Cloudy fluid
/ Cloudy fluid #1
Matt2796
Member
Mahindra Emax 25
Recently changed my fluid in my hydrostatic transmission and noticed fluid becomes cloudy after running tractor for a few minutes...was wondering if this is caused by the return oil splashing when entering the reservoir or there is water, cavitation, aeration?
/ Cloudy fluid #2
moisture, is the fluid clear before it gets run?
If so the water may have separated out, and cracking a drain plug
and trying to let out just a quart or so may clear it up.
/ Cloudy fluid
It is clear before starting it up
/ Cloudy fluid #4
Matt
Can you siphon or drain some of the cloudy fluid out into a clear glass container? This way you can observe better if air entrainment or moisture. Air you will tiny bubbles water fluid is typically milky colored and over time there would be separation layer of water and oil.
/ Cloudy fluid #5
It looks like there’s some water in the fluid. You could put some in a clear container and allow time to separate to verify.
/ Cloudy fluid
Took some out there is no sign of water...it seems to be air. Any idea how air could enter the system? Can find any leaks.
/ Cloudy fluid #7
How long did you let the container sit?
/ Cloudy fluid #8
Does the oil get cloudy with tractor sitting stationary and without PTO operating?
/ Cloudy fluid #9
Air not entering from leaks unless its on the suction side.
/ Cloudy fluid #10
That sure looks like water to me. Draining and filling with new, may take more than one cycle of fluids to get all the water out.
/ Cloudy fluid #11
Hmm, Recently changed hydro fluid and looks like it is now contaminated. I wonder what could have caused it. Not all THFs are equal. There are some really good ones out there, and really crap ones as well. A lot of water can come from condensation, usually from a faulty breather valve on the reservoir/transmission.
/ Cloudy fluid #12
It looks like air to me too. Microbubbles. Water is usually more opaque - it really can look like dirty chocolate milk.
Air goes away pretty quickly... The tainted fluid appears to rise up because the microbubbles make it less dense than the clearer de-aired hydraulic fluid. I've never timed it but that process takes hours rather than days.
Water takes days if it separates at all. Depending on detergency, sometimes it either doesn't separate or takes so long that I've gone on to other projects. If it does separate, I would think that the clear amber hydraulic oil is less dense - most oils are not as dense as water - and should float on top of the water.
As someone said, the only way air can get in is from the suction side - basically that means it has to be getting in somewhere along the path that starts at the bottom of the common transmission/hydraulic sump and continues up to the inlet to the hydraulic pump.
Typically that path will go from a cleanable crud filter inside the sump, out through a fitting on the bottom of the sump, up to a spin-on replaceable filter or even two spin-on filters in series - and from the last filter it goes directly to the hydraulic pump inlet side.
The suction line can be a rubber line although more commonly it is a steel line with compression fittings. We do see leaks sometimes associated with pinhole damage to the wall of the suction line itself, but by far the most leaks are in the end connections rather than to the line itself.
Look for suspicious places from the suction line as it exits the sump and goes to the filter, or from the filter to the inlet to the hydraulic pump . It is rare for the leak to be within the pump itself. Although I've heard of leakage past a rotating shaft seal and into the suction side of the hydraulic pump, it is fairly rare.
Don't even think of looking inside the pump itself until you are positive the suction leak isn't in the suction line or fittings.
HOW TO FIND A LEAK:
IF the suction leak is happening below the top level of the Trans/Hydraulic Fluid (THF) in the sump, then it will almost always be able to be seen as a wetness around the leak after the tractor has sat overnight. Wash it, let it sit, and look. That is where most are and how they are found.
If that doesn't do it, work your way up to the pump renewing connections and/or lines until you find the problem.
If it is the pump, take it to a rebuilder.
Good luck,
rScotty
Wooden Wagon Wheel Chair (A61569)
Wooden Wagon Wheel...
New/Unused Grapple for CFG Mini Excavator (A61166)
New/Unused Grapple...
2013 BMW 750i Sedan (A61569)
2013 BMW 750i...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
Kubota Snow plow with subframe
Kubota Snow plow...
CASE TV450B SKID STEER (A62129)
CASE TV450B SKID...
