Oversized cylinders on my ck2510
/ Oversized cylinders on my ck2510 #1
Zmann.
Kioti ck2510
I really had no use for the larger ck2610 and while researching I had thought the ck2510 would handle a heavier pallet than it actually could
hydraulic wise not counterbalance since having a backhoe makes that a non issue
the only reason I needed a little more FEL lift is once in a while I can rent my tractor out to my company instead of renting a forklift
but after trying a few things around the house like loading a 600 lbs safe into a 2' high trailer and just barely getting it up high enough
and then trying a few pallets with 400-500-550 lbs to see how high i could go I realized that this was not going to work for unloading pallets from a semi
I did bump the hyd psi by 250 psi but no help so I started looking around and found some Magister ready to ship 2.5 cylinders with a 12" stroke that were close to what I needed , I had to cut off and reclock/space the end tube and the worst part was the sae to british threads I had to get new lines made to do the transition
anyway when I was done there was not one of those pallets I could not lift to 50" with ease and even lifted the front of a vehicle off the ground that I had tried before and couldn't budge
we should all know this kind of modification is at your own risk, and you really need to pay attention to ballast and front tip potential not to mention you may be exceeding other structural limitations as well and the whole FEL assembly could collapse and impale you.
lift speed and lower speed was reduced minutely , but I always thought it was too fast anyway and this is more controlled
my tractor has 340 hours and I just bought it so I do not know if lift capacity has diminished since new but the hyd psi is just over spec
the FEL would bleed down overnight when i tested it and one cylinder had a slight drip but no damage.
now the FEL will maintain height overnight ,, if that even means anything ?
/ Oversized cylinders on my ck2510 #2
I'm surprised there isn't a crazy long slew of replies here lol! Both the kind interested in what you did and those condemning the whole idea... (Although you clearly outlined all the dangers!)
Sooo all that aside, I'm curious to know how it's been working for you, have you done any tests to see what weight you can lift to what height? As I sit here typing away I'm pondering the physics behind it - I'm guessing a cylinder with the same range but larger diameter will lift more while being slower? (Is that an accurate statement?) If so it would be interesting to know the specs of the stock cylinder in comparison to what you put on. Exactly how close are the open and closed dimensions? Just wondering if you lost any height?
I previously had "boxes" of firewood (a pallet with 2 pallets vertically on 2 ends filled with firewood between the vertical pallets, with a 2 straps at the top to hold the vertical pallets from folding out.) - I don't know the actual weight but with even when the hardwood was seasoned the loader at best could just get it off the ground (CK20s) a little bit while using the 3 point hitch to lift them was no problem - So I know it was less then 1400lbs... My forks - I had made my own pin on that I would swap my bucket off to use - the design maximised the limited lift capacity - one of my beefs with these small tractors using the stock skid steer QA options out there. In the end given I had to stack pallets I made the top layer about a foot shorter and that the loader could lift up at least 4 feet or more - I never tested the max. Having said all that... I tried to not travel too far carrying a full load like that, in general I try to limit that as it puts a strain on everything loader, axle etc. But like you I am not against the idea of just a little more...
Last thought! The Ck2610 - Originally comes with the KL2610 loader which has a max capacity of 1252lbs BUT from the dealer you can instead get the same tractor with the KL4010 loader with a max capacity of 1835lbs! So in that case Kioti actual warrants the tractor to be able to lift more which is no surprise given between the models in that line-up the only real difference is the motor - the tractors are all physically the same otherwise. My point being that your increasing the capacity of the loader on the CK2510 might still be within it's actual capacity. (I say might given we don't have actual numbers here.) Personally given how beefy the CK2510 is I think it could safely lift say 200lbs more - with the proper counterweight.
Anyway, like I said at the start of this diatribe I'm interested to hear how things are working out...
E.
/ Oversized cylinders on my ck2510 #3
I’d be super concerned about front axle, bearings, cv joints, etc. big money once broken. Not to be a Debbie downer but fork lifts have their place as you know and SCUTS have their place.
/ Oversized cylinders on my ck2510 #4
Overload your equipment - something is bound to break. All you did was change the formula.
Good luck ............
/ Oversized cylinders on my ck2510 #5
The original cylinders were 45mm cylinders. So a pair of them at 2500psi has a push force of ~12,300 pounds.
You went to 2.5" bore cylinders and a pair of them have a push force of ~24500#
You have doubled the force the cylinders "can" exert on the loader...
That doesnt mean you now have double the lift capacity. If means you have MORE than double the lift capacity due to the static weight of the loader not also doubling.
In other words....you say that you could lift a 600# safe 2' high with the old cylinders. Lets say that those cylinders were reall capable of 900# and that 300# is what it takes to lift just the empty loader and pallet forks. SO you had to have 900# capacity to actually lift 600#.
You doubled that 900# and now have 1800# of capacity.....but the empty loader still only takes 300# to lift. So the result is yoy can now ACTUALLY lift 1500#.
So by doubling the force of the cylinders....you actually yield about 2.5x's more usable capacity.
For what its worth....most manufactures dont start using 2.5" bore cylinders until 50-60 horsepower utility tractors that weigh twice what your tractor weighs. I hope this is just a case of going overkill and you never actually plan on using the full capacity of the cylinders. You backhoe is no longer sufficient ballast to keep the @$$ on the ground. And when it comes off the ground, the entire weight of the loader and load as well as the entire weight of the tractor and backhoe is all all on the grossly undersized front axle and tires.
If you just need a few hundred pounds more capacity, and respect that, you should be fine. but even the 4010 loader kept it modest at just under 2" cylinders (50mm) which would have been about 24% more power from the cylinders and about 50% more usable capacity as opposed to the 250% more capacity you gave it.
/ Oversized cylinders on my ck2510 #6
I have considered doing just what the O/P did, for the added capacity, but haven't taken the time to do the math on the size required. I do know that if I did the change, and had previously upped the pump pressure, I would probably let the pressure back down to original status.
David from jax
/ Oversized cylinders on my ck2510 #7
You don't mention if you are using clamp-on pallet forks or quick connect forks. Using the clamp-on forks my lift is much reduced but with the way it sticks way out there I don't think I'd want to lift more. Too unstable. The forks are a once-in-awhile use so not important to me to lift more. With sufficient counterweight (BH) my FEL will lift a full bucket of river stone, gravel or wet soil.
/ Oversized cylinders on my ck2510 #8
It has SSQA on the loader, so only a dummy would still use clamp-ons.
I just upgraded tractors, for the main reason to gain loader capacity and obtain SSQA. But! I do have to say, having the compact forks that much closer to the tractor front end does make it a bit harder to see what I am doing.... Been jamming into a lot of pallet wood, still need to get better at my new controls.
/ Oversized cylinders on my ck2510 #9
LD1 - some good info there, thanks. One question - so just because the cylinders are capable of pushing 24500# vs the stock 12300# is the hydraulic pump capable of getting the cylinder to that maximum? Showing my ignorance here - I understand that a cylinder would have a max it can push but I would have thought a pump would also have a limitation? And/or the hp required to drive the pump to hit that maximum on the cylinder? - Or is it simply as long as the hydraulic system is capable of maintaining 2500#pressure then based on the capacity of the pump it will in time get the cylinder to it's max?
/ Oversized cylinders on my ck2510 #10
You have to first understand flow and pressure and how those are created and how they effect a cylinder.
Hydraulic pumps don't make pressure. They make flow. Your tractor spec is 11.3gpm. I'd guess some of that is power steering flow....on a tractor your size it's usually around 7.5gpm for implement flow (loader, 3ph, etc).
That flow would be at PTO speed. These are positive displacement gear pumps so each revolution of the engine moves a given amount of oil each time. Barring any inefficiency, 1000rpm is gonna flow half the oil that 2000 rpm gets you.
With the tractor running at at PTO speed, you are flowing 7.5gpm no matter what you are doing. If you are doing nothing, you have no pressure. 7.5gpm is simply coming out of the pump and going back to the tank.
If you are doing something like raising the loader....7.5 gpm gets diverted to the loader cylinders and they fill up causing the loader to lift. A 12" stroke, 1.77" bore cylinder like your stock ones takes 0.127 gallons of oil to extend. There is two of them, so the time it takes your tractor to pump 0.254 gallons of oil is the time it takes to fully raise. Or about 2 seconds.
The new cylinders at 2.5x12 take double the oil to do the same thing....thus twice as long. In other words, the cylinders...to get double the power, move at half the speed.
That's the effect of flow on cylinders. Flow = speed. More flow is faster. Less flow is slower. That's why idling down make things move slower.
Now pressure. Remember the pump only makes flow. Attempt to stop that flow and you build pressure. Trying to raise something with the loader is an attempt to stop the flow...so pressure builds. One of two things happen ...either it builds enough pressure to lift, or the relief valve opens to protect the system.
Without a relief valve, there is no limit to the pressure it will build. Remember...every revolution of the pump HAS to move that given amount of fluid at a rate of 7.5gpm. without the relief, pressure will build until something can no longer contain the pressure and let's go to allow fluid to move. Maybe a blown hose, crack the pump, etc. The relief valve is the intentional weak link in the system....usually set somewhere around 2500psi so bad things don't happen.
So with that said, you have a contained system capable of 2500psi. A hydraulic cylinder has a round piston that 2500psi pushes on. Figure the area of the piston....(pi x r-squared) and now you have the max capable force the cylinder can push with.
By going bigger, you have doubled the area of the piston, this doubling is capable force. The pump and relief have no idea what size the cylinders it's supplying are. It simply moves fluid at a given rate, and the system relief won't let pressure exceed 2500,psi. Do there is no other protection for your machine to prevent you from trying to lift way more than intended.
Let's say your max with the old cylinders was 600 pounds on the forks. That weight cause the system to need all 2500 psi to lift.
With the new cylinders, you can lift that SAME load with only half the pressure. Which means you have 1250 psi to spare to lift even heavier stuff. Which isn't a bad thing, and not a huge concern if you are only lifting pallets of known weight because you can know to be cautious. The issue would be doing something where you have no idea how much force you are exerting....like digging in the dirt, or trying to dig out a stump.
Sorry for the novel.....are you even more confused or do you understand?
/ Oversized cylinders on my ck2510 #11
Great post thanks! So to sum up the bigger cylinder takes twice as much time to move but that allows it to apply twice as much force assuming the remainder of the hydraulic system remaining the same.
So theoretically if one were still interested in playing the game you'd look for a cylinder that say had a 10 or 20% increase, which would still give a bit of a boost understanding that you're going to be operating likely close to the max and no longer having much safety headroom as you would in compared to stock. (There in being the million dollar question - how much extra capacity is there till things start breaking - axle, loader etc.)
And agreed the biggest danger is not lifting a skid with a known load but pushing into the dirt and then lifting with unknown forces pushing against the loader.
E.
/ Oversized cylinders on my ck2510 #12
Kioti didn’t use 2.5” cylinders for a reason. You might get by with a little bit of lift increase but it’s a pretty safe bet the tractor wasn’t designed for that margin of overload. Have fun fixing the front axel or busted FEL. If you wanted a forklift you could have bought one for less than it’s going to cost you when you break the tractor.
/ Oversized cylinders on my ck2510 #13
With regards to flow and pressure, pressure can also be limited by motor, in other words if lucky, motor stalls prior to failure. In this case with big hydraulic cyls 2500 psi is plenty of pressure to destroy the tractor. And if you didn’t increase relief valve you’ll not exceed 2500 psi. Regardless. In summary you’ve created a ticking time-bomb and if lucky machine will fail without anyone getting hurt. Machines need to be used for their intended purpose and are designed as they are for a reason.
so excuse me for not addressing every comment
I have had these cylinders for months now and yes the next size up FEL would have been nice but not practical cost wise
yes I am aware of the added strains and mentioned them originally trying to circumvent the
'you overloaded your tractor" comments
end of the day the tractor is now a keeper before I was going to have to get rid of it because it could not do a job I only need it to do once every few months ,, thats unload some fixtures from a semi truck ,, 30 minutes tops
yes the operations are slower now but this does not leave me with time to ponder my next dangerous mod it is just a tad slower and sometimes that's a good thing
would I do it again .. yes ,, would I recommend others do it = no
will I break somthing ? not likley .. if I sell it will I return to stock ? maybe I have all the parts but I will inform the new owner whats been done
and now for my next mod , it is an electric mixer on my FEL because I don't like the PTO mixers
no one here has told me anything I did not already take into consideration , I will post back if I break something, so naysayers please hold your breath ;-)
/ Oversized cylinders on my ck2510 #18
I have a little experience with oversized loader cylinders. In 2012 my boss got a killer deal on a l3540 with 400 hours. once i started using it i realized the bucket wasnt sitting straight. after a bit of inspecting i noticed that the right side cast steel mount had been snapped an poorly repaired. I also noticed that the curl cylinder mounts had been bent. and last, i noticed that the curl cylinders had been replaced with bigger cylinders causing the previous 2 problems. I went through and recut and welded the mount. later, the curl cylinder mount tore while i was on a job site and several years later the mount on the other side snapped.
There is a very big risk to larger cylinders than the loader was designed for. loaders are carefully engineered to not be any heavier than they need to be because excess weight on the front of a tractor is bad in several ways if you dont specifically need it. The tolerances just arent there to handle bigger cylinders.
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
Informational Lot - Shipping (A61306)
Informational Lot...
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
