Identify 1 cyl garden tractor with sickle bar & reel mowers, chain drive
/ Identify 1 cyl garden tractor with sickle bar & reel mowers, chain drive #1
the old grind
Super Member
Mid-Michigan
NH T-1520 HST, NH TC33DA HST, Case DX26 HST, .Terramite T5C, . NH L785
Engine in this guy is a Wisconsin single. I'm guessing it's 8 or 10 HP despite attachments. Belt drive to the transmission is on the left, & chain drive to the rears on the right under guards. Included are front blade and 'long-arm' mount, reel mower, and side-mount sickle bar. All look to be 36" wide at most, about matching o'all width. Rear rims look like 12"of not taller, fronts might be 8".
Note the size of the seat for perspective. Other than a nice 80% Classic Wisconsin decal we haven't spotted any identifying tags or numbers ... yet. What looks like a gearbox moves freely to three positions as if having F & R with a center N, no up/down mov't. Other operating controls aren't prominent. A heavy cylindrical gizmo Like a 3/4gal paint can might be seems to go with the sickle bar but that's also how it was loaded and why I didn't get better pics.
I seems we have a spare transmission and neither mount or drive for the sicke-bar.
/ Identify 1 cyl garden tractor with sickle bar & reel mowers, chain drive #3
Coming along for the ride to see what this beauty is.
/ Identify 1 cyl garden tractor with sickle bar & reel mowers, chain drive #4
Looks a lot like an antique Sears Garden tractor I had for a while, but not sure. Been years!!
David from jax
/ Identify 1 cyl garden tractor with sickle bar & reel mowers, chain drive #5
Speedex, not sure on exact model but. Maybe late 60's early 70's
/ Identify 1 cyl garden tractor with sickle bar & reel mowers, chain drive #6
I had one of them here. But I can't remember who made it. It was not a Sears.
Just talked to owner. Sickle bar label says Bready and hood/grill shape/contour matches their line vs Speedex. Haven't seen either brand (+ Strongland) with the double sheave on the drive side of the engine. Chain guards are a quick identifier, and close on several sites but no cigar.
The hood/grill seems to be in the way for using the front-mount 36" reel mower so the hood may have been replaced by a more common version w/o the drive for front implements. That said, bracket at left front of frame is likely for a clutching pulley.
/ Identify 1 cyl garden tractor with sickle bar & reel mowers, chain drive #8
Bready from Solon, Ohio.
David from jax
/ Identify 1 cyl garden tractor with sickle bar & reel mowers, chain drive #9
"I am sure that Bready built them but one is a Reo, one is a Homelite and the other one is a Gilson"
Maybe that quote will help? Apparently Bready was building for others?
David from jax
/ Identify 1 cyl garden tractor with sickle bar & reel mowers, chain drive #10
David from jax
Doesn't really look like the Bready drivetrain I'm used to. All the ones I've seen used a longer chain from the trans to the rear axle and the engine output on the opposite side, fram and front axle are different also.
That drive looks like Speedex athough the sheetmetal looks a little different from all the models I'm familiar with. Could be a random model that's not common, or someone changed out the sheet metal at some point? I don't remember Speedex rebranding but I can't find any of my books to look it up right right now.
Found this Bready (561?) while searching. I suspect it's a lower hp model with Clinton power. Ours has separate starter and alternator while this one has an apparent combo. (like my EZ-GO w/Robin) Our gen is in same position but the Wisconsin has a geared starter to the flywheel sitting above it. Both are tagged. "Ford".
This likely has magneto ignition integral to the engine. Ours has a tiny distributor and a car-type coil. There was only one pic, but this shows what we have and what we don't, why the mower & sickle bar won't have power.
Also, our hood doesn't tilt like some similar models. (See hinge at front bottom) I'm sure we're only one or two model numbers away from knowing what call it. We plan to move it indoors in a few and I'll get more pics, esp if/as requested.
I find the ACN engine to be 14.9 cu inches. (~250 cc). The distributor thingy is mounted where the magneto would be. It has a sister model the BKN with 7/8" vs 5/8" stroke at 17.8 cu in. Wisconsin hp ratings are 6 and 7 respectively at 3600 rpm per OEM instruction book and parts list.
WISCONSIN ACN INSTRUCTION BOOK Pdf Download | ManualsLib
I'm a go move it and get more pics for you guys who showed interest. Thanks! :)
2006 Toro SandPro 2020 Bunker Rake (A61572)
2006 Toro SandPro...
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59910)
2019 ISUZU NPR 4X2...
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
2012 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2012 TROXELL 150...
