nisaacs
- Joined
- Mar 9, 2020
- Messages
- 865
- Location
- Snowflake, Arizona
- Tractor
- 970 John Deere 4x2, 970 John Deere 4x4, 4320 John Deere, 995 Case/IH
I posted this on another forum so I though I would share it here. As all you owner operators of dump trailers are aware, the lift is super slow. For me, it is aggravatingly slow. For a home owner with once in awhile use, it is fine, in a commercial setting, not.
(1)
Calling all dump trailer owners/operators. Or just anyone with hydraulic experience.
If you have a dump trailer you know how slow they cycle. The bigger the trailer/hoist the slower they go. I think jhenderson put me on to a double pump system that is offered. I am really thinking about it or just adding a second pump. The double pump is expensive or about $800 more than a second pump. Since two pumps will have two tanks, my concern is, will the oil level stay equal or will one or the other overflow. I think I can adapt a fitting to the tanks and run a hose between them. There is an unused plug on the tanks that I think is 1" straight thread. Is there a 1" o-ring boss fitting? I think they are straight thread. What do you guys think?
KTI Hydraulics Dual Pump Motor Hydraulic Pump w/ Remote | Fayette Trailers LLC
(2)
Almost done with the conversion, still lack one o-ring boss #6 straight and both tee's. Sunday is not a good day to find parts, I did get all 4 hoses made, that was good.
I moved one battery out of the large section of the tool box and turned the existing one, for clearance to add the second pump. I wired one battery per pump and jumped the batteries together. I am going to run both controllers for independent use of each pump or both.
I will be all in for about $600 v/s $1200 for the double pump, plus what they don't furnish for the install.
(1)
(2)
