John Deere 5210
/ John Deere 5210 #1
Alan v
John Deere 5210
John Deere 5210 I purchased this and changed the filter And topped off fluid. It first appeared to work fine and then the steering and lift arms would not function. Not familiar with hydraulics. Any thoughts. Thank you
/ John Deere 5210 #2
Is the fluid still showing full on the stick? I had a 5310 that I changed the filter on once I think. I'm not sure I lost enough to even add any.
/ John Deere 5210 #3
Since it happened after you changed the filter I would think it has to be related.
/ John Deere 5210
Is there a simple way to bleed out air. I suspect the filter change introduced air. I thought it may purge by running the system or turning the steering back and forth.
/ John Deere 5210 #5
A bad seal on a hydraulic filter is a possibility. A common error is a doubled up gasket. The old gasket can separate from the filter and stay on the tractor, then the new filter and gasket won't seal properly.
/ John Deere 5210 #6
It should purge itself out. I don't know of any way to purge air. I sold my tech manual when I sold my 5310 so I can't check and see if there is anything about it in the manual. Is the steering doing nothing or just hard to turn? I would think if your fluid is correct and you can operate thing to some degree, run it and see if it starts getting better.
/ John Deere 5210 #7
I would think it would be leaking if that were the issue. This tractor has a spin on filter like an auto oil filter.
/ John Deere 5210 #8
The spin on filters are the type I was referring to, but yes, I would assume it would be leaking also.
I used an aftermarket (spin on) suction filter on one of my diesel zero turns several years ago and the hst wouldn’t operate at all. There were no fluid leaks, but I don’t know exactly why it caused problems. The oem filter fixed that issue.
/ John Deere 5210 #9
Good point. It could be the filter if it's not OEM. I never put aftermarket parts on my JD tractors or ZTs.
/ John Deere 5210
I did check to see that old gasket was removed. No leaks. Oem Napa filter. The lift arms do very slowly raise and I can feel them trying to raise. They did suddenly jump up a little once. Steering is hard to turn. Feels like no assist.
/ John Deere 5210 #11
So you got the filter at NAPA? I would get a JD filter and see if that makes a difference. I know that sounds silly but you did change the filter and now it's not working. It has to be air in the system or lack of flow. The filter would cause lack of flow. That NAPA filter is not OEM.
/ John Deere 5210
Thank you. I just replaced with what
/ John Deere 5210
Sorry. I just replaced with what was on the tractor
/ John Deere 5210 #15
Let us know if you get it working so we know what the issue was. Good info for others.
/ John Deere 5210
Always happy to share. I appreciate the help.
/ John Deere 5210
I also noticed the pro spins slow. Not as fast as I am used to seeing. Related?
/ John Deere 5210
Yes. Pto The fluid is very clean. Should I drain it and check the screen near the PTO.
/ John Deere 5210 #20
The seal on the filter is very critical since it is under suction, it won't show any leaks (as it sucks air into the system) The hydraulic system shares the oil with the transmission, clutch/s (some tractors), and brakes. It is very poor economy to cheap out on filters or fluid. There isn't a common specification organization unlike engine oil's API. Any failure in these systems is expensive and difficult to repair. Failure debris is quickly distributed and hard to clear out. It just lurks in the system nooks and crannies waiting to be dislodged and cause another failure.
SKID STEER ATTACHMENT (A58214)
SKID STEER...
1998 JOHN DEERE 120 EXCAVATOR (A62129)
1998 JOHN DEERE...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2016 Chevrolet...
2019 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60352)
2019 Ford F-550...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
