Patio Refrigerator and Freezer Question?
/ Patio Refrigerator and Freezer Question? #21
Get a new tenant.
/ Patio Refrigerator and Freezer Question? #22
Get a new tenant.
Not so fast there Mr bob,tenants that say on for 12 years are hard to come by. If it came to a choice between kicking him out or caving to his request,I'd furnish a freezer and ask him to keep it indoors.
/ Patio Refrigerator and Freezer Question? #23
I also don't believe this to be your problem.
However, as capable as I'm sure you may be, do you think having someone who's labeled as a professional electrician on paper comes out, checks the outlet, says there are no issues with the wiring or the house would satisfy them?
I don't think it's an expense you should HAVE to incur, but I wonder if it would be the most reasonable and least confrontational way to put it to bed for you. Keep the tenants and not have to buy a freezer or a fridge.
/ Patio Refrigerator and Freezer Question? #24
How did the tenant conclude the house is killing his appliances? Could it have come from those 2 good-for nothings I Herd and Tha Said?
/ Patio Refrigerator and Freezer Question? #25
I agree that the problem is probably the undersized extension cord, but I would also want to know if mice have moved in and caused problems? Leaving it outside just screams to me as a place that mice would want to live.
/ Patio Refrigerator and Freezer Question? #26
Depends on the extension cord. I have a refrigerator in the garage on a heavy extension cord that I made from romex wire with 12 gauge plug ends.
Yes, a proper size extension cord can be used , but most people don’t have a 12 ga cord.
/ Patio Refrigerator and Freezer Question? #29
/ Patio Refrigerator and Freezer Question? #31
They sell 12 g extension cords, but im not sure they sell short ones, I usually see 50 to 100’. No appliance should ever tun on extension cords that you usually see at HD or Lowe’s. Most of these are 14 or more usually 16 ga wires.
ive had some lazy employees run my hole hawgs on 16 ga HD cords and burn out the motors.
and if you’ve reciently priced out refers and freezers…. Maybe need new tenants. If you give into this, what will they try to get you to replace next.
now, when I wire additional refer and or freezer circuits in for clients, it’s ALWAYS 1 appliance per circuit.
/ Patio Refrigerator and Freezer Question? #32
Just to make sure all the facts are clear, your tenant had BOTH a chest freezer AND a refrigerator plugged in to the SAME outlet?
And this was a 15 amp circuit?
If so, there is your problem. No amount of extension cord size is gonna fix that.
You can't even do that inside the house.
And the circuit breaker for this outlet never pops?
/ Patio Refrigerator and Freezer Question? #33
6-ft 12/3 Heavy Duty Lighted SJTW Indoor/Outdoor Extension Cord by Watt's Wire - Short Yellow 6' 12-Gauge Grounded 15-Amp Three-Prong Power-Cord (6 foot 12-Awg)
Saw this on Amazon.
4.8 out of 5 stars
1,449
/ Patio Refrigerator and Freezer Question? #34
Go to home depot and buy x feet of romex and plug ends. Make a cord.
Plug ends are needless expense and get in the way while rolling cord up for storage. Run stripped wire though holes in freezer plug and crimp them over then flatten wires on other end so they slide into outlet easier. It's called hard wired and reccomended for permanent or semi-permanent applications. It works for drills,hedge clippers and vacuum cleaners but often come loose causing you having to stop and reconnect so it's a good idea to add some tape.
/ Patio Refrigerator and Freezer Question? #35
what part of Kentucky were you from?:)
/ Patio Refrigerator and Freezer Question? #37
a few months ago my 24 yo upright freezer failed. we had just got home from a horse show and still had horse trailer attached. i got on the phone and called every store in town. only 1 store had an upright in stock. bought it sight unseen and drove there and loaded it into the horse trailer. luckily i had a alarm on the old freezer so i found out about failure before all food defrosted.
in the mean time i ordered a new defrost timer and thermostat from the repair shop. took 3 weeks to get parts due to covid shortages. but i fixed old freezer. now i have 2 freezers....always have a back up now.
/ Patio Refrigerator and Freezer Question? #38
Tell him to read the owner's manual of the failed unit regarding extension cords and environmental conditions for use.
Definitely check the manufactures installation/ operation manuals. Many won’t allow extension chords and have statements about being installed outside/ wet environments.
/ Patio Refrigerator and Freezer Question? #39
google and other sites have translators.
Explain that extension cords are not meant to handle one appliance much less 2 and will burn out a motor. In fact, it is dangerous to them and your rental home.
Offer to have an electrician install 2, CFCI outlets on that porch at your expense.
If this appliance was there when they moved in, then its on your dime.
If you have provided frig/freezer in the kitchen, and they brought this on their own, then this addition is their responsibility just like a hairdryer or tv.
If you feel it is in your best interest to replace this, I guess you can but as others have said, you are signing up for universal warranty replacement.
/ Patio Refrigerator and Freezer Question? #40
While I agree that a GFCI is needed for out door use, or at least the out door plug be protected by a GFCI up stream. I have to disagree about using an extension cord for the appliance.
I have a 12/2 extension cord that connects to my freezer and fridge for the last xxxx years. The wall plug is also connected with 12/2 wire
Those small compressors 1/4 hp ? don't pull much juice. I can operate three of four of them plus lights, etc, off my 5500 watt generator
