/ Harbor Freight Tools that don't suck #14,521
I would really like to have a drill press, but I don't think I would use it often enough to justify spending a great deal on one.
Any thoughts on one of the more cheaply priced drill presses from HFT?
/ Harbor Freight Tools that don't suck #14,522
Bought the cheap hf 5 speed bench top one over 10 yrs ago, it was a pile of garbage. I could stop the spinning chuck with my hand on highest torque, slowest speed. A 1/2" bit would stop the motor trying to drill in soft pine. I won't even get into accuracy and runout.
/ Harbor Freight Tools that don't suck #14,523
Those are not good qualities for a drill press.
/ Harbor Freight Tools that don't suck #14,525
Similar results with the cheapest HF drill press from maybe a generation before yours. Near useless.
I've had good luck stepping up to Ryobi gear when HF's tool is useless. The most recent example was the cheap disc/belt combo sander. A couple of its adjustments didn't have enough range, to make the table slot parallel to the disc, for example. And too-wimpy power. Essentially a pretend copy of a real tool. The Ryobi is what that HF sander should have been.
As for impact wrenches, I like the first-generation Earthquake I just bought - on Closeout.
/ Harbor Freight Tools that don't suck #14,526
I got one of the table top ones about 20 years ago. Just needed it for 1 project, I was renovating kitchen and wanted to build cabinets with adjustable shelves with movable pegs. Don’t remember count, but hundreds of holes in MDF. Never a problem. Not long after I shipped it to my current location as I had started a building project. Drilled over 400 holes with forstner bit for railing stiles. Still didn’t kill it. Next project was some metal, extension for my boom pole. Sits on back of my bench, still available.
I think a lot could depend on use. I’m not much a metal worker so little experience there.
/ Harbor Freight Tools that don't suck #14,527
I've never done much metal work, but I have recently purchased the Titanium 125 welder and hope to start doing a little more. Small, simple stuff. My dad has a big miller MIG welder for any big stuff, and the years of experience to see that it's done right.
I've done some crude fabricating with a hack saw, angle grinder, cordless drill, and BFH. Now I find myself wanting a drill press to go with it, so I can still nice square holes.
/ Harbor Freight Tools that don't suck #14,528
Go back and buy the the 3 year exchange warranty!!! Half the posts I've seen about that welder said it failed after a while and they got a no-hassle exchange as soon as they walked in.
That said, I'm seriously considering getting one. (and the warranty!) The convenience of a 15 lb welder you can plug in anywhere would be a big improvement over the 240 volt mig I have that's a nuisance to roll out for a project. But I don't weld often enough to justify two wire welders and the big AC stick welder too.
But I'm tempted ...
/ Harbor Freight Tools that don't suck #14,529
But I'm tempted ...
Quick question On the exchange warranty, do you need to keep the receipt or can they look up the serial number?
/ Harbor Freight Tools that don't suck #14,530
It's linked to your name, phone number and email. No invoice needed.
/ Harbor Freight Tools that don't suck #14,532
I have a 20-year-old craftsman floor model drill press. The table not being perpendicular to the spindle tormented me. I turned it into a tabletop model I dug up my old tram bar from machinist days long gone and adjusted it so I could drill straight holes. I works great now after 19 years of hating it.
/ Harbor Freight Tools that don't suck #14,534
Wow the supply-chain problems must have bit HF hard. For the Titanium Flux125 welder:
In-store ONLY Available Online by Jun. 10
Please visit any store to order for Free Pickup.
Find a Store [The usual list of stores with stock, isn't shown]
IOW - not available before next summer.
/ Harbor Freight Tools that don't suck #14,535
Just purchased the Doyle Rivnut setting tool I give it an A+ only issue is it comes with a limited supply of Rivnuts and HF don't sell replacements.
/ Harbor Freight Tools that don't suck #14,536
But I'm tempted ...
I bought the titanium 170 a month ago and quite happy with it but I ended up buying Miller flux wire
/ Harbor Freight Tools that don't suck #14,537
i have the HF rivnut tool also. For occasional use that I need it for, it is a good value and works.
I found extra rivnuts on fleaBay.
/ Harbor Freight Tools that don't suck #14,538
Does anyone who depends on tools everyday all day long shop at Harbor Freight?
jmf
I have a friend who’s a welder. He buys the HF angle grinders. He says they last half as long as the Milwaukee brand, but they cost only 25% of the better brand, so he’s ahead.
/ Harbor Freight Tools that don't suck #14,539
Had a job where former boss bought the cheap Chicago electric 4.5" ones. used everyday, lasted a month or less mostly due to the gearcase stripping or exploding (have a bevel, spiral gear setup like most) he kept exchanging them unfortunately. Paying someone hourly to run to HF isn't the best use of time IMO, in comparison I own pretty beat up dewalt, makita and milwaukee grinders in my shop only had to replace brushes occasionally. Granted the Chicago electric line is the cheapest of the cheap.
/ Harbor Freight Tools that don't suck #14,540
I'll check that out today. Amazon has them as well but the quality is always suspect. Wish I had bought one years ago. My only issue with it is, it don't come with a drill size chart for the pilot holes but I have one of those continuous step drills I use for the holes and it fits nicely in the case.
John Deere TX Gator (A60462)
John Deere TX...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
New/Unused 72in No Till Seed Drill (A61166)
New/Unused 72in No...
2015 Caterpillar 430F 4x4 Extendahoe Loader Backhoe (A60352)
2015 Caterpillar...
wooden chair (A61569)
