kenmac
Super Member
- Joined
- Feb 13, 2005
- Messages
- 9,965
- Location
- The Heart of Dixie
- Tractor
- McCormick CX105 Kubota MX 5100 HST,
anyone here ever seen a push fit (almost like a shark bite) hydraulic fitting ?
Are you referring to a compression type which is available or an actual shark bite.anyone here ever seen a push fit (almost like a shark bite) hydraulic fitting ?
No, it's not a compression fitting. It's a male fitting on the hydraulic hose, and it pushes into the hydraulic diverter valve and locks in place.Are you referring to a compression type which is available or an actual shark bite.
If you talking about a regular air line fitting where you must pull the outer part back on the female coupling to disconnect the male fitting ? That's not the case with this type hydraulic fitting.Tons of pneumatics are done that way. It is basically the industry standard for any industrial pneumatic lines and connections. Can't say I've seen it on hydraulics, but I sure haven't seen all that much in hydraulics...
yeah, that's it !!! Thanks !!!WEO fittings. Alo/Quicke uses a ton of them on their loaders.
New Holland and Quicke sell adapters with a male WEO fitting on one end and male JIC on the other. I used to stock them so we could make up replacement hoses with JIC fittings and use the adapters. Far better than ordering complete OEM hoses and being down until they arrive. Note there are at least two sizes of WEO fittings that ALO uses.yeah, that's it !!! Thanks !!!
It's on my Quicke loader diverter valve .. No one I have talked with has never seen one. Now I know the name or what it's called I may be able to buy some for when ever I need a hose made.
I broke a hose and no hyd shop I went to had ever heard of or seen that fitting.
Thanks for the info on these. Sad part is, they require $175.00 order to be able to order. LOLNew Holland and Quicke sell adapters with a male WEO fitting on one end and male JIC on the other. I used to stock them so we could make up replacement hoses with JIC fittings and use the adapters. Far better than ordering complete OEM hoses and being down until they arrive. Note there are at least two sizes of WEO fittings that ALO uses.
A search turned up this example.
14-727-1212 CEJN Nipple Adapter, 3/4” WEO x ½” Male JIC 37° (Thread Size: 3/4”-16 UNF)
Part #14-727-1212 CEJN Nipple Adapter, 3/4” WEO x ½” Male JIC 37° (Thread Size: 3/4”-16 UNF)www.gghyd.com
