4 wheel drive. Grab a stick, and use your hand to press on the brake with the stick...
With a HST, hitting reverse to back up is SO easy, I never see when I would ever have a need to spin around on a dime.
/ L2501 with HST #6
Old and Tired....where I find the steering brakes useful is if I am using the loader to cut hard pack snow and ice in the winter. Because you are putting down pressure down with the bucket and can't steer, they do help you maintain direction even in 4WD.
/ L2501 with HST #8
Not living in snow country had to read to understand the need for the brakes. Makes sense. As tractors were mainly built for farming and row crops you needed the ability to make tight turns and thus the split or individual brakes. When a farmer was use to turning a single horse or mule at the end of a row or a team they needed the same ability with the tractor as you pulled out of one row and make turn back into it for row spacing. Still normally done with single row equipment.
I have a B2710 with brakes on right side but my L6060 last year does have them on the left and yes no clutch. But it is seldom I have needed the brakes to even slow down or stop. Again it makes sense about your need on snow or ice.
/ L2501 with HST #10
I've seen big AG tractors use them turning at the end of the rows as you say, but on my little tractor I've never had the need to use them in the summer. Even mowing circles around all my trees. With a hydrostatic transmission it is just so easy to switch from forward to reverse to make tight turns that's all I end up doing.
I used to run full size backhoes lots and I found I used the steering brakes lots in those when using the front bucket.
/ L2501 with HST #11
GgHow does an L2501 work with brakes on same foot as the HST pedal?
When I first started using my new Kubota more than 20 years ago I tried to figure out some convenient way to use the split brakes like we did on the old tractors. I remember moving a big round bale for a neighbor across the very muddy, slightly sloping cow lot next to his barn. The R4's weren't doing much good in all the mud and both the bale and the tractor were slowly working their way down the slope toward the fence instead of to the barn. Standing beside the fence, the old gent kept telling me to get on the brake, and I must have looked pretty funny doing some kind of dance on that tractor trying to find a way to do it.
The solution, when it came to me, wasn't some some really fancy footwork. In desperation I straightened the front wheels and punched the diff lock and the tractor began working its way through the mud toward the barn. Even with the slippy R4's , the "3 wheel drive" (1 locked rear axle + 1 open center front axle), gave more forward traction than I had ever been able to gain with the old rear drive + split brakes tractors long ago. We got the bale moved, but I don't think the old fellow ever figured out why I was doing that crazy dance up on the tractor.
I used the tractor for many more years doing many different chores, but the split brakes didn't factor in everyday use and weren't missed. For turning, if you have any kind of weight up front, such as the loader, with or without payload, the front wheels will pull you around a turn better than a brake turn in almost all conditions. And if it's a really sharp turn, the power steering + HST is so easy and quick to operate it makes sharp turns a piece of cake. I found adding a spinner to the steering wheel helps too.
Turning in slippery conditions is probably the one place where the split brakes probably give an advantage. If that's a big part of what you'll be dealing with, that odd Kubota pedal layout will be something to think about when you buy. For me, and I'd guess for most owners, it's mostly a non-issue.
/ L2501 with HST #12
I don't know how you would use those steering brakes. Hopefully you won't have to do much of that with the HST. Our M59 has the same thing with brakes and F/R pedal on the same side. Being a largish tractor with a flat floor it has enough room to make it work....uh, sort of work... well, if you stand up and lean to one side while holding onto the front canopy support it you can make it work..... kind of...
Come to think of it, far and away the most complaints about Kubotas that I've heard in the last 15 years are all about the placement of the controls. Feet, seat, and levers are all uniformly poorly designed and poorly placed. Isn't that odd?
One of the world's most popular tractors and they still can't get that part right.
If it wasn't for the way the operator controls are laid out there there wouldn't be much to say against Kubotas. Maybe that's why they do it?
rScotty
/ L2501 with HST #13
I had a L3200hst... Basically exactly the same as a L2501. To work turning brakes, you had to ride side saddle in the seat with both feet on one side. Not ideal, but not the end of the world. I used them occasionally but not a whole lot. I didn't have cruise control, even if I did I wouldn't have used it. If I need to turn tight it means precision & I don't want cruise on for that.
My new L4060hstc has brakes on the left separate from the HST. I like it better but don't end up using turning brakes that much more.
/ L2501 with HST #14
Kinda side saddle and left foot braking is what I do on my MX.
Up until recently Kubota was still using a clutch pedal on HST models....
Now that they have gone away from that, I'd expect to maybe see some left side brakes.
/ L2501 with HST #15
Yes, as I pointed out, the new L02 series that is being released in the new year has left side brakes and electric PTO clutch engagement.
The B01 and B50/LX series already had gone to left side brakes and no ore clutch pedal.
/ L2501 with HST
The B2301/2601 models have left side brakes. The PTO clutch is like a selector to the left side of the seat.
/ L2501 with HST #17
I tried the side saddle method on my B, and it has way more room on the platform than an L01, but I found it was easier to just band over and use my hand on the brake pedal.
/ L2501 with HST #18
My B2150 HST has wheel brakes. I would not want a tractor without wheel brakes. I guess the small ones mainly for yard work are an exception. In the days before the rear axle locks wheel brakes were how you stopped one from spinning on the slick side. If you do farming or cleaning up an old farm involving steep ground you will at times very much appreciate wheel brakes. On the smaller Kubotas (like my BX2200) the brakes are a worthless joke to start with so wheel brakes would be a waste on them.
/ L2501 with HST #19
Economy Ls still have a clutch on all models for the 00 & 01 series. 60 series Grand Ls don't have a clutch pedal on the HST machines at all.
1993 Freightliner FLD120 Truck, VIN # 1FUYDCYB0PH492774 (A61165)
1993 Freightliner...
300 GALLON BOOM SPRAYER (A62130)
300 GALLON BOOM...
1995 GMC TOPKICK FUEL INJECTION CHASSIS TRUCK (A62130)
1995 GMC TOPKICK...
(1) 380/85R30 TIRE W/8 LUG RIM (A62130)
(1) 380/85R30 TIRE...
INOP/NON-RUNNING 2012 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL6CL455085 (A61165)
INOP/NON-RUNNING...
2018 International HX620 Quint Dump (A62613)
2018 International...
