Diggin It
Super Star Member
Housing rental inspector? What’s that.
It's why so many of us no longer live in cities.Holy cow…..What crazy rules. Would drive me nutz
So far city has frozen increases and evictions.
If tenant were to freely vacate home would rent easily for $800 a month more... just like SF with some paying $600 and the identical apartment down the hall is $3,000
Yes… with Load Tester.I expected that was the case when you made the first post. I wouldn’t pay a dime for a new refrigerator or to add additional circuits. It meets electric code. He can pound sand or spend his own money if he doesn’t like it. Did you perform a load test? Just measuring voltage doesn’t prove a lot. Try plugging in a hair dryer and measuring the load at the same time. You should probably use the low heat setting for a fair test since bathroom circuits are 20 amp therefore a hair dryer wasn’t intended to work on 15 amps.
I'd rather pay to upgrade the house than to pay to buy a fridge or freezer.
current passed but voltage drop failed… i.e. exceeded 10% drop.
Now, place an amp meter on the heat gun plugged directly into outlet, then read it when plugged into extension cord.Just out of curiosity I did a load test in my garage which is 12 gauge wiring. Under no load 123 volts. Running my heat gun on full output it dropped to and maintained 116 volts. Then I plugged in a 25 foot 14 gauge cord on the same outlet and repeated the test plugged into the cord. This time it dropped to and maintained 111 volts. That’s actually less drop than I expected although the test didn’t last long. I would expect it to drop more as the cord heated up.
