New Stihl?
/ New Stihl? #21
Another recommendation for the 261cm Plenty of power and very light weight. Used to have a ms290
and the weight really makes a difference after working a few hours
/ New Stihl? #23
my brother has done tree work for decades and brings his saws over anytime i am cutting. His go to is the 261, he also says all his co workers always grab those saws as well. they have access to almost all the saws in stihls pro lineup but always go to that saw because of its power to weight. when he is cutting big wood he goes with the 660 but that is almost the only time, unless climbing he uses the 200t. i will admit the first time i held the 261 it felt like a toy because of the weight, but it beats my larger dolmar every time.
/ New Stihl?
I looked at the 261. The dealer said I would be stepping down in power from my 029 and the 291 might be a little more due to the 029 being 27 years old. I don't cut that much, just in the fall and winter. The 029 has been a good saw, just getting tired if not having the power for the bigger stuff and dead ash. I do like the weight of the 261. The 311 seems heavy, but is about the same as my 029.
/ New Stihl? #25
It's a long story, but a neighbor gave me a basically new MS390. It's heavy, but I equipped it with a full chisel chain and 20 inch bar and for doing large stuff it is a great saw.
/ New Stihl? #26
I've got an older MS361 20in and a newer MS362C 20in and love them both (they were expensive but I've gotten great use out of them both). I didn't like the 362 at first because of the computerized carb stuff... but after a few days of getting the saw acclimated (and me acclimated to the newer tech)... I love it now. Easiest starting/restarting of any saw I've had.
/ New Stihl? #27
I have a Circa early 90s Stihl 029 and a MS391.
the 029 can sit for months in cold weather and will start with 3 to 5 pulls.
the 391 is a much different story, that sucker needs to overnight in a warm environment to have any chance of starting. Once started and warmed up it performs as advertised. Bottom line, the 029 is still my ‘go to’ cordwood saw.
/ New Stihl? #28
Stihl doesn’t provide the most bang for your buck that’s for sure.
Nothing bad to say about Echo; have a pole saw I like.
But I also still use 2 almost 40 year old Stihl 024(great great granddaddy to the MS261). Older Pro saw that still work great and has cut A LOT of wood. That saw has provided decades of bang for the buck. That was an expensive saw 40 years ago, but I think we got our moneys worth :D
It depends on your use, and how it is amortized over time...
/ New Stihl? #29
I bought a Stihl 029 in 1995 or so, was my one and only saw used it tons. The plastic handle cracked but that was my fault. About 8 years ago my boss had a much newer 029 that his son in law ran straight gas in, cooked it. I put my motor into the MS290 case which meant I got flip caps (best thing)!! But its still the motor from 1995, and still running today. Saw can sit all summer in the basement with ethanol free gas in it, take it out in the fall, 3-5 pulls she's running like a champ, every year. As a back up to my 029/ MS290, I bought a MS390 thinking I needed a bigger saw, & it was, but I was mostly disappointed with the saw, it would run 20" bar ok I guess, but anything longer, or a less than perfect chain it just didn't have the oomph to go through hardwoods. I found my self running the 029/MS290 all the time anyway. I did appreciate the compression release though when starting the MS390. Recently I bought a lightly used MS361 PRO saw and after running it the first time, I sold the MS390 and am not missing it at all. So my unprofessional opinion is, if your 029 is about to be retired and even if its occasional use, go with the MS261 PRO saw, you will not be disappointed, more power, and less weight than the 290, yeah its more $$ but you won't ever think to yourself, should have went a little bigger. I would not even consider the MS390 as an option, a couple more lbs, but not enough power to justify the weight & extra size.
Besides some of us might need your 029 for parts someday!!
/ New Stihl?
The 029 still runs fine. I'll take a look at the 261 again. As I get older, heavier isn't the way I want to go. Maybe the 261 with a 18" bar and stay away from the big stuff. I plan on keeping the 029 as a backup.
/ New Stihl? #31
I sold my 029 due to it being as heavy as my 361 and there is no comparison. I use my old 026 pro with a muff mod for all smaller stuff and limbing. It would run with the 029 any day at much less weight. Some of the equation is how well the saws are tuned.
/ New Stihl? #32
Just playing with ya on the 029, at this rate mine may never need parts... With the 261, you can run the 18" bar and cut a pretty big tree, there are techniques to minimize the holding wood so you can get a darn big tree on the ground with a shorter chain. I am also assuming you could put a 20" bar on it for those occasionally larger tress, and just cut from both sides.
/ New Stihl? #33
I'm on my third Stihl 261 with 20-inch bar. The first one froze the engine just short of the 2 year warranty. Stihl didn't replace it, instead they sent the dealer parts to rebuild it - lasted another year. About three years later I pinched the second saw in a large (about two foot) horizontal spruce limb, torqued the bar and broke off the shaft, unfixable. I'm on my third one - they may not last, but they are the right size and power. Be sure to buy the hi-grade Stihl mix six-pack (the grey bottles) at the time of purchase - homeowners (not pros) get a one year warranty extension with that. Essentially Stihl expects their pro saws to last a year or so with everyday use; they expect their farmer/homeowner saws to last a couple of years with occasional weekend use. The main reason for buying a stihl in our area is that there are no other dealer serviced brands available.
/ New Stihl? #34
You can't blame Stihl longevity on you pinching the bar in a spruce limb and mangling it beyond all recognition.... That's what is called "User error".
/ New Stihl? #35
I have had 2 Stihl saws, a MS 250 and a newer MS 261. I have a 18 inch bar on both. The 261 easily pulls an 18” bar, the 250 not nearly as well. I’m pretty sure a 261 would pull a 20” bar well also. If you need bigger than a 20” bar, than I’d step up to a bigger saw.
The pic is some “noodling” I did with my 261. With a sharp chain it cuts really well. I noodle the bigger stuff so I can lift it up on my splitter, it’s horizontal only.
/ New Stihl? #36
I run a 20 inch bar on both my 290 and my new 261. The 290 worked fine ...but the 261 works better because it has a more aggressive chain.
Cheers,
Mike
/ New Stihl? #37
I'm more than impressed with my MS261 m-c and the MS362 m-c. 18" and 20" bar respectively.
Replaced a long-lived Farm Boss 041 that was an impressive saw for 30+ years.
Had the MS250 before the MS261 became available, and it to was a faithful Stihl saw. Never a complaint how that saw would run and run.
/ New Stihl? #38
I looked at the 261. The dealer said I would be stepping down in power from my 029... I don't cut that much, just in the fall and winter. The 029 has been a good saw, just getting tired if not having the power for the bigger stuff and dead ash. I do like the weight of the 261...
According to the specs your 029 made 3.7 hp when new, a MS 261 C-M makes 4 hp.
Interestingly I have the same two saws, after just buying the MS 261 C-M. I run an 18" bar on the 250 but using the whole length works it pretty hard. My 261 came with a 20" which it runs better than the 250 does on an 18", as it should since the MS 250 only made 3 hp when new. I also bought an 18" bar and couple chains for the 261 and will probably use the 18" most of the time. Interestingly the 18" on the 261 is longer than the MS 250's 18".
For me the MS 261 C-M is replacing two saws my MS 250 (my main saw) and heavier 60cc Echo Timberwolf with 20" bar (only for larger stuff) and so far I think it's perfect for me. It's almost as light as the 250 yet much more powerful and smoother running, and will cut just as large of stuff as the heavier, buzzier, Timberwolf can.
/ New Stihl? #40
I'm not sure if there other differences but the chain for a MS 261 with 18" bar has (I believe 6-8) more links than one for MS250 with 18" bar.
2016 FORD F650 ROLLBACK (A59909)
2016 FORD F650...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61568)
2016 Freightliner...
UNUSED INDUSTRIAS AMERICA HI-1100T TILT LAND LEVEL (A62130)
UNUSED INDUSTRIAS...
2023 New Holland C327 Compact Track Loader Skid Steer (A61567)
2023 New Holland...
16ft Equipment Trailer (A61165)
16ft Equipment...
2023 CATERPILLAR 259D3 SKID STEER (A62129)
2023 CATERPILLAR...
