Used Front Wheels YM2000..???
/ Used Front Wheels YM2000..??? #1
treedawg
Dublin, GA
Kubota M6800, Yanmar YM2000
I see several vendors selling new front wheels but I would prefer a good used one if possible. Ive seen several on eBay but none are currently listed. The old one has been cracked for years and it recently started wobbling. I think it’s time for a replacement before it fails.
/ Used Front Wheels YM2000..??? #4
That’s an awesome price. Willing to sell one..???
Sorry, no, I really need them both.
Here's one I took off. I re-purposed it as the base for a welding table / grinder pedestal. The other one was just as bad. Both cracked, welded, (a little crooked), cracked a second time. I can't imagine what the prior owner did to them. One has $25 written on it. He must have busted and repaired/replaced wheels a lot.
20170224rcrackedwheelgroundflat-jpg.604241
This one's new life.
20200514_152819rwelding-in-shop1-jpg.693647
/ Used Front Wheels YM2000..??? #5
I had wobble also on my Org. front YM2000 wheels. A lot on 1 wheel anyways. The Inside of the 2 Bearings Disintegrated. and the other one fell out in pieces. New there was a problem so wasn't really surprised. Org. tires still with some Dry rot. Foam fix a flat took care of that and Ill probly just Tube them when I have to. It showed up in the Valve and quit leaking. Bought it in 08 and over 900 on the Tac. I put on there so I sure can't complain....
Looks like you are starting to develop spider cracks around the lug nuts on your new wheels. Maybe that's a common issue and I should bite the bullet and buy new wheels.
/ Used Front Wheels YM2000..??? #7
I think some JD wheels might fit? Maybe look there.
Have you called Hoye? They have parts tractors and would imagine they have a few floating around...unless there a lot of people needing them and they sold them? I can't imagine wheels being that needed of an item?
/ Used Front Wheels YM2000..??? #8
Just in the wheels and mostly just paint cracks. Lug nuts come loose again!! Been doing that for Yrs. Off the top I can't recall the size but it's not common. Standard is a MM. or so smaller. Lost two and so I Used standard Lug nuts and Bolts. They're not coming loose. I'm always moving 5th. 6th. gear so I'm rough on the wheels.
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
Linx EQ07018RS 18ft Trailer (A65640)
Linx EQ07018RS...
2018 TAKEUCHI TL8 SKID STEER (A59914)
2018 TAKEUCHI TL8...
429888 (A61165)
429888 (A61165)
Iranch IRET13 Electric Tricycle (A64127)
Iranch IRET13...
2022 EZ-GO ELITE...
