Bolt Size Help
/ Bolt Size Help #21
It might be worth trying to screw in a piece of tight wood. When you take it out, you should be able to count the TPI or the pitch if its metric. Measure the maximum diameter as best you can, and then you should get some help on the actual size.
/ Bolt Size Help #22
I see some bolt heads on one of my B2150s that say "10.9" which I believe means it is a 10mm metric bolt with 9 threads per cm. Not that your bolt holes are that size at all.
/ Bolt Size Help #23
/ Bolt Size Help
nope the 10.9 is the grade not the size
/ Bolt Size Help
this may be an interesting idea if i have to, i think they make a substance just for this "casting" technique in a different application though.
/ Bolt Size Help #28
I usually resort to my tap & die set to find a bolt or hole size & pitch. Try different taps to see if you can get one that threads in. A tap works better than a bolt for this since it will clean paint and debris from the threads. Use care so you don't cross thread.
If all else fails, you can always drill & tap the holes for a larger bolt size.
/ Bolt Size Help #29
not same as mx. i have a m6060hd thanks
I know it's not the same machine. But the bolt sizes may be. The 6060 is only one step larger. Have you tried a 12mm bolt.
You said 16mm is too big, and 14mm is an uncommon size. Not saying it's not, but it's like a 7/16 or 9/16 sae bolt. They make em, they use em, but not that often.
That leaves 12mm.
You not doing anything to help us help you. What do you have at your disposal to try an figure this out. Do you have a tap and die set? Do you have some SAE bolts and can tell us what sizes in sae are too big and what ones are too small? Have you tried taking 30 seconds and pulling a bell housing bol and see if it worked? Or any other bolt on the machine for that matter?
My money still says you will eventually find out it's the M12-1.25 like I said
/ Bolt Size Help #30
I bet they are 12mm. The head size on a 12mm is commonly 19mm which a 3/4" wrench fits perfectly. That means the size is very close to 1/2" SAE, probably a little larger. Thread pitch is another matter. 1 and 1.5 is common but if it is a finer thread it may be a 1.75.
/ Bolt Size Help #31
I hope it's not nominally about 5/8".
5/8-18 and M16-1.5 are so close that you could probably start a bolt in the wrong hole and run it in a few turns. If you're using a tap for a thread gage, you could run it in even more, thinking there's gunk in there.
/ Bolt Size Help #32
Hello, I am trying to find the correct size bolts to fit my M6060 I am attaching a picture I found showing the bolts holes I am looking for. I have tries several sizes both metric and SAE but to no avail. And I have looked at the diagrams at Messicks and they are not shown. Anybody Know what size these are metric standard fine thread pitch etc. I need bolts to fit up in the two holes in front of this bracket someone else built in the picture. Thanks
My Ace hardware store has one of these, your GOOD hardware store may have one as well. Or buy one yourself, see link below.
/ Bolt Size Help #33
Actually, 1.75 is the coarser thread.
1.5 is fine and 1.25 is extra fine
/ Bolt Size Help #34
He said the M16 bolts he got were too big. That leaves 12 and 14. 14 isn't very common.
A 1/2" bolt will fit loosely in a M14 hole. It will be too be for an M12. So easy to tell those two apart if you have a simple 1/2" bolt
/ Bolt Size Help #35
12 mm is just under a 1/2. You’d be hard pressed to identify a 1/2 course thread from a M12-1.75 by eye without gauges. They’d probably thread together if forced. But you could just about bet the farm it’s not a 1/2 bolt in a Kubota unless someone changed it. On the subject of that I’ve had problems with my Grasshopper slinging the deck pulley ( the 1” bore pulley I put there after I broke the other one. Pretty much everything on the Grasshopper is SAE bolts including the blade bolts. So I falsely assumed the shaft was 1”. After it self destructed I was measuring to buy new parts and discovered the spindle was 25mm. 25mm is only 15 thousands under 1” so it wasn’t immediately apparent.
/ Bolt Size Help #36
If they are the same as my M7060, I'm thinking they are 14x1.5. If I think of it I'll check to be sure but it might not be until the weekend. Menards had them.
/ Bolt Size Help #37
I could be wrong but I though JIS was for hydraulics and pipes and such. Not really anything pertaining to nuts and bolt threads.
Hydraulic and pipe fittings are JIC.
/ Bolt Size Help #39
14 MM isn't that uncommon.
Our B3030 uses M14x2.0 for the grille guard attachment-think recent GM pickup wheel nuts.
Good Luck!
14' Cultimulcher (A66408)
14' Cultimulcher...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
2008 Chevy Trail Blazer (A62679)
2008 Chevy Trail...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
2011 UD Thermoplastic Truck (A64194)
2011 UD...
