Picking a first tractor
/ Picking a first tractor #21
I know it gets asked here alot, but every property has different needs/concerns, so here it goes.
we live in 5+ ac in a wooded property, lots of holly trees need to go, with lots of blackbery bushes, short volunteer brushes around the taller trees. We live in pac nw. I am considering either a sub compact like the Massey gc1715 (about 1700 lbs), or should i stick with a heavier kubota L3410, but about 5-6k more.
My two cents follow. I own two tractors and one backhoe. My first tractor, a Ford 9N, has a transmission that can only be shifted with the tractor stopped. That means coming to a full stop to shift into reverse . My second buy was a Case 580CK backhoe. Though it has the same type transmission as the Ford it also has a feature called a "Shuttle Shift". The Shuttle Shift is a second transmission combined with a torque converter. The first transmission feeds the Shuttle Shift. It doesn't change speeds but does allow shifting from forward to reverse without clutching or coming to a complete stop. This is a HUGE advantage when moving dirt, or any operation that requires any sort of even infrequent reversing. Did I say HUGE? My third tractor, a Yanmar YM2310, which I bought less than 6 months ago, has two transmissions. The first is a 5 speed without reverse. It requires the tractor to be stopped before shifting. But this transmission feeds into a second 3 speed transmission with reverse. This means 15 forward and 5 reverse speeds. This particular setup is called "Power Shift". The second transmission has hydraulically actuated wet clutches so all you need to do to change speeds is to move the shifter lever. Though the shifting is not as smooth as the Shuttle Shift it doesn't have the slippage of a torque converter. My Case is able to push harder at higher RPM because all the power is going through a torque converter. The Yanmar transmission is not RPM sensitive. The torque converter also uses horsepower, while the wet disc clutches do not. Both the Case and the Yanmar have front end loaders while the Ford does not. On my 10 acres, of which most is wooded, I still find a front end loader so useful I would not buy another tractor without one. I bought my Yanmar to replace the Ford for several reasons, but the front bucket was a must no matter which tractor I was gonna buy. The Yanmar is a little smaller than the Ford but has a little more horsepower. For my uses it is the best size. Though I would like sometimes a bigger bucket the smaller size makes it much more maneuverable than a larger machine. And I would rather make a few more trips than have a machine that I constantly need to worry about hitting things because if the size. I know about this worry because of my backhoe. It is so long I constantly have to watch out. I bought the backhoe just to put in my septic system so that we could move into our new house. When we had our house built there was a building boom going on and though the house was complete there was a 6 month wait for any of the reputable septic installers to do the job. I found the Case for sale for 5 grand, which was a really good price at the time here on the island. So I bought the backhoe even though I had never even sat on one. It was old and beat but worked well. And since the county allowed folks to install their own septic systems, even people like me who had zero experience with septic systems and backhoes, to install their own system, I bought the backhoe. Though the perfect size to do the septic installation the backhoe is really too big for my place most of the time. It seems to me that if buying one machine get one that will do 90 percent of what you will be using it for during the years to come and hire out or rent any specialized machines. If I was shopping for another tractor today it would require a front end loader, and some sort of clutchless reversing, be it a Shuttle Shift, Power Shift, Hydrostatic Transmission, or equivalent. I hope some of my experience will help you make a decision.
Good Luck,
Eric
/ Picking a first tractor #22
Five acres I think it is more a matter of how fast you want to get the work done than it is how big of a tractor do you need. A 25HP tractor can get the job done on five acres, just might take a minute. Upkeep could absolutely be done with a small tractor.
/ Picking a first tractor #23
I would rent the bulldozer. When else are you going to get to rent and run a bulldozer? Just the shear fun of it, is justification. :)
/ Picking a first tractor #24
Sitting at my desk, the Ford appears to be in excellent condition for $7,000.
You will need to learn hydraulic repairs long before you need an engine repair.
For working over the blackberries with destruction the goal, consider a Ratchet Rake bucket attachment to tear Blackberries down in manageable segments, then mow prostrate vines. Spray inevitable sprouts with Gordon's (brand) "Brush Killer" from Tractor Supply Company (TSC).
Jeff, thanks for weighing in on this. I was not sure as to what recommendations should be made about how the tractor should be equipped for clearing holly groves and blackberry bushes. I took a look at that Ratchet Rake and was amazed at the effectiveness of it. I learn something new everyday on this site.
I am looking at a 33 hp kubota b3200, 4wd, 1700 lbs. Wheelbase 65”.
would it be maneuverable between a grove of trees 15’ apart, on an uneven slope?
/ Picking a first tractor #27
The L3301 is about the same on HP and wheelbase but gives you 1000 lbs more weight for stability.
Comparables for the 3301 would be the Branson 3515, LS 235E, TYM 394, Kioti CK3510, JD 3035, MF 1835, CIH 35A, NH WM35T4B and Bobcat CT2040..Of those, only the Kioti is lighter than the 3301. All are between 53.5" and 67.5" wide..plenty of space for 15' wide tree spacing.
IMHO, any of these would do better on the tasks you describe than a b3200. Only real advantage I can see in that would be price and lack of emissions.
/ Picking a first tractor #28
I owned and operated a B3300 SU for several years, the same tractor without the mid-PTO.
This a light tractor on tall wheels/tires. Not the most stable platform, even with liquid filled ("loaded") rear tires. A neophyte operator could easily get into trouble doing loader work on uneven slopes. SAFETY FIRST. Tractors can kill you. For non-Loader work on 1-6 flat/level acres a prudent operator would find a B3200 a suitable machine.
Selling a used tractor is easy. Selling multiple light implements in order to buy heavier, wider implements for a new, heavier tractor requires a lot of time. Depreciation on implements is worse than depreciation on a tractor.
When considering a tractor purchase bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
Plenty maneuverable if the 15' spaced trees do not have branches encroaching from both sides. You need 6' wide clear path down the middle.
BUY ENOUGH TRACTOR​
/ Picking a first tractor #29
The ford is 4x4, with fel, about 400 hrs. I will need to learn on how to wrench an old diesel.
Looks nice. If you are the kind of guy who changes his own oil, I'd say jump on it. Those Fords were and still are dandy tractors. Several people on this list own them and I've driven them myself. Older gear drive compact tractors are the financial "sweet spot" for tractors right now.
A good old gear tractor with 400 hrs is unlikely to need any repair. You can expect any used tractor to need attention to maintenance items.
rScotty
/ Picking a first tractor #30
I have a geared MF1528. A HST tractor would have been fine but this tractor was a great price. I do not mind gears as I grew up operating geared 2wd ag tractors. Even so HST is great for loader work.
For consideration in tractor size… you are going to need 3 pt implements to accomplish various tasks. Used implements for subcompacts may be more difficult to find than used implements for larger frame tractors. Give some thought to implements needed to accomplish your tasks and check out costs of new versus used.
/ Picking a first tractor #31
Easily maneuver in those spaces, just watch your head and exhuast :)
Awesome tractor for what you have indicated it will be used for, except (sorry, a lot of excepts...) it might have emissions crap on it. If you have time to keep looking, I'd suggest avoiding emissions.
/ Picking a first tractor #32
Yes on the needing multiple implements. On the difficulty of finding them (used) it's hard to say as it depends on the area. I wanted a 6' RC for my NX5510 and it took quite a while before finding one. 7' box blade pretty much never available: I ended up buying a new one (had to be shipped). 5' RCs are almost a dime a dozen (though quality/condition varies). It did take me a while to find a GOOD 5' box blade.
Regarding the B3200, which is not all that different than my B7800, if it has the quarter-inching valve for operating the 3pt I'd stay away from it. Though my B7800 has been one of the most indestructible and hardest-working pieces of equipment I've ever been around (and ever will be around), that quarter-inching valve is just horrible (with 1,100 hrs seat time I can instinctively adjust it, but it's a constant thing- I just accept it).
SSQA would also be something totally worth having if you're going to be using different loader attachments (mostly bucket, pallet forks; small grapples are possible). Don't have it on my B7800 and managed to live that way until I got my NX5510 (which does have SSQA).
Thanks for all the advices from different angles. Granted, some aspects are a bit more advanced for me to grasp, but i appreciate anyway.
i can see the correlation between weight and stability, strikes a fine balance between able to work safely and efficiently, vs small and nimble enough to get in and around between obstacles…
/ Picking a first tractor #34
Keep soil conditions in mind!
My water table is about 16" right now and it hasn't really hit the rainy part of the year! If I break through then it's all over with: I started sinking in with my NX5510, the rears, although on firm ground, were lifting and not able to drive the tractor out in reverse as the weight on the loader was too great and started sinking the front wheels; I dumped the load but it was too late, I was STUCK. Had pallet forks on the front and tried to use them to push myself out but I ended up driving the forks ALL the way into the ground. A bit embarrassing. Last and only time I got the NX5510 stuck: I've used it, though, to pull out a stuck 9k lb excavator).
/ Picking a first tractor #35
I have come across a
1)Massey gc1715 (sub-compact) almost brand new for 11k, or a
2) older 800 hr L3410 for about 15k or
3)a more beatup L2600f w/o fel for 7k,
4) old Ford 1700 low hrs for $7k.
Didn’t know if i should look for specific weight/hp class? Is it better to have a newer model with less hp or an older one with more hp/more weight?
For almost all tractor tasks, except mowing lawns, wore weight and a wider stance are beneficial.
/ Picking a first tractor #36
Tractors are inherently unstable operating on sloped ground. Tractor rear wheel/tire spread is a critical factor increasing compact tractor stability working sloped or uneven ground. Rear axle is the tractor component on which rear wheels/tires mount. A 4" to 6" wider rear axle substantially decreases tractor rollover potential. Tractor width is an approximation of rear axle width.
The Ford 1700 (unusually) has an adjustable rear wheel/tire spread from 43" to 58".
Larger wheels and tires permit heavier tractors to bridge holes, ruts and tree debris permitting higher ground speed with less implement and operator perturbation.
/ Picking a first tractor #38
Here I thought stability was about the centre of gravity and not weight.
Stability is a combination. Weight is part of it and certainly CG is too. When stability involves slopes, then the side slip - of the tractor or the surface - can be just as important.
The problem with just using tractor center of gravity is that CG doesn't take width into account. CG stays the same whether the tires are 4 feet apart or 40.
rScotty
/ Picking a first tractor #39
rScotty
Centre of gravity and stability takes all dimensions and weights into account. There is no combination. It’s all just plain straight forward.
/ Picking a first tractor #40
I'll try to answer your question again.
No, stability is not simply about center of gravity - nor is it just about weight, although it can appear so since the center of gravity does move when mass is rotated and total weight does not.
Center of gravity is just a mathematical point. It may move as a result of rotational forces; but it doesn't create them.
rScotty
2006 Chevrolet TrailBlazer SUV (A64557)
2006 Chevrolet...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A63689)
Midwestern...
2004 Case JX75 (A64126)
2004 Case JX75...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
