Kioti CK3510SE HST - How The Hell Do I Engage the Locking Diff?
/ Kioti CK3510SE HST - How The Hell Do I Engage the Locking Diff? #1
MailManX
2021 Kioti CK3510SE HST
I have a 2021 CK3510SE HST. The darn diff lock lever below the left side of my seat feels stuck. It's been that way in the three months that I've owned the tractor. I've stepped on it, pushed on it by hand, tried it in gear, tried it in neutral and tried it after rocking back and forth a bit. NOTHING has worked! Am I doing something wrong? Maybe I have to hold my mouth just right. I don't want to haul the tractor 2-hours back to the dealer, so I'm hoping to sort this out on my own. Your suggestions are appreciated! THANKS!
/ Kioti CK3510SE HST - How The Hell Do I Engage the Locking Diff? #2
Do you know that it only engages when it's pressed (and held) down and that it should not be held down for more than it's needed to get you unstuck.
Holding down the lever, locks the two rear tires so that you can not turn the tractor without dragging a tire (stressful). Hope this helps.
{EDIT} - are you saying that diff lock doesn't move at all?? Does it slide up and down??
/ Kioti CK3510SE HST - How The Hell Do I Engage the Locking Diff? #3
Do you know that it only engages when it's pressed down and that it should not be held down for more than it's needed to get you unstuck.
{EDIT} - are you saying that diff lock doesn't move?? Does it slide up and down??
Oh yeah, my brother always hit the lever when tractor was spinning wide open. I tried to tell him. He just acted like I was stupid. But his dif lock don't work no more. But as long as it was his fault, I'm fine and dandy with it. Just like blowing reverse out of a perfectly good log skidder. Saw it happen, was yelling to stop, boom. It was all over but the crying. I guess when you have a good job you can do things like that. I know I had to pull the engine to get transmission apart. Went ahead and went through both differentials, stripped it down to the frame and sandblasted, rims too. I do love my brother and am proud of him.
/ Kioti CK3510SE HST - How The Hell Do I Engage the Locking Diff? #4
Try some lubrication on under side things.
/ Kioti CK3510SE HST - How The Hell Do I Engage the Locking Diff? #7
As said, it's not something that stays engaged, if that's what you mean..? Foot pedal should be in the 'Up' position when disengaged. Otherwise some rocking should let it slip in. The actual foot lever is just a simple lever arm and pushrod setup so not much to go wrong unless its a misadjustment inside the diff.
/ Kioti CK3510SE HST - How The Hell Do I Engage the Locking Diff? #8
Your owners manual is your friend ;)
Embarrassed, I am. I have told others over the years to RTFM! Time to look in a mirror and repeat it to myself. The lever moves just fine. I took it upon myself to determine that it should go “click” and stay locked in. I’ve had lots of 4x4 trucks, but this is my first tractor. All the more reason to read the manual!
Hit the pedal with a rolled up operator's manual.
At least then you'll have the satisfaction of using it for something.
That’s one of the funniest things I’ve ever read. ROFL!! I had that coming!
The
The misadjustment is between my ears. Based on comments here, the diff lock is working just fine.
Touche! I’ll have to retrieve it from under the leg of the couch where it makes up for a chunk gnawed off by the dog a while back.
JK 🤪
Thanks for the picture and clear explanation.
/ Kioti CK3510SE HST - How The Hell Do I Engage the Locking Diff? #15
The other one is for the 4wd. It *does* stay clicked :)
Still should only really use it when needed as well and make sure its disengaged when traveling at high speeds or on firm ground/roads/asphalt/etc..
/ Kioti CK3510SE HST - How The Hell Do I Engage the Locking Diff? #16
Mate, I've advised this on a number of occasions... 'if it moves, but doesn't have a dedicated grease nipple (zerk), spay it with a lanolin based lubricant.' Do this every now and then and you'll avoid all sorts of future problems... including regular greasing and annual torqueing the wheel lugs + all accessible bolts/nuts.
(I also laughed at the "smack it with the Owner Manual" comment... if only it were true. ;))
/ Kioti CK3510SE HST - How The Hell Do I Engage the Locking Diff? #17
Yes so true. People are used to new autos. Just get in and go. Tractors take a bit more up keep.
/ Kioti CK3510SE HST - How The Hell Do I Engage the Locking Diff? #18
The funniest thing I’ve read!
Oh man! I’m stealing this!
/ Kioti CK3510SE HST - How The Hell Do I Engage the Locking Diff? #19
Nothing bad about reading the manual but you should feel comfortable asking any question you want on this site without the snarky comments.
/ Kioti CK3510SE HST - How The Hell Do I Engage the Locking Diff? #20
One of the great things about the people on this forum is they may give you a ribbing on occasion but will always answer your question and provide advice in the process.
2026 Electric Tricycle (A64194)
2026 Electric...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
DSP 900 Balancer with Split Weight (A63689)
DSP 900 Balancer...
2002 Ford F-250 Service Truck, VIN # 1FTNF21L52EB33349 (A65563)
2002 Ford F-250...
16ft T/A Utility Trailer (A64557)
16ft T/A Utility...
(INOP) 2022 MACK MD6 WATER TRUCK (A65054)
(INOP) 2022 MACK...
