Cougsfan
- Joined
- Sep 10, 2008
- Messages
- 1,650
- Location
- Eastern Washington State
- Tractor
- Ferguson TO35, Branson 4720CH
My TO-35 23c Standard diesel starts extremely easy after the engine is warmed up, but fairly hard when engine is cold, and nearly impossible when it is below freezing out. I have used a space heater and blanket in cold weather in the past, but that is a pain and only semi effective. I have been thinking about installing a block heater to make cold starting easier. There are lots of options and I am unsure of which to use. There are magnetic heaters that just attach to the block, there are inexpensive heating pads that can be put on the oil pan, engine block and/or battery. There are radiator hose in-line heaters at a rough glance seem to be the best bet. There are freeze plug heaters that seem that they might be "iffy" to install. All of these come in various wattages. I am not sure if heating the engine iron, oil, the water, the battery, or the fuel is most effective. I would guess heating the water is most effective. Any experience based advice would be appreciated.
