Bolt Size Help
/ Bolt Size Help #1
nwut05
Gold Member
SW VA. BRISTOL
New Holland T-1510, T 4.75
Hello, I am trying to find the correct size bolts to fit my M6060 I am attaching a picture I found showing the bolts holes I am looking for. I have tries several sizes both metric and SAE but to no avail. And I have looked at the diagrams at Messicks and they are not shown. Anybody Know what size these are metric standard fine thread pitch etc. I need bolts to fit up in the two holes in front of this bracket someone else built in the picture. Thanks
/ Bolt Size Help #2
Remove one bolt, take it to a good hardware store and find someone competent in the the nuts & bolts department who knows their business.
Alternative:
Buy a vernier caliper with metric and standard options, and metric & standard thread pitch measuring devices and measure yourself.
Cheers
/ Bolt Size Help #3
Is that a homebrew skid plate? What hole are you trying to attach it too?
/ Bolt Size Help #4
Do you have calipers and a thread pitch gauge?
Can you take a bolt out and take it somewhere like a NAPA.
Saying "metric standard fine thread" is a oxymoron. There is more than just coarse and fine thread with metric. Figure out the bolt diameter, and the thread pitch and you will have your answer
/ Bolt Size Help #5
Last time I shopped SAE bolts at Lowe's, they only carried COARSE threads!
/ Bolt Size Help #6
I'd try the Kubota dealer...
I think we all know SAE and metric threads, but there's also a JIS (Japanese Industrial Standard) thread. That might be why you can't find a bolt at the hardware store
Just something to consider...
/ Bolt Size Help #7
Sorry, nothing against Lowe's or Home Depot etc. but they do not qualify as a "good hardware store".
Yest they do have nuts & bolts but if he is looking for someone competent who can help him.....
Oh well, never mind.
/ Bolt Size Help #8
I could be wrong but I though JIS was for hydraulics and pipes and such. Not really anything pertaining to nuts and bolt threads.
Maybe there is? but I'd be 99.99999% sure its just a metric bolt
EDITING TO ADD THIS TO POST:
I MEAN TO SAY JIS IN THIS POST. YES, THERE ARE JIS THREADS FOR HYDRAULICS THAT ARE SIMILAR TO JIC BUT WITH A 30 DEGREE SEAT AND BSPP THREADS
/ Bolt Size Help #10
You are talking about the two open, empty holes in front of the orange bracket, right?
Are you sure they're even threaded? Why do you need bolts for those holes if there's nothing bolted on there?
/ Bolt Size Help #11
...but I'd be 99.99999% sure its just a metric bolt
Could be...but just measuring the thread OD (major diameter) isn't much help. The pitch is every bit as important...
Also, a Kubota dealer's service guy might be able to provide the info
/ Bolt Size Help #12
The black bolts into the housing are 99 percent metric. The other bolts through the bottom looks like “standard” bolts.
/ Bolt Size Help
Alternative:
Cheers
I would love to have the option to take one of those bolts out and take it with me to a good hardware store or a local fastenal. But That is just a picture I found showing the holes i am needing bolts to fit. I agree with everyone that they are most likely metric....and reason I want bolts is to make a skid plate like this home brew one. Also I do not currently own a good set of calipers and I have already tried several different bolts I have lying around and 16mm is close But they do not thread right. Tried local dealer they said to try a 16mm 1.5 pitch, ordered 2 from online supplier, as they are not a standard in stock bolt at most places, guess what, There too big! hence my delema....thanks
/ Bolt Size Help #14
He said in the post #1 he is talking about the holes in front of the existing bracket someone else mounted there. I have to assume he wants to bolt something on there using those two pre-threaded holes. If not, he needs to say so before we waste even more breath.
I found with other Kubotas (like mounting of MMMowers) that they often have threaded holes on the frame which are certainly metric and some at least (I think most) are fine thread metric. Worst case, measure the hole size and go buy a handful of metric bolts to try in the holes each with a different number of threads per cm. Tedious but eventually by cut and try you'll find one that not only fits the hole but will screw all the way in without feeling cross-threaded. It can be tricky. I had need for one more bolt in mounting a MMM, had a metric bolt which seemed to fit but would only go in a turn or two and then bind. Visually seemed no different than the other bolt which would go in. Took the other bolt from a sister hole on the frame to a well stocked hardware and found the problem was fine thread required vs coarse or whatever the others are called. Even a Lowes has a plate with "test holes" in which to screw bolts to determine sizes. Even trying to match up threads of two bolts side by side (fitting one's threads into the other's) can leave you mumbling to yourself and uncertain because the differences are so small.
/ Bolt Size Help #15
I would love to have the option to take one of those bolts out and take it with me to a good hardware store or a local fastenal. but That is just a picture i found showing the holes i am needing bolts to fit. thanks
Well, if its the same as a MX, I'll be heading down to my shop shortly and can tell you
/ Bolt Size Help
You have the correct understanding of what I am needing. Yes those empty holes in front of that bracket are what I am trying to find bolts for and yes they are threaded. However this is just a picture I found of someone else's tractor showing the holes. If I had tried to explain where those holes were without the picture I would have had a worse train wreck in the replies. thanks
  • Good Post
Reactions: JWR
/ Bolt Size Help #17
OK. The reason I wanted to clarify is that there were several suggestions to take a bolt out and take it to the hardware store. There's no bolt to take out . . .
Still curious --- are you planning to attach something there?
/ Bolt Size Help #18
Do you have a tap and die set. mine came with cool little thread pitch gauges that would help you find the pitch. it would be harder on a female thread but not impossible with a good light and especially since you say the hole is 16mm. there will be room for the gauge in the hole.
metric thread pitch is millimeters between the threads and use decimals so 1/1.25/1.5/1.75/2
I can try and check my grand L4740 but if this is for your new holland the results may not translate.
/ Bolt Size Help #20
Well....the MX holes are M12x1.25
My money says yours are the same.
Do you have a 1/2" bolt laying around. If it acts just a hair too big it's definitely 12. And you said it's fine thread so that would be a confirmation.
If your machine is like mine....the bell housing bolts as well as the rear axle to transmission bolts are also that size. Find one up top easy to get to, take it out, see if you have a winner. Take said bolt to hardware store if needed. Just don't forget to put it back
2024 Forest River Sunshine Enclosed Trailer (A62613)
2024 Forest River...
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
2021 Wacker Neuson G25 Quiet Power 20kW Towable Generator (A64553)
2021 Wacker Neuson...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
