Disc Harrow Restoration Tips
/ Restoration Tips #1
Cuttingrass
Central Florida
Bobcat 4045 Shuttle
Any recommendations where to find parts for a functional restoration? Bearings, disc pans. I’d also welcome tips on rust removal. Is this a job for sand blasting?
Model MF 21. It looks like the frame rust is surface only. It was buried in the woods for 20 years. Manufactured in Detroit, probably in 50’s.
/ Restoration Tips #2
Agri-Supply should have anything you need to rebuild that harrow.
/ Restoration Tips #4
I'd use it first to see if everything works. They are very simple.
Bearings and races from any bearing shop. They just need numbers off the bearings.
To restore it dis-assemble and drop it off to a sandblaster. if you want you could even have them prime it for you.
/ Restoration Tips #5
Thank you. I wasn’t aware of Agri Supply. They do seem to carry numerous parts for disc harrows.
If you get ready for a road trip, run up I-75 to Valdosta to that Agri-Supply and give yourself plenty of time to shop, if you have never been in one you are in for a treat, you will find the disc parts section, it's an area about the size of a baseball diamond.
3 Brake Drums (A62613)
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
Athey 7-12 Force Feed Loader (A62679)
Athey 7-12 Force...
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
