My Industrial Cabin Build
   / My Industrial Cabin Build #2,681
I believe it’s 20 amp circuit, but outlets themselves can be 15A rated if multiple, unless a dedicated 20A load. For my fridge, I had to put in a single outlet, not a duplex. I haven’t looked at a code book in several years.
It looks nice recessed in a wall, but it’s hell trying to add circuits later. I have moved circuits many times in my panel since I built.
And the heavy circuits are closer to the main.
I cringe just thinking of the work to install the service entrance wiring to that panel.
Laying out the wires neatly into the panel in an art. Mine looks crappy.
   / My Industrial Cabin Build #2,682
I'm not 100% sure, but in residential work, isn't it code for ALL outlets to be only 15 amps now? Or maybe that is just bedrooms, etc?
I won't pretend to have kept current with the code since it became less important to me (in other words - my house is done!) but I have not heard of that limit. Residential has been allowed 15A rated devices (receptacles, GFCI's etc) on a 120V 20A circuit for a long time. A lot also depends on what version your state or locality has adopted. Few places seem to jump on the new code the minute it comes out so most places are behind at least one version, and new ones come out every 3 years. My first question when starting my permit was what version of NEC are we using now? I think it was 2 or 3 behind.
Just for giggles here was my panel when I was done with it. 200A 40 space. Actually I see there are a couple spaces there. It was all full when I was totally done, but I must have been waiting for a couple things when I got to this point. Mains fed from bottom, so I flipped it.
Dstig, that panel is impressive.
I am supposed to have an electrician at the house tomorrow. If he wants me to, I’ll cut a piece of osb, cover the hole and surface mount it. Wont take long.
   / My Industrial Cabin Build #2,684
I called the folks at Aqua sciences today. She priced out the stuff I need.
She priced a goulds pump that should give me 15 gallons a minute at 40 psi. At about 2950 and a goulds constant pressure system that would give me 15 gallons per minute up to 70 psi at 2750.
The constant pressure is appealing because there is no well tank involved. The downside is there is no reserved water if you lose power.
Anybody have experience wit this kind of system?
Yes I have lots of experience with pump controls of all kinds. Constant pressure is s good thing. But how you get it is important. The variable speed type pumps may seem to cost less up front because of the smaller wire, but that is just to entice you into purchasing the tar baby and get stuck with replacing it several times for several times the cost over the next few years. The Cycle Stop Valve is s simple mechanical and long lasting way to get good strong constant pressure. The CSV makes pumps last longer, uses smaller tanks, and is considered a disruptive product to the pump industry because it saves you so much money over the years.
   / My Industrial Cabin Build #2,685
Use a nice sheet of plywood instead of OSB. Make it big enough so you can staple the wires to the plywood.
   / My Industrial Cabin Build #2,686
Hi David,
Can you post the pump details from Aqua Science 15 GPM setup quoted as your well/pump will be at 190', 20 GPM output, and water averages around 70' as I recall?
The Goulds 7GS 3/4HP will easily pump 8-10 GPM, and the 10 GS 3/4HP will average around 10-12 GPM at the depth you are running.
You should look at the pump flow charts and for your application I would not get more than a 3/4 HP 10 GPM (10 GS series).
Definitely get the Cycle Stop Valve to prevent pump cycling and then a 8-12 Gal drawdown bladder tank, otherwise each time you run a faucet or use any water the pump will run - and the start/stops is what kills pump life.
I would keep the system simple and not get into the variable speed pumps.
Carl
  • Goulds 10GS15 Pump Chart.pdf
The pump quoted was 10gpm. It would produce 15gallins per mijute. I am definately houng to avoid the computerized drive. I am at the end of the line for power here. It isnpretty stable most of the time but we have som big storms and wind and lots of people lose power. Spikes are not uncommon.
The electrician came to look things over this morning. He will be back friday to do some install work to bring the power into the house. The disconnect and transfer switch.
I have to re run some of my wiring. I have too much for the boxes I am using. Some of it he wants me to redo in 14 instead of 12.
I am pulling the box back out and surface mounting it. Always so fun to redo stuff. It’s the Inexperienced builder tax.
I appreciate you weighing in. Since you are here, what pump would you recommend? Provided, that I could find it with the way supplies are going these days. Any particular vendor you would recommend?
   / My Industrial Cabin Build #2,690
... Some of it he wants me to redo in 14 instead of 12.
Why would anybody want you to remove a bigger wire that's already in place for a smaller wire that cannot handle as much power?
You can never go wrong with a bigger wire, it's just more expensive, but if it's already in place, you can easily run a 15 amp breaker on 12 gauge wire.
large capacity skid steer bucket (A56857)
large capacity...
2009 IC Corporation PB105 School Bus (A59230)
2009 IC...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
40 (A52708)
40 (A52708)
BOX BLADE (A58214)
BOX BLADE (A58214)
PARTS ONLY - Has Title - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - Has...
