Skidding Tongs for pulling lumber - What else do I need?
   / Skidding Tongs for pulling lumber - What else do I need? #31
I purchased some choker cables from a logging supply company and love using them. Having broken log choker cables available at big box home improvement stores and fought tongs, I'll keep using the cable chokers. They are easy to push under logs. Depending on the size of log you can diy a log skid to put under the log to keep it from digging in when pulling. Basically you want something to keep the log from digging in and getting full of chainsaw dulling dirt. I made one out of a metal wheelbarrow tub. Just cut the back end out to let the log sit inside and put a hole in the front for the choker to pass through. It worked well for me. I have used it to drag decent sized logs with an ATV when it was the only machine that could get to the logs. When the log can't sign in, it's much easier to pull.
   / Skidding Tongs for pulling lumber - What else do I need? #32
I made a DIY log skid (sled) using the curled end designed for highway safety railing.
The shape is just right and kind of looks like the end of a giant ski.
They are even shaped to keep a log end centered.
   / Skidding Tongs for pulling lumber - What else do I need? #33
I've been using a cable choker. They cost less than tongs, they grip hard and don't come loose. Since they are stiff they're easier to poke under the log than chains.
I have some long chains that I use to hook to the tractor, and also a 65' cable that's sold by HF as a winch cable replacement. I got some clamps and a ferule and made a loop on the bare end. The winch cable was the cheapest way to get a cable that length.
This works ok when there is room for moving the tractor while pulling the log. My land is steep and wooded so there usually isn't room to run the tractor to do the pull. I now have a forestry winch on order.
If using cable, add in a snatch block or several to your logging tool kit! There are some handy self releasing snatch blocks available (never personally used one but they sure look nice in some videos I have seen). Snatch blocks allow you to redirect your pull which is very helpful in tight areas. You probably want a second pair of eyes to prevent getting your cables jammed into the snatch block—a real pain and time consumer.
   / Skidding Tongs for pulling lumber - What else do I need? #34
It may be worth the time to check out prices for appropriately rated lengths of logging/tow chain or wire rope at Home Depot/Lowes/Menards/Tractor Supply instead of using tow straps. Dragging stuff behind a tractor puts a beating on whatever you are using to pull with. At very least I probably wouldn't plan on using those tow straps as tie downs afterward. I've got two 20' sections of 5/16ths tow chain and I think they might have cost $90.00 together. You should also be able to buy by the foot for custom lengths at a comparable price to pre-cut lengths.
Another thought... Consider investing in a shorter length of heavy duty wire rope to act as a choker as an alternate to the tongs. In some situations tongs work better and in others they may not bite well enough and a wire rope choker might be of better use. Just make sure you constantly check the fasteners for the eye for slippage and the wire rope for fraying. Best of luck!
Tongs are only as good as the diameter they were meant to fit. Unwieldy and at times hard to keep attached. Ideal set up to me would be a 3 point hitch log lifter appropriately sized for your needs.
   / Skidding Tongs for pulling lumber - What else do I need? #35
A skidding cone comes in handy, a Blue barrel https://northernwoodlands.org/articles/article/homemade-skidding-cone would work fine .
I definitely agree with the use of some sort of skidding cone, especially if you are dealing in a rocky area or going uphill. I found myself with a large mess on the back and side of my property from a tree thinning project in our community. The forest service did "lop & scatter" rather than removing downed trees and debris from the canyon area. This was a main wildlife corridor that greatly effected the elk travel pattern, which we loved to watch. So my wife and I decided to clean it up. Ended up being at least 5 overloaded trips with my 22' flatdeck to the slash pit.
With a lot of exposed rock and stumps I needed to have something that would allow the timber to not get stuck pulling uphill. I purchased a 15G conical drum and cut off the top to use as my log skidder, along with a choker chain, multiple g70 tiedown chains and a 5000lb 12v HF winch we got to work. Another must have for the chains is the "locking end" clip type so that the multiple chain connections don't come undone until you want them too.
And as everyone else keeps saying... BE SAFE DOING YOUR PROJECT!
   / Skidding Tongs for pulling lumber - What else do I need? #36
Think you may have quoted the wrong post friend.... I've never used tongs for skidding the logs I've needed to move, though I've seriously consider buying two pair for piling up the large amount of railroad ties the former property owner used for landscaping.
   / Skidding Tongs for pulling lumber - What else do I need? #37
I brother used to work for a paper mill and they used G80 or G100 9/32" over head chain in 20 ft lengths. They could only use it so long and then they had to
throw it away. My brother and many of these chains. We had a slip hook on each end.
The advantage of a chain over tongs is that you can wrap the chain so you can roll the log or hook the chain so you can steer it around a stump.
   / Skidding Tongs for pulling lumber - What else do I need? #38
Aint really the size of the tractor but the load being moved. I agree, a couple 5/16 and a couple 1/4 and a steel rod and bar for poking/pulling under. Chokers are ok but for the diy type chains may be better, chokers get assholes in them and wires are sharp. Nylon not really good for this. Hard to damage a chain if you aint doing something you shouldnt.
   / Skidding Tongs for pulling lumber - What else do I need? #39
Hard to predict the load pulling a log. Never know when it might dig in, bind on a stump, get hung up on another tree, etc.
A chain that the machine isnt capable of breaking before loosing traction is better than a chain you have to constantly worry if you are overstressing it
If a 3/8" log chain is too much for you to tote around, I dont think wielding a chainsaw and cutting firewood is the right thing to be doing
Volvo ECR235CL (A53317)
Volvo ECR235CL...
2010 Dodge Grand Caravan Van (A56859)
2010 Dodge Grand...
2021 Boss 990 Fuel Trailer, VIN: 1F9BT1028MB503652, Honda GC 160 Gas Fuel Pump, Tandem Axle, GVWR: (A59076)
2021 Boss 990 Fuel...
LARGE METAL RACK W/ 5 LEVELS (A58374)
LARGE METAL RACK...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
