Case 1150 dozer
/ Case 1150 dozer #1
rpd428
Massey Ferguson 471
I hope this is allowed here as it is a dozer… but I’m in the market for a dozer and came across a case 1150 probably from the early 70’s (I’ll include pictures). Seller says it runs good and undercarriage is 80-90%… would this be a good buy? How are parts availability? I’m looking for a dozer simply to clear some brush and trees on only about 50 acres we just bought… maybe a few little projects but certainly not making a living with whatever I find. Thanks. Can probably have this for less than 10 grand.
/ Case 1150 dozer #2
Looks very nice in the pictures , $10,000 sounds cheap to me. In the long run you might be better off just hiring the work done.
/ Case 1150 dozer #3
They were a decent tractor, although an odd size. Some friends in the excavating business had one, decent tractor but, too big for some jobs, to small for others. Mainly used it for hogging dirt building small ponds, or moving large amounts of dirt that were too big of a job for their Case 450. Would probably make a decent farm dozer though. BUT, no way I'd push out trees with it, without a ROPS, with the brush sweeps that go up to the top of the front cowling. When pushing out trees, they can spin turn, and come back over the top of the blade, and could pin you in the seat. Even once they are down, and your pushing to a burn pile etc., they can jump over the blade, and do the same thing. Limbs higher than the blade can turn/roll, come back on the hood, and knock the exhaust pipe/muffler off, and possibly break the exhaust manifold, and or break off hydraulic lines. The sweeps can prevent that from happening, but still not 100%. If you would happen to get it, find a used ROPS in a salvage yard, and put it on.
Any dozer is a high maintanance item. Depending on how much work you have for it, and how much experience you have operating one, in the long run, $10K would go a long way towards hiring someone to do it.
/ Case 1150 dozer #4
I have a Case 1550 dozer. You need to post close up pictures of the undercarriage to verify if there is really 80 to 90% life left in them. For me, this is a huge red flag for a machine that old. It's rare that somebody spent the money for a new undercarriage, and from what I can see, it's been used for a very long time, which means the undercarriage has a lot of wear on it.
Case does not support their old equipment. The dealer may or may not have parts for it. On mine, the fan broke off and destroyed my shroud. Case does not have that fan. I had to find it at a salvage yard in Florida, where they also had the shroud off of another 1550 dozer that they where pulling parts off of. Including shipping, this cost me $2,000
Mine has a Cummins engine. You cannot buy engine parts for it from a parts store. Napa requires the serial number to find the right part. All Case serial numbers come up on the Napa computer as not being available. You can only buy parts and rebuild kits for the engine from the dealer. Fortunately, they have had those parts and the prices where similar to Napa.
Every time I've had issues with my dozer, my local dealer has gone out of their way to help me fix it myself. They copy everything needed from their manuals. They tell me where to get the best deal on parts and other places to do work on it. They just about totally refuse to work on it themselves.
When one of my hydraulic pumps went out, Case wanted $25,000 for a new pump. They didn't want to do the labor, and would not quote me a price to do the labor. They also told me about a place an hour away that rebuilds the pumps if I take it out myself and bring it there. Cost to rebuild the pump was just under $3,000 with me doing all the labor.
My dozer is 170 hp. It was big enough to dig my pond, and big enough to move a lot of dirt, but horrible at removing trees. When the ground is soft in the Spring, it pushes them over pretty good, but it also snaps them off from time to time and leaves you with a nasty stump to deal with. Most of the trees it pushes over are in the 12 inch range. Bigger trees require digging around the roots, and building up a ramp to get the blade up high enough on the tree to push it over. This is slow going and it creates a huge mess to clean up. Once the trees are on the ground, pushing them into a pile to burn adds a massive amount of dirt to the burn pile. I bought a rake, and that helped, but the trees still push dirt as they are pushed to the pile and you still get a bunch of dirt in the burn pile. A dozer is probably the worse machine out there for clearing trees. Once I realized this, I stopped using the dozer for trees and now use my backhoe for tree removal. I put a grapple on it so I can pick up the trees and carry them to the burn pile. Clean trees burn faster then trees mixed with dirt. Clearing trees with the backhoe is significantly faster and easier then with a dozer. I believe an excavator would be even faster at taking them down, but not as good for getting them to the burn pile.
I still have a few things left to do with my dozer on my land, but then I'm looking forward to selling it and never owning anything with tracks again!!!!
/ Case 1150 dozer
Wow that is one big dozer… thanks for the insight… may have a lead on a D4D that works as it should… any insight on these machines?
/ Case 1150 dozer #6
I don't know anything about it. I'm assuming its a Cat. They have the reputation of having every part for every machine, no matter how old. I don't know if that's true or not.
Off the top of my head, I believe that D4's are in the 90hp range. Dozers that small are more for finish grading and making the dirt look nice. They are too light to dig in hard, compacted soil and pretty much worthless at pushing over trees. I ran a Deere 450G for a little bit and it was only able to take out saplings, and unable to push them when I had a bunch of them down.
Except for digging my lake, I really don't have any reason to own a dozer. Since I have it, I'll use to for a few more things, but once it's gone, I'll never own another dozer.
/ Case 1150 dozer #7
They are way cheaper than that. Just look around a little.
/ Case 1150 dozer #8
They are way cheaper than that. Just look around a little. They are becominga dinosaur. A skid steer with tracks will work circles around that thing. Skidsteer will not do as much at once but will make five trips before you get that thing across a field. Just rent a trac hoe to knock the trees down and do the rest with a skid steer.
/ Case 1150 dozer #9
Only under "ideal" conditions! Anything other than that, and you will be going for something to pull/push that skid steer out.
I had both at the same time, the dozer is still here!
SR
/ Case 1150 dozer #10
Unless you want to be on the other side of the dirt don’t touch a tree with an open station dozer.
/ Case 1150 dozer #11
SR
They’re different tools for different uses. It also doesn’t sound like you had a tracked skid steer. That dozer doesn’t have a 6 way blade either which is really going to reduce the usefulness of a small dozer.
/ Case 1150 dozer
D4D is cat, yes. It’s a pretty stout dozer though, I’ve seen them run, they’ll push over trees fairly easy. 90 HP and I think around 20,000 pounds I’m not logging and pushing over sequoias or anything. Good to know that parts availability is presumably a little better with Cat than the others. Thanks for the info.
/ Case 1150 dozer #13
For land clearing straight blades on dozers are stronger and work VERY good. BUT, like a "gear drive" in a tractor, you have to learn how to use them, and once you do they work great. Some people just think it's too much work to learn how to operate something, that in the end is superior.
I had dozers with straight blades, you just have to learn to use them, and you CAN do finish grading with them just fine.
BTW, yes my skid had tracks...
SR
/ Case 1150 dozer #14
SR
We have a trac hoe remember? The trac hoe can knock down and pile an acre of trees while the dozer is still trying to get the first one down. Trac hoe is big with a thumb on it. Picks up big trees and piles them. Whole trees stump and all. Plus you can pick up and drop stumps to knock dirt off them for burning. Plus sometimes we cut stumps off and take to one spot with the ss and the th piles them like a tee pee, burns good. Try that with a dozer. They brought a case dozer on the last job we were on. But with three skid steers and two big trac hoes, we only cranked it when we loaded it up to leave, two weeks later. I guess if both hoes got stuck we might have used it.
/ Case 1150 dozer #15
NO argument from me on a track hoe, but THIS is your post I answered,
[They are way cheaper than that. Just look around a little. They are becominga dinosaur. A skid steer with tracks will work circles around that thing. Skidsteer will not do as much at once but will make five trips before you get that thing across a field. Just rent a trac hoe to knock the trees down and do the rest with a skid steer.]
See anything about a track hoe in there?
SR
/ Case 1150 dozer #16
SR
The next to the last sentence. Second one up from the bottom.
/ Case 1150 dozer #17
My point was/is, you are comparing a hoe AND skidsteer to a dozer, then claiming the skidsteer is much better.
Do you really think that's a fair comparison?
No matter, different strokes for different folks.
SR
/ Case 1150 dozer #18
SR
Right he can keep the skid steer. Just get a trac hoe for a couple of weeks per 40 acres and he should be cooking with grease. I had a D 7 for years with a winch. Pain to move. Work on it down in the woods where it falls apart. A front idler split on me 1/4 mile in the woods. Had to break tracks right there. Move blade off of it. Jack up remove front idler. Drive way off and find another one. Come along and bindered the track together. Or it started blowing water and it had cut the sleeve in the engine. I fixed that. It started easing out of gear, fixed that. Oh take a radiator out and repair it. Water pump started leaking, that was fixed by me too, tough because big water pump. And that old dozer still goes. But, I don't want it. I can say I know a lot about dozers though.
/ Case 1150 dozer #19
I've had a few dozers too, including a D-7, but mine was quite reliable.
The 450 I have now, has been a very good dozer, but it's been taken care of too...
SR
/ Case 1150 dozer #20
SR
There is a nice 450 JD here. Final drives slipping a little but looks nice and runs good 3,000 bucks. But our big skid steer weighs 13k and it will load feed mixers, dirt, pile with grapple, run Bush hog and mulcher, run hydraulic auger, haul it to storms all over the country and clean up, load lumber at the saw mill, stack and put out hay for 3,000 cattle. That's just the things we do. Dozer you can only push and drag. You gotta make every move count because it's metal to metal and wearing out.
2016 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2016 Chevrolet...
RIDGID AIR COMPRESSOR (A68842)
RIDGID AIR...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
Set of 4 Unused 12-16.5N.H.S. ForeRunner Skid Steer Wheels and Tires (A66734)
Set of 4 Unused...
