Changing coolant yearly or lack thereof.
/ Changing coolant yearly or lack thereof. #61
Anyways, today I stumbled on my el cheapo coolant tester, so since it's in my hand, why not. Tested the coolant and found this:
Maybe I don’t understand how to read that tester, but looks to me like it’s good to -40? If they were all floating it would be ‘unsafe’?
/ Changing coolant yearly or lack thereof. #62
It all depends on the application,
I'll have the radiator hoses off, if the tractor doesn't have a cab I'll pull the thermostat wrap a rag around my blow gun to fill the upper port
and let the air blow in and push much more water and sometimes a bunch of rust and sludge out.
On a cab tractor I'll blow out using the heater hose port to the lower radiator hose port.
Often on a tractor with alot of hours you will get a considerable amount of sludge out, I'll keep flushing with water and air till it stays clean.
That is very true on the accumulation of sludge in a cooling system. I have read a number articles that say that plugged coolings systems cause as many engine problems as gunky old oil. Restricted coolant passages cause unequal temps within the block and things can go downhill from there.
I've flushed sludge and rust from cooling systems on used tractors and some took as many as 6 or 7 flushes and still weren't clean.
Yup, I totally hear ya, I'm also confused by the gradients on the tester. But really it's all about how many balls are floating vs sinking, the fewer the worse.
/ Changing coolant yearly or lack thereof. #64
What were the instructions for yours? Normally the ball type float in 2 or three positions to give your freeze point, condition of fluid, and boil over point.
/ Changing coolant yearly or lack thereof. #65
So, found something interesting today. I changed coolant last year on my GC1710, used this stuff:
I had no intention of changing coolant this year, not as though the tractor is a daily driver or anything. Anyways, today I stumbled on my el cheapo coolant tester, so since it's in my hand, why not. Tested the coolant and found this:
I thought maybe there's a problem with the tester, so tested some of this same coolant leftover in the container, and got 3 balls floating from that (safe to -10 deg). So yeh, this is surprising, and looks like I'm changing coolant this year after all.
I have some sample jars, take some from each vehicle and machine each year, pop them into the freezer for 24 hours, that test is good enough for me.
/ Changing coolant yearly or lack thereof. #68
Pretty much everyone has the perfect water for radiators, you just have to harvest it. The condensate from your AC evaporator unit is perfect water for anything that requires no mineral content. And it's free.
Would this be true for dehumidifiers as well?
/ Changing coolant yearly or lack thereof. #69
Those are some interesting instructions, not much better than the floating pointer ones.
Were 2 balls floating or 4? would be my question based on those instructions.
If it were me, I'd either just replace the fluid with new or buy a magnetic heater pad if a block heater cant be added. Not sure the second one is any more trust worthy than the first, but you have a refractometer coming that measures the sugars, and as long as it is stored the right direction or you remember about the bubble, it will work well; and you can calibrate it!
/ Changing coolant yearly or lack thereof. #70
Not really, unless you are keeping the dirt out somehow.
Easiest way is the old way (used to do it this way for batteries), put an empty bowl in a pot. Put water around the bowl, put lid on and put the pot on medium-high or so. Steam condenses on the lid and collects in the bowl, all the minerals and dirt stay in the bottom.
Oh, dont boil it dry and break the bowl. Done that too.
Can use a tube on a kettle as well, as long as it does not melt.
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2020 Bobcat T76 R Series (A60462)
2020 Bobcat T76 R...
2023 CATERPILLAR 926M WHEEL LOADER (A62129)
2023 CATERPILLAR...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
