Most useful wrench
/ Most useful wrench #21
It is my opinion that the air die grinder is about the best wrench for removing stubborn nuts ever made. :)
My solution is not always mechanical. I first try penetrant - most any major brand. It's best to apply as soon as you know you have a need. Minutes are good, but days are even better. One project was removing rusty hub bolts from a 1950 tractor. Applied some every day for 4 days. Impact wrench spun those off as though they were just installed. Another project was the internal nut on a hydraulic cylinder that had been sitting with open ports in mud and water for over 15 years. Wanted the rod for a project. Again, penetrant for 2 days. Impact took the nut off on first try.
/ Most useful wrench #22
Heat, to expand the nut as much as possible. Then penetrating oil, which will be drawn into any opening. Then time, then the impact wrench.
/ Most useful wrench #24
Most useful wrench​
I use my 24 inch adjustable wrench more for bending and straightening metal, than wrenching.
Not mine, but it looks the same:
Well maybe mine is more nicked up and not as shiny :D
/ Most useful wrench #25
An auto body air saw works great for those small places die grinders can't reach.
If it were simply a nut I would agree but when you cannot get a hydraulic hose fitting loose you cannot use an impact wrench. I tried penetrating lube, propane torch to heat fitting, cheater bars on the wrench and backer wrench and finally said enough. Used the die grinder to cut the nut loose, split it and I was in business..
/ Most useful wrench #27
Thats why I said it's good to get familiar with several methods of removing stubborn stuff. Because one method doesn't work in every case
/ Most useful wrench #28
Most useful wrench​
I went to the shop and took pictures. Not as nicked up as expected, but definitely not as shiny:oops:
It is made by Williams
Towable Generator (A60352)
Towable Generator...
2024 Kubota SVL97-2, PIN: KBCZ064CJN1J72104 (A61166)
2024 Kubota...
New/Unused Top Cat Quick Attach Stump Grinder (A61166)
New/Unused Top Cat...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61568)
2017 Chevrolet...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
2017 Kubota SVL 75-2 Skid Steer (A61166)
2017 Kubota SVL...
